All other windows work. How do I trouble shoot if it's the switch or the motor? Are there more than one window motors? Where are they located?
Are there multiple power window fuses?
Yea , could be a couple thing's , the motor , window regulator , no B+ voltage to switch or window motor ! Videos on youtube trouble shooting power windows . Watch videos on basic automotive electrical testing , how to use a DVOM - digital volt ohm meter , how to read a wiring diagram . You can find a free wiring diagram at http://www.bbbind.com/free_tsb.html c
Do you know how to do electrical troubling shooting > Do you know how to read a wiring diagram , do you own a DVOM - digital volt ohm meter , do you know how to use a DVOM ? Go on you tube an check out some videos on automotive basic electrical trouble shooting , how to read a wiring diagram . Also check out video on power window trouble shooting .Then go here for a free wiring diagram . http://www.bbbind.com/free_tsb.html We test not guess .
Did you check power an grounds at the driver door switch ? Before changing the switch ? How about fuse's ? You could go to you tube an check out videos on power windows an door lock trouble shooting . Basic electrical trouble shooting etc.... Go to www.bbbind.com/ for free wiring diagrams to trouble shoot the circuits .
Remove the door panel, and disconnect the plug for the window motor. Using a test light, see if you are getting power to the plug while operating the switch. If you are, I'd replace the window motor. Being that neither the master switch and the switch on the actual door aren't working, its a pretty safe bet that its the motor.
I'd try to see if I could hear the window motor working.
Otherwise, I'd remove the door panel and take a voltage reading at the window motor.
If ya have voltage, then we're looking at a window motor or a window regulator.
first check fuses and relays
next check window switch
then make sure your getting power to motor on window winder if you are then more than likely motor faulty or could be just jammed in some way
