Question about HP Color LaserJet 2600n Printer
HP color laser jet 2600n. Shows 51.22 error
Since replacing black cartridge, my printer has consistently been showing 51.22 ERROR, turn off then on. I have turned it off then on, leaving it in between anything from a minute or two to days. It continues to read the same and, of course, doesn't print.
  • 3 more comments
  • normalkat Sep 10, 2008
    I have run initialisation several times, each time I switched the printer back on. It makes no difference
  • normalkat Sep 13, 2008
    Switching off then on, initialising again and again makes no difference. The manual suggests a hardware error. Is there anything I can do?
    Turning on and off and initialising makes no difference. The manual suggests a hardware error. What can I do?
    I am getting nowhere with this 51.22 error problem. Any ideas???
  • Anonymous Mar 16, 2014
    Printer will not read new black cartridge
  • HP Master
  • 19,396 Answers
The error is with one of the toners, see here: 51.22 Error Turn off then on
Try the following:
  • Remove all toner cartridges.
  • Unplug the printer power cord and wait ten minutes.
  • Plug back and restart the printer.
  • Start and complete the toner installation, installing all toner cartridge, one at time, in the same you did when printer was new, before using it for first time.
It usually fix problems with toner, after toner replacement.
Posted on Sep 13, 2008
  • Ginko
    Ginko Sep 13, 2008
    If the toner replacement did not unlock, then the probably printer must be taken apart to clean residual toner inside the printer, if this is the case , then you should follow HP suggestions and call service.
  • Shamus Woosley
    Shamus Woosley Mar 09, 2018
    51.22 is problem with scanner laser, has nothing to do with color toner cartridge.
    Brigadier General:
  • 5,158 Answers
51.22 Error Turn off then on Error message 51.22 Error Turn off then on Description Magenta laser scanner error. The device has experienced an internal hardware error. Action
  1. Turn off the power by using the power switch, wait at least 30 seconds, and then turn on the power and wait for the device to initialize.
  2. If a surge protector is being used, remove it. Plug the device directly into the wall socket. Use the power switch to turn on the device.
  3. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
    Robert
    Posted on Sep 07, 2008
      Master:
    • 505 Answers
    Http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=c00314875&locale=en_US
    Try look at This Site
      President:
    • 1,263 Answers
    After you replaced the cartrige,did you run a initialization?
    Hp laser jet 300/400 10.1000error
    10.10 error means it does not recognize the chip on the cartridge or that the seal is still in cartridge need new cartridge
    Feb 24, 2015 | HP LaserJet Pro 400 color M451dn - Printer...
    I have hp color laser jet 2600n printer.. but after printing, there have line at the both side left and right on my paper.. the line is about 1cm .. how do i fix the problem.. tq..
    If the lines are predominatly one color such as yellow or cyan then you likely have a bad cartridge. If you recently replaced a cartridge that is the one I would check first. You can also just look at the drum of each cartridge (the green roller under the shutter). If there is a problem it will usually show on the drum as well. Cartridges are the biggest issue with these printers, particularily the poor quality of cheap remanufactured cartridges coming from Asia.
    Mar 16, 2011 | HP Color LaserJet 2600n Printer
    My Hp Color laserjet 2605 was not working some colors (yellow,megeanta) so how to resolve this problem ? all color tones are new ! i would pinted test page black and cyan was ok
    This is a common problem with this model of printer. The scanner optic degeneration is due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta and yellow toner cartridges, red tones are the first to show fading. Colors shift: purples turn blue and oranges turn yellow. The printer optics will need to be cleaned by a compliant technician to resolve this issue as it means dismantling your printer and cleaning the mirrors and lenses in the optic section to fix the problem.
    Aug 09, 2010 | HP Color LaserJet 2600n Printer
    MY HP ''COLOR LASER JET 2600n'' HAS FUOLL INK CARTRIDGES BUT THE PRINTING IS REALLY DULL AND FADED LOOKING. CAN ANYONE HELP? TERRY M.
    This is a common problem with this model of printer. The scanner optic degenration is due to dust buildup on mirrors and lenses. Since the most vulnerable mirror reflects its laser beam to the magenta toner cartridge, red tones are the first to show fading. Colours shift: purples turn blue and oranges turn yellow. The printer will need to be cleaned by a certified HP technician to resolve this issue as it means dismantling your printer to fix the problem.
    May 30, 2010 | HP Color LaserJet 2600n Printer
    Hp 2600n error 51.22 magenta cartridge, says turn on and off, hel
    51.22 is a Magenta laser scanner error.
    Try removing the magenta restarting the printer and reinstalling.
    If that does not work you likely need a laser assm.
    You might want to call a tech. to replace.
    Apr 01, 2009 | HP Color LaserJet 2600n Printer
    Black ink only?
    No, the answer is not.
    printer need all fo the ink cartridges in order to print.
    Feb 09, 2009 | HP Color LaserJet 2600n Printer
    HP color jet 2840 cartridge not recognize
    Turn the printer off and turn it back on again and see if happens now.
    Jul 12, 2008 | HP Color LaserJet 2600n Printer
    New Black Cartrige
    plz try with another cartridge
    Jul 01, 2008 | HP Color LaserJet 2600n Printer
    Hp colour laser jet 2600n
    This printer should still be under warrantee, can you take it back?
    Oct 16, 2007 | HP Color LaserJet 2600n Printer
    HP Color LaserJet 2600n Printer Logo
    1,591 people viewed this question
    Ben Johnson
    mukhtar21 shaikh
    mukhtar21 shaikh
