Question about Sony Cyber-Shot DSC-S40 Digital Camera
Digital camara can you switch pictures that are on your internal memoery to your memoery card so you can put them on the computer
    Genius:
  • 2,985 Answers
Yes. Check the Manual for your camera or scroll the menus.
Posted on Sep 09, 2008
There is no sd card inn my camara but it reads write protect and cant take any pictures
As long as you don't put in any memory card, where the camera can put its pictures, it will say write protected.
If you did put in a memory card the wrong way around you also can have damaged the little switch in the memory card holder, so it always thinks the switch is engaged. Please put in a correct card, with the lock switch up. Not pointing to the lock position and check if that will work.
Oct 12, 2014 | Olympus SP800UZ Digital Camera
CARD FULL with 3 pictures
Have you tryed eraseing / formating it in the 740?
Make sure the camara uses the card instead of internal memory
it might be that its saveing the images into the cameras internal memory witch is probably just about 3-4 shots.
Mar 09, 2008 | Olympus Stylus 740 Digital Camera
Mi camara digital kodak c195 dice internal memory is full
The internal memory is very small and will only take a few pictures. Just enough to test the camera. Your camera also accepts SD and SDHC cards, which are not expensive. You can put lots of pictures on the SD or SDHC cards.
You also could connect the camera to a PC or MAC and send the pictures over after you installed Kodak Picture easy share.
After you backed up the pictures that way, you can delete the pictures in the camera. Always make sure you have at least 2 backups from your pictures.
May 02, 2014 | Kodak Easyshare C182 12MP Digital Camera
Download photo from camara
First use the Copy command as described on page 64 of the manual at http://www.general-imaging.com/uploadedFiles/40_Support/User_Manuals/J1456W/j1456w-usermanual-eng.pdf to copy the pictures from the camera's internal memory to a memory card. Then take the memory card from the camera and put it into a card reader attached to your computer. Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa ( http://picasa.google.com ).
May 19, 2013 | GE Smart Series J1456W 141 Megapixel...
Hi everyone, I just bought my camara last night and added a memory card. The camara now is saying that the internal memory is full, and I have only taken 1 picture? I'm hoping you can help me, please?...
You need to get that one pic out of the internal memory. Here's how...remove your memory card. Go into the menu and find "format"...follow the on-screen instructions to erase the internal memory. Then, insert your memory card and do the "format" thing again to erase and initialize the card. Everything should work properly now.
Apr 18, 2010 | Kodak EASYSHARE M340 Digital Camera
I cant get my pictures off the camara.
I would take the memory card out of the camera and plug it into your computer and see if you can download them to your pc without using the camera at all... If the pix are really important take the sd card to a photo shop and have them burn the photos to a cd... hope this helps
Jan 20, 2010 | Kodak EASYSHARE Z1485 IS Digital Camera
I forgot my memory card at home this morning. I know that my camara has internal memory so i took some pictures. I am now at home and need to trasfer my pictures from the internal memory to an external...
Plug in the USB transfer cable (to the camera), other end into your computer. The computer should recognize the picts and start the download.
After it is complete, you can now insert the external memory device (either into the computer (if it takes them) or into the camera.)
**If you plugged into the computer - you can drag and drop the picts from the folder on the PC to the memory card (the computer thinks that it is an external hard drive).
**If you place the card into the camera, connect the usb cable between the camera and the PC. Now, you can drag and drop the picts from the folder on the PC to the camera memory card (the computer thinks that it is an external hard drive).
That is all there is to it.... because the PC thinks that the memory card is an external hard drive, you can move stuff to/from it just like any hard drive. Neat, huh!!!
Oct 15, 2009 | Sony Cyber-shot DSC-S750 Digital Camera
My digital camara will not save pictures. Messages appear.
If you are using SD memory card, it can be locked. Take out your memory card, on the left side there's a switch. Turn switch up and try again. Hope this will work.
Aug 09, 2009 | Cameras
How to transfer pictures from camera to memoery card on kodak easy Z712IS
Excuse me but is your camara Kodak Easy Share C643 or kodak easy Z712IS ?
I need this information to better assist you.
thank you
May 10, 2009 | Kodak EasyShare C643 Digital Camera
Olympus SP-320 memory full when 1GB xD picure card in camara
If you download the photos that are on the internal memory to your computer, the next time you take photos it should go to the memory card that is loaded. It worked for me, so I hope that helps
Mar 23, 2008 | Olympus SP-320 Digital Camera
Sony Cyber-Shot DSC-S40 Digital Camera Logo
18 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
