It doesn't come on unless it's plugged into a socket
  • 8,596 Answers
Reset, then repair
If the voltage of the charger was wrong or it was overcharged, it can cause permanent damage to player
Posted on Sep 07, 2008
Ecomax400 - Continual cycle - won't turn off unless unplugged at socket!
Please specify that wont stop means filling or washing or rinsing.
Jul 30, 2014 | Hobart Dishwashers
The socket is stuck on the newly installed spark plug
You probably have a spark plug socket that is too large for the plug. Take the plug back out and then you can release the plug from the socket. The act of removing the plug might even unstick it from the socket. If it doesn't you can punch out the plug using the small square hole in the socket with a pin punch or similar item and hammer. A vise to hold the socket would help. Understand that hitting the top of the plug might shatter the ceramic. At least you get your socket back right? Be sure to wear eye protection and gloves. Safety first!
Oct 27, 2011 | 2000 Mercury Sable
No spark changed coil still no spark
Either the ignition module, which is mounted on the outside of the distrbutor, and has a 6 wire in line plug, is bad, or the pickup coil inside the distributor is bad. Modules were very well known for failing back in the day. The module if original, should be grey in color. Some replacements were black. I would replace this first. If that doesn't fix it, you will probably have to chang the distributor, as the pick-up coils are very difficult to change. Distributor disassembly is required. Mark the posistion of the distributor, and loosen the hold down screw to rotate the distributor to gain access to the two 7/32 screws that attach the module. A module tool should still be available at your local parts store. Unless you have a snap-on 7/32 or 5.5mm deep socket, you will need this tool. The screws are recessed and the socket needs to be ultra thin wall to fit in the holes. Craftsman sockets are too thick. Once the screws are removed, push down on the module to slide the three spade terminals loose. Install the new module in reverse order.
Aug 17, 2011 | 1990 Ford Bronco
When i plug in my compressor to the socket it sparks. i'm thinking since it doesn't have an on/off switch it has power all the time and I'm suppose to be plugging it in and leaving it plugged...
It is best to make or use an extension cord with a switched plug socket.( circuit breaker type)
In this case you can switch on when required and the power will be cut off when the switch is OFF.
Aug 09, 2011 | Garden
Hello. I just bought your spa4310 speakers and I linked correctly the subwoofer to my computer (Acer with realtek drivers) and the speakers (red plug to red socket - white plug to white socket). The...
try swapping the speakers around if the problem still persists either the speaker is faulty
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
be sure to wear an anti static earth strap before touching anything inside your computer
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the CPU central processing unit and your sound card dust causes static to build up in a computer causing it to overheat any many other problems
hope this helps
Jun 09, 2011 | Philips Audio Players & Recorders
I dont know how to set it up
- First you need a rather old TV, like maybe before 2002, if you have one. Because on newer TVs N64 graphics are terrible !
- Once you have your TV, check to see if you have two cables with your 64 (if you don't something is missing !). One shaped like a little box on one end and an electrical plug on the other : you hook up the little box to your N64 and plug the device in the nearest power socket. The other cable has a a strange black and rectangular input that hook up in your N64 and 3 sockets that are red, yellow and white. Connect the latter on your TV by finding the same sockets with the same colours !
- Connect your controller to the console (it's the round-ish sockets in front of it)
- insert your game
- THEN turn on your console. Don't turn it on unless everything hooked up !
(if it doesn't work you may want to try the famous turn-off-the-console-blow-into-the-cartridge-put-it-back-and-try-turning-your-N64-again trick !)
Good luck ! :)
May 28, 2011 | Nintendo 64 Console
My Hoover tumble dryer plug keeps over heating
The plug is not making proper contact with the socket, causing arcing and heat due to increased resistance. You probably need to change the wall socket, unless you can close the contacts where the plug pushes in. (AFTER YOU HAVE SWITCHED OFF THE MAINS)
Feb 17, 2011 | Hoover Washing Machines
48 people viewed this question
 Grubhead
Grubhead
