Question about Haier Energy Star ESA3183 Air Conditioner
No cooling My room air conditioner doesn't cool. what do I do?
  • alwayslearn Jul 21, 2008
    same problem, window unit clows cold then warm air will not cool 400 sq. ft. room!
F8 displayed
Posted on Sep 06, 2008
Is the a/c blowing warm air? If the coolant is not the issue, it may not be an efficient a/c, and has frosted up inside. Turn the unit off, and let is defrost. This will take several hours, but until the ice is gone, it will not allow air to blow through.
Posted on Jun 17, 2008
Most likely you have a bad thermostat or very dirty coils thermostats are easy to trouble shoot just remove the knob and jump the two wires on the back of it together if it comes on you have a bad thermostat. if your coils are very dirty do what the other post said but use a cleaner such as a new bright or alki foam to aid in removing the dirt from the coils.if it is real bad you will also need to clean the blower wheel but this can be hard depending on the type of unit you have.good luck
Posted on Nov 29, 2007
The compressor overload switch has tripped.
Posted on Aug 14, 2007
Shotage of gas
Posted on May 13, 2007
    Novelist:
  • 74 Answers
A room air conditioner that doesn't cool may need to be recharged with refrigerant, but the chances are good that it simply needs to be cleaned. You can do this work yourself, which involves disassembling the unit, or you can call a professional (see Air Conditioning Service in the Yellow Pages). Before attempting the work yourself, consult your owner's manual and make sure you have the right skills and tools to handle the task. Here is what a typical owner's manual will advise: 1) Unplug the unit and remove it from the window (beware, these are heavy!). Put it where you can work on it outdoors. 2) Remove the grille and filter and unscrew the metal case. Be careful not to damage the coil's fins. 3) Wash out the filter or replace it with a new, inexpensive filter--cut-to-size foam filter fabric is available at most appliance stores. 4) Using a vacuum with a soft brush attachment, clean the inside coil's fins. 5) Then, from the fan side, spray water back through the fins (protect the wiring and motor with plastic). 6) Clean it up with a rag, making sure all drains that allow condensed water to drip away from the unit are open. Allow it to dry thoroughly. 7) While you have the unit apart, lubricate the motor according to your owner's manual instructions. 8) Then reassemble and reinstall the unit. If that doesn?t do it, clean the evaporator and condenser coils.
Posted on Jan 18, 2006
Its very easy.. throw u r old ac and buy new one it may help u better cooling
Posted on May 12, 2008
The outdoor unit does not work
Posted on May 07, 2008
  • shallal May 07, 2008
    the outdoor unit in my split air conditioner type-TAD-SWI DOES NOT WORK help me please
4 Suggested Answers
relaga58
  • 158 Answers
SOURCE: air conditioner not working
have you tried turning off and on power from the plug ?
Posted on Aug 17, 2009
demonicsaint
  • 160 Answers
SOURCE: air conditioner only cools sometimes
Your convergence is off. See the owners manual or call tech support to walk you through a convergence.
Posted on May 06, 2010
  • 251 Answers
SOURCE: Haier air conditioner will not kick on to air
A few basic principles for air conditioner troubleshooting. For both central home air conditioner or window air conditioner, the first thing to check is whether the unit is getting proper power. If the unit uses 220 volt power be sure that the proper voltage is getting to the unit. Same for 110 volt units. A voltage meter can be used to assure that the voltage is correct.
For window air conditioning units the voltage can also be checked before and after the thermostat. If voltage is being supplied to the thermostat but not from it then the thermostat probably needs replaced. This is a fairly common problem. Another place to check is the fan motor voltage. The fan on window air conditioners runs both the indoor blower and the condenser fan. If that motor fails than the compressor may run for a short time, but will overheat and shut off. Continued operation like this will result in compressor failure. This motor can be economically replaced for larger window air conditioners, but for smaller ones the cost of replacement will be more than a new unit.
Central air conditioners for the home are more complex and there are more things that can go wrong. As with the window air conditioner the thermostat can also be a problem. The central air conditioner thermostat will only have 24 volts going to it. So don't look for high voltage there. Some units the voltage will be coming from the outdoor unit and others the voltage will be supplied by the indoor air handler or furnace. Most home central air conditioning will be supplied by the indoor air handler or the furnace. If the air conditioner is for cooling only the unit will usually have only two wires going to the condenser unit. Make sure that you have 24 volts across those wires.
The next thing to check will be the indoor blower. If your thermostat is calling for cooling then the indoor blower should be running. If there is no air moving across the indoor cooling coil then you will soon have a big block of ice formed on the coil. This can happen for a few reasons. The indoor blower is not working, the air flow is restricted and not allowing air to move across the coil. A clogged air filter would also do this. Or the outdoor condenser unit has lost the charge of refrigerant.
