Haier Energy Star ESA3183 Air Conditioner
Problem for Haier Energy Star ESA3183 Air Conditioner
Central air conditioner
By Guest on Jan 18, 2006
central air conditioner doesn't turn on... Any suggestions?
Solution #1
posted on Jan 18, 2006
Somewhat Helpful)
nagev
Rank: Wiz
Rating: 78%, 2426 votes
If the compressor turns off and won?t come back on during a very hot day, the unit may have built up a high "head" pressure and the high-pressure limit switch may have tripped. This is usually located right inside the access panel on the compressor unit. Simply push the button to return it to operation.
If your central air conditioner doesn't go on automatically:
1) Be sure the thermostat is set to "cool" and set below room temperature.
2) A central air conditioner should be on a dedicated 240-volt circuit; check the main electrical panel and any secondary circuit panels for a tripped breaker or blown fuse. If you find the problem here, reset the breaker or replace the fuse.
3) Make sure the furnace power switch is turned on and that the outdoor condenser's power switch, mounted on the outdoor unit, hasn't been shut off. Also be sure the 240-volt disconnect next to the compressor (in a metal box, usually mounted on the house wall) hasn't been shut off.
4) Turn off the power to the air conditioner and check the thermostat.
5) Remove the thermostat's cover and unscrew the wire from the Y terminal.
6) Turn the power back on.
7) Holding the wire by its insulation, touch the bare end to the R terminal and hold it there for about 2 minutes. If the compressor kicks on, the thermostat is faulty; replace it or call an air conditioning technician. If the compressor doesn't go on when you hold the two wires together, turn the power back off and call a service technician.
You rated this solution as "Somewhat Helpful".
Solution #2
posted on Apr 12, 2009
Not Rated)
joelcoval
Rank: Apprentice
Rating: 0%, 0 votes
Both the inside air handler and outside unit would not come on. After disconnecting the thermostat and reconnecting it and setting it on cool both units came back on. Is this an indication of a bad thermostat or is it possible it reset.
Was this helpful?
Yes
No
Popular Solutions for Haier Energy Star ESA3183 Air
Questions and Unsolved Problems for Haier Energy Star ESA3183 Air
Do you recommend Haier Energy Star ESA3183 Air Conditioner?
Answer
Answer
We have and L6 error code on AGER mdoel RCL-13H. Any know how to fi it
Answer
breaker trips and feels warm to the touch when I went to reset it.
Answer
Have 5,200 BTUair conditioner window air conditioner and my dog got a hold the remote and chewed it... (More)
Answer
Haier Window A/C unit won't come on - just reads E1
Describe your Air Conditioners problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Air Conditioner Experts
Top Air Conditioner Repairmen
ARS
(866) 800-3823
When it comes to air conditioning systems,...
ARS
Service and Repair, System Maintenance, Advantage...
Aire Serv Heating & Air Conditioning
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
