Question about Ranger SS-3900 240-Channels Base CB Radio
Turn down my talkback
I have a new ranger 3900 and the talk back is to loud, how do I turn it down
Find the auido horseshoe turn it down
Posted on Sep 16, 2008
How to turn off talk back setting
To turn off TalkBack, follow these steps:
  1. Navigate to Settings > Accessibility > TalkBack.
  2. Slide the TalkBack switch to the off position.
  3. In the Stop Talkback dialog, select OK.
See link below
Jan 16, 2017 | HOW Video Game Consoles & Games
How do I turn off the talk back feature on lg tribute
TalkBack won't turn off - Google Product Forums
Oct 23, 2013 - 100+ posts - ‎100+ authors
Re: TalkBack won't turn off, Nexus 5 -curious user, 2/15/14 6:38 AM ... I don't blame Google for making this feature so difficult to shut off once ...
How to Disable Talk Back Mode? « Android Gadget Hacks
Jun 24, 2013 - If you just have the regular swipe to unlock feature for your lock screen, to unlock it ... Now, to disable TalkBack mode, you need to make your way to ... I only turned on because my lady friend has an LG Stylo G and she set her ...
How to Exit 0r Disable "TalkBack" Mode on LG Optimus F6 ...
? 3:11
Dec 3, 2014 - Uploaded by Klavdio-Leadership
This Video will show you how to disable the TalkBack Mode on your phone.
LG L70 how to Turn off the talkback or voice over - YouTube
? 2:29
Jan 13, 2016 | LG Tribute 4G No-Contract Cell Phone
Ranger vr 9000 how to turn down the talkback
First , is this radio new or used ? If it is new I see no dial for talk back and if it is used then was talk back added to it ? Open the radio so you can check out trace side of the radio and look to where the speaker jacks plug in. If you see a resister soldered across them then disconnect it and your talk back is gone,unless you still want it then solder a 220 ohm resister in place of the one you removed. if the radio is out of the box new then it should be adjustable but as I look at the face I see no knob marked as talk back.If you ordered this radio and asked for talk back on a seperate switch then which one ? look at it and make the call as to which wires to cut and do it .
Feb 25, 2012 | Ranger VR-9000 Base CB Radio
When ever i dead key the mic on med rf power i get a humming or bumble bee sound through my talkback same thing on high rf power i changed the coax it helped it for low rf power and tried new mic but had...
Thats because your Rf is powerful on high settings..try taping a AM radio "ferrite bar" to your coax in the back of radio for "RF filtering". Keep your power supply 15 inches away from radio. I recommend unhooking talkback on radios (it always causes feedback). But make sure speaker is good distance from the radio. I'd say 10 feet or so, behind radio. Change external speakers or add one with a long cord.
Apr 23, 2011 | Ranger Virage VX-38 Base CB Radio
I have a Connex 4600 Turbo mounted in the headliner of a W900L Kenworth using Wilson 2000 twin antennas and a RK56 mic. When trying to use the "talk-back" feature all I hear is constant...
Strange. You shouldn't have a squealing problem with an RK56 noise canceling mic.
Unfortunately there is no way to change the volume of the talkback. Its too loud. The only solution is to turn the mic gain down.
The only reason you need to have talkback on is to check your audio. Make sure the echo is good and what not. After that you really don't need it on. So turn down the mic gain, then check the echo, then turn off the Talkback and turn the gain back up.
The squeal is feedback from the talkback being to loud and being heard by the mic. So the only way to solve it is to lower the volume of the talkback, (Which is not possible in this radio) lowering the mic gain(which lowers your audio level) or turning it off.
Nov 08, 2010 | Connex 4600 Base CB Radio
My radio recieves ok but only whistles when i key the mike is this a major fix?
Do you have talkback installed? It my be too loud and causing feed back. Back the mic gain down if so.
Could also be improper mic wiring. If you use a mic that is wired for a different radio, it could just cause a hum, buzz or squeal.
Another thing that can cause a hum, buzz or squeal is a faulty volume and or squelch knob depending on the radio.
  • Turn down or disable talk back.
  • If you cannot turn off or disable talk back, lower mic gain.
  • Try a different mic that you know is wired for cobra.
  • Play with volume and squelch knobs while TX and see if it stops at all. If it does replace knob.
Oct 12, 2010 | Cobra 150 GTL DX Base CB Radio
I have a dx98vhp and it sqeels* when i key up when the talkback is on. I've tried adjusting the power and i can't figure it out. Thanks
the talkback is too loud. there is no way to adjust the talkback volume on this radio. Talkback is really just so you can check how your audio sounds and your echo. Once it set, there is really no need to have it on.
Turning down the gain on your mic will stop the squeal.
the squeal is cause by feed back from audio from the talk back being heard from the mic.
Sep 14, 2010 | Galaxy Radios Microsystems DX98VHP CB...
My talk back is low cant hear it
You really don't want to have a loud talk back. Its usually controlled by your mic gain. the louder it is, the louder your talk back is.
Talk back is used so you can her how your audio is being transmitted. It makes a lot of sense when you have echo. use it to hear you echo to make sure its not too much.
The problem with a loud talkback is, if it is too high, you will get feed back in your transmit.
You should leave it where it is.
Jul 13, 2009 | Magnum S6 Base CB Radio
Galaxy dx-66 squeals on talkback
timspur, hi. First off, using the talkback with a tuned Galaxy will give you problems, so you need to use a good noise cancelling mic like a RK 56, or Astatic 636. If your running an amp, that will only amplify the problem. Here is a mod if your comfortable working on your radio, to tone down the TB volume.
Talkback can become distorted if these radios have been "peaked," and there is no cure because the talkback just amplifies what goes to the RF section. Try adding a 470k ohm resistor from junction of C155/R207 to the junction of C187/R235 on the solder side of the board. This will also give you clean talkback on SSB and FM. Try different values of resistance to get the amount of volume you want. The less the resistance the louder the talkback will be.**
Hope this was what your looking for,, I know for a fact that the Astatic mics do help tone it down.
Let us know,,, Mechanic
Mar 12, 2008 | Galaxy Radios DX-66V Base CB Radio
Ranger SS-3900 240-Channels Base CB Radio Logo
135 people viewed this question
Top Ranger Radio Communications Experts
Jon Piercy
Mike Charette
Are you a Ranger Radio Communication Expert? Answer questions, earn points and help others
