Question about Whirlpool Refrigerators
Alarm is constantly bleeping on our Whirlpool integrated freezer, door is closed properly and temp inside seems to be ok. Red and green lights are on, if I push button to illuminate orange light the alarm stops,any help please ? Thanks Steve
  • jimmyjesus Sep 07, 2008
    Hi Krazytech,ive just tried pushing the light button 5 times in 15 secs,still the same. The model number is AFB821/1B INT FRZ
  • jimmyjesus Sep 08, 2008
    Thanks for help Krazytech,ive totally defrosted the freezer,and must admit it is not going off as much now,there is gaps where its not going off at all,and red lwarning light goes off,BUT seems to be as soon as you open the door it goes back off again.Any advice on where the filters are so i can check them also ? Your help is appreciated.
    Thanks
    Steve
  • 725 Answers
May need the model number but try pushing the light button 5 time in 15 sec,, if it will not work send the model number
Posted on Sep 07, 2008
  • Franklin Ouchida
    Franklin Ouchida Sep 07, 2008
    sorry that didn't work this is must be a UK freezer. I don't have access to UK tech sheets ..I would double check the temp and also check the back for extra frost...if you have frost you may also try to unplug it with the door open for 24 hr make sure thet there is no frost build up.... also check the filters have they have been changed...sorry I was not more helpful
Freezer bleeps as if door open. Temp goes down on its own
Kenmore freezer door alarm beeps but door is closed ...
www.shopyourway.com > Manage My Life > Questions
Every once in a while, the door ajar light goes on and the alarm beeps and will not ... Ifthe door is closed good and the door alarm is sounding, it will indicate the ...
How to fix constant refrigerator door alarm beeping? - Shop ...
The doors aren't open and we have checked the air flow vents and made sure ... We have to turn the alarm off to get it to stop beeping but I more concerned about ... If the fresh food section lights are working, meaning you can get the lights to go ... Thefreezer fan motor would need to be checked to make sure there motor is ...
Jan 12, 2016 | Refrigerators
Why is the temperature alarm light on, on my freezer Model# FFU21M8CW?
Good Afternoon Friend,
I understand that the temperature alarm light is on for your Frigidaire freezer, model# FFU21M8CW. This feature is designed to provide a warning of a possible malfunction. If the temperature of the food rises to a level unsafe for long-term storage, the buzzer will sound. The red light, if equipped, will also glow. The Temp Alarm feature operates on household electricity. If power fails, the alarm will not function. An ON/OFF switch allows you to deactivate the Temp Alarm when not wanted. Your freezer is shipped with the Temp Alarm in the OFF position. After your freezer has run approximately 4 hours, the red light, if equipped, will go off. Then you may activate the Temp Alarm without the alarm sounding. Press the ON switch to activate the Temp Alarm. To deactivate, press the OFF switch. If the alarm sounds, be sure freezer is properly leveled, and the door closes freely, and seals properly. If you suspect a technical malfunction, call an authorized servicer immediately. Hope this is helpful.
-Best Regards-
WP
Jun 24, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Whirlpool High Temperature Alarm Keeps Blinking
New Refrigerator / Freezer usually takes up to 12 hours to get the food down to temp and the inside air temps to stabilize...
Now, try explaining that to a BSN who is required to take hourly temp readings on a refrigerator and just loaded it half full of warm soft drinks and is opening and closing the door repeatedly retrieving supplies.
You lower the temp to "suit" (shut 'er up) and tomorrow they're calling you back because it's too cold...
Apr 13, 2014 | Whirlpool Refrigerators
Whirlpool freezer display flashing 1
Hi Rachel
For your door to close properly take off the gasket from your fridge and wash it with hot water. It will be softer and stick to the fridge much easier.
Feb 15, 2014 | Whirlpool 10 cu. ft. Chest Freezer...
Can't get alarm to turn off while temperature stabilizes
My wife solved it for me :-) You turn the alarm off with a switch at the bottom. The alarm turns off, but the light stays red for another 4 hours. After that the red light goes off too, and you can turn the switch back on without the alarm going off, if the freezer is back to operating temp.
Aug 06, 2009 | Frigidaire Upright Freezer FFU12F2H
Too much bleeping
The alarm is caused by either temperature disorder, check on your thermostat settings, or it is being caused by unbalanced level of freon gas in the system, or the door of the freezer does not shut correctly.
Thanks
Nikunj Pattni
nikunj@qool-point.co.kr
Nov 17, 2008 | Liebherr Refrigerators
Whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted
whirlpool side by side fridge freezer alarm keeps bleeping and freezer has defrosted. the temp display on freezer shows - - flashing
May 16, 2008 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool s20b fridge/freezer
858615215011 temp. indicators and night light flash continuously.
Mar 27, 2008 | Refrigerators
Kenmore Upright Freezer Model 253.9239780 Temp alarm, Temp rising slowly
you have a refrigeration issue partner let her go 16 yrs. is good service you can replace it for 3 to 5 hundred the repair will be that IF you can find someone with the r-12. don't go for a top it off and go deal the food you lose is to expensive for that to be economical.
Mar 22, 2008 | Kenmore 20.3 cu. ft. / 575 liter Upright...
Alarm Flashing Red & Bleeping
Did the RCD tripping have anything to do with the freezer? You could have a faulty defrost heater, which means the freezer will not defrost at all.
May 26, 2007 | Whirlpool 21.6 cu. ft. / 612 liter Chest...
Refrigerators Logo
826 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