Finally and worst of all is when you have a complete compressor failure. Often when this happens the compressor will "lock up" or not be able to turn when power is supplied to it. Overheating or lack of lubrication are usually the main causes of compressor failure. Overheating can be caused by the outdoor coil around the compressor getting clogged with dirt, leaves, or grass. Loss of the refrigerant charge will also cause the compressor to overheat. It is the cool return gas coming back to the compressor that helps to keep it from overheating.
As you can see there are many things that can go wrong with an air conditioner and I have not come close to exhausting the possibilities here. I have just touched on the most common problems in a very basic way.
There are some basic trouble shooting things that can be done very easily. Most problems are above out of the range of comfort for many homeowners and professional help should be consulted before any attempt is made at repairs. Remember also, that the release of refrigerant gases into the atmosphere is a federal offense in the
US. Proper care must always be taken to minimize the release of any gases. A license is also required to handle refrigerants. Make sure that the professional you call has the proper certifications to handle refrigerants properly.
http://www.fixya.com/support/r3636709-size_air_conditioner_need
http://www.fixya.com/support/r3623253-window_air_conditioners_clean_every_year
http://www.fixya.com/support/r3633369-portable_air_conditioning_great_portable
http://www.fixya.com/support/r3623166-heating_air_conditioning_scams
http://www.fixya.com/support/r3597468-you_can_add_air_conditioning_to_your_hot
http://www.fixya.com/support/r3583697-how_to_keep_house_cool_without_using_air
Posted on Jun 07, 2011
Kenmore 580.15151500 Compressor doesn't turn off
Most likely is a issue with the temperature sensor that when it reaches the level selected is not turning the compressor off.
Jun 15, 2012 | Kenmore Room Air Conditioner
Just bought a 2 yr. old Danby DAC5209M window a/c unit that doesn't cool the air before it blows it into a room. The wiring looks brand new, it was barely dirty on the inside, anyway, I've...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 24, 2011 | Danby DAC5020 Air Conditioner
I just purchased a kenwood a/c a couple of weeks ago it's a G130EK, 13,000 btu and it doesn't cool anything not even a 12 x 12 room. There is an opening that leads to a bigger room , but the...
Air conditioners generally cool the air 15 to 20 degrees. 80 degrees in return should be 65 in supply. 70 degrees in return should be 55 in supply. If the a.c. is in that range it is working fine and doing all it is going to do.
Jul 02, 2017 | Kenwood Heating & Cooling
The air from my air conditioner doesn't seem to be coming out as cold as it was when i first bought it. It seems to take a lot longer to cool off my living room, i dont know if it needs freon to be...
Its going to take a hile to cool down a hot room . have you cehck the filter? while your at it wash it out . what is the temp of the room and the temp of the air coming out of the unit?
Jul 22, 2011 | Goldstar Heating & Cooling
The air conditioner cools the room but it shuts of. The power light doesn't come on while unit is on. Can I replace the plug?
"The air conditioner cools the room but it shuts of." -- Temperature reached, but does not turn back on automatically? Stops short of reaching temperature? Shuts off for a period, but will come back on only to shut off again later?
Most importantly, how do you get it to turn on again?
"The power light doesn't come on while unit is on." -- If the unit is on and the power light is not, then the power light must not be operating (is burnt out).
Actual answer: "Can I replace the plug?" -- Of course you can.
What is causing you to feel that the plug needs replaced?
:o).
Jun 04, 2011 | Daewoo DWC-056CL Air Conditioner
Portable air conditioner not cooling
Ensure your Portable Air Conditioner is sized properly for the room it is in.
A good rule of thumb is 12,000 BTUs for 400 square feet. If the room you are attempting to cool is too large, then the cooling effectiveness will change.
Also ensure that the air conditioner is properly vented outside of the room.
May 21, 2011 | Heating & Cooling
My air conditioner cooling system doesn?t work
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 20, 2011 | Heating & Cooling
AC was cooling fine. Now, won't cool room even though cool air comes out. Exhaust hose is extremely hot.
Check filter, if you have a 5000BTU unit (small) and it is extremely hot, then it wont work great for a big room. BTU is the rate of what the AC will put out. 5000 BTU is good for a small single room. 10,000 will cool a bigger room and 18,000 btu is meant to cool a home.
Jul 07, 2010 | Whirlpool ACP102PS Portable Air...
Won't cool room off
Check the filter if the filter is plugged the unit will work hard and have trouble cooling the room off.
Jun 01, 2010 | Samsung AW0501M Air Conditioner
Haier Energy Star ESA3183 Air Conditioner Logo
621 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
