Question about KitchenAid Superba KSCS23IN Side by Side Refrigerator
Icing and frost clogs the ice dispenser
My icemaker is accumulating frost and ice underneath the big ice tray and around the opening where the ice comes out. It clogs the ice from dispensing.
  • 725 Answers
Check the dispensing flapper ,, it may not be shuting there is a spring and lever it the lever is bend or if the spring is broken it will not close correctly clean and clear all the ice .. then check that it will close after you open it...hope it helps
Posted on Sep 07, 2008
  • closeups Jun 03, 2012
    How do you fix this? Any pictures or procedure? I have GE side-by-side and has exactly same problem. I see Flapper loose and stays slightly open. There is a heavy frost buildup in the chute. Ice cubes/crush wants to come out, but gets clogged behind the clog.
I have major ice build up in the freezer near the icemaker area of my GE side by side. Replaced the icemaker, but the problem came right back. HELP!
Icemaker inlet water valve may need replacing. If the valve
is not closing all the way it will leak water into ice tray.
Sometimes well water without a conditioner can cause
cause this problem. LynnMBent
Oct 27, 2015 | GE Refrigerators
Why do water accumulate at the bottom of my fridge under the vegetable tray?
If your refrigerator is frost-free, the water accumulates during the defrost cycle and should drain through a tube at the bottom into the evaporator pan underneath. The tube may be clogged or broken.
Dec 18, 2014 | Refrigerators
Hello! I have a Kenmore refrigerator model #10656576400. It stopped making ice for a while but then started up again. Now it is leaking water and filling up the tray underneath the ice cube mold. Is it...
The first thing to check would be the water fill valve located usually on the back outside of the unit where the water line comes in, these can start leaking water slowy into the icemaker. The icemaker itself tells the valve how long tostay opened, that can be adjusted by a tech or you may need to replace the icemaker
Jun 24, 2011 | Refrigerators
Ice accumulation on the bottom of the freezer
Your drain line is clogged, that is located behind the white wall inside of the freezer. The water comes from defrost cycle, that happens every 8-12 hours. You need to defrost it and snake it.
Maytag refrigerator repair in Orange County, CA
refrigerator repair in orange county, ca
appliance repair orange county, ca
Feb 06, 2010 | Maytag MZD2766GES Side by Side...
Ice maker stopped working. Red light is blinking.
  • That means no flow of water to icemaker. So check the solenoid valve paddle is stuck/jammed due to a fault in the Valve; replace valve.
  • accumulation of frost in the water supply tube &/or blockage
  • defrost button stuck
push the door close button with your thumb, insert the ice tray, any water flowing into the icemaker??----------- observe the position of the paddle & don't forget to check the defrost button is not engaged.......sodeep
Oct 26, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Kenmore elite bottom freezer. Frost, Ice tray
The adjusta cube ice maker has an on/off switch. To stop the ice from overfilling and being knocked off when you open the freezer door turn the ice maker off and then back on as needed.
Mar 28, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
My old whirlpool refrig. with frostless freezer on top model # ET20DKXSN 00 has started to form frost in the back of the freezer where the ice cube trays are stored. It seems to be coming from the around...
check the back of the refrigerwtor there shpoould be a opening where the water goe into the freezer for the ice maker. you need to seal it up so that the moiust air from outside does not enter the freezer.
Feb 24, 2009 | Refrigerators
Icemaker leaks into freezer compartment
Sometimes the drainage inlet for the defrost can get clogged and then the frost has no place to go (usually an evaporator pan at the base of the fridge) have you ever felt the side walls or within the fridge and it was warm? When it is working the tray heats to rid the fridge of the frost. The DYI solution is simple but can be frustrating. If the freezer is on top and you can remove the drip tray and the contents for that matter and see the inlet all the way in the back most likely covered in ice, turn of the fridge throw a bunch of towels togeter with sponges and buckets and le the fridge thaw out for the day sopping out all of the water. If you can get to the inlet squirk some hot water with a turkey baster down into the hole and listen for the flow out into the bottom into the tray. Take the back off of the fridge (or access panel at the botom) to see the evap tray. If it is totally dry and looks like it has been for a while then it hasn't been draining. Usually unless a waterline is leaking or broken ice formation is a faulty defrost, huge amounts of continuous water is a leaking suply line. The frustraing part of the DYI solution is if you don't get the blockage free from the line (usually a clear tubing that emties into the evaoprator tray) and put everything back together and restock the fridge about a week later it will start icing up again.
Feb 11, 2009 | GE Refrigerators
GE TFX22CR Ice Piling up in Back of Freezer
You either have icing that you didn't clear or the unit is low on gas.  You might also try cleaning the condenser coils.  This is a big problem in cooling.
To check low gas:  After cleaning the condenser (!), clean around the piping to the compressor in the back of the unit.  Wait at least an hour with the unit shut off.  Restart.  The larger pipe should begin to frost up.  If after about 15 minutes the frosting gives way to: ice, wetness or drying out...the gas level is likely okay.  If it stays frosted, you'll need a gas recharge.
Nov 04, 2008 | GE GSS20IEP Side by Side Refrigerator
Ice accumulating in freezer
There should be a tube that brings water to your icemaker from the back of the fridge into the icemaker. This tube is frozen with water, or the inlet where this tube feed the icemaker tray is frozen. The result is that water cannot go to the ice maker, and instead, goes over the top of the inlet area.
Verify that this is indeed what is going on.
The fix is to remove the blockage/buildup of ice at the inlet. You may have to detach the icemaker to get to it. Be carefull with electricity! Also be carefull as plastic can break under stress!
The tube may be frozen to the inlet, channel locks can be used to gently twist the tube to break it free.
Good Luck!
Jan 01, 2008 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
201 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
