Question about Aiwa Audio Players & Recorders
Hellow Sir: I bought Aiwa XR-MS3, now the piece has a problem. It can recognisze some CDs, and some CD it can't recognize. thank you very much Yong
    President:
  • 624 Answers
First you need to clean the disc's that it will not play. If a disc has a fingerprint or scratch on it in the area of the disc that is at the inner-most part of the disc where data is at, most CD players will not play the disc at all. Some will, but most will not. That area is the part of the disc that is called the TOC, it stands for "table of contents" and if that part can not be read, the disc can not be played. It has all the information there about everything that is on the disc. If the player can't read it, then the player has no way to find anything on the disc.
Try using windex and a soft cloth, like a bath towel or something soft that won't scratch the disc. This method works better than anything else you can buy for cleaning disc's and it is much cheaper.
If cleaning the disc's doesn't help you should try cleaning the laser pick-up lens. many retail outlets like Best Buy sell a disc that you can put in the unit and run it for about 20 to 30 seconds and it will clean the lens. It doesn't work great, but it will clean it a little. If you are able to see the laser pick-up and get to it with a Q-tip, you could try cleaning it with the Q-tip. Put a very small amount of windex or even isoprophl alcohol on the Q-tip and then very lightly rub it on the laser lens. Don't use a lot, just enough to get the Q-tip moist, and that will clean the lens better than anything else. It is the way professional technicians clean them. I have been repairing audio equipment for over 18 years and have lots of experience with these type of units.
If cleaning the lens doesn't help, you have a weak laser pick-up that would need to be replaced. If it is under warranty, take it in to an authorized Aiwa service center along with your receipt and they will fix it for free. This unit should have a 1 year warranty and as long as you have a proof of purchase they will fix it. You do not need to have registered your purchase when you bought it, many people think that it is required, but it is not. All you need is the receipt, which if you no longer have can sometimes be given to you by the retail outlet you bought it from. Many retail outlets have that information stored in the computer systems. Or you could check your credit card statements, if you used a credit card, and that is often accepted as proof of purchase. I have even seen some people who have contacted the manufacturer thru the customer service number and get a letter from them authorizing a one-time repair under warranty. You know that old saying, "The squeeky wheel get the grease". Sometimes it helps to call and complain, or just explain that you lost your receipt. If the unit is one that has been in stores being sold within the last year, many times they will allow for a free repair.
I hope this helps you with your problem, and if so a rating of "FixYa!" would be appropiate and very much appreciated, after all, it is the only reward we get for offering people like yourself free support for your problems.
Thanks, and let me know if I can be of any further help.
Dave
Posted on Sep 07, 2008
The player says there is no cd in the slot but i know that there is because i put it in any ideas on how to get it out?
you should see: a tiny hole on the front of the cd tray; straighten a paperclip and, push the straightened wire into the hole: the tray will pop out. then clean the player's laser with a cd cleaning kit.
Jun 29, 2011 | Aiwa XR-MS3 Shelf System
Where can I get an Aiwa XR-H66MD service manual for free online. Many thanks, Chris
Hello c bull1962:
"CLICK HERE"
If this helped just click the thumbs up.
Your FixYa team member, Peter N.
Mar 25, 2011 | Aiwa XR-H66MD CD Shelf System
I have an Aiwa XR-MN5 that displays ROLL ERR 0. It won't eject or load CDs. But I can hear a motor inside making noise for a while before the error message displays.
hello
there is a belt inside which has to be replaced with a new one. it dont cost much but disassembling needs a bit braveness...
please feel free to contact me under your topic for further assistance.
regards
Feb 10, 2011 | Aiwa XR-MS5 CD Shelf System
I cannot get the AM radio stations to play or the CDs to play on the AIWA XR-M10. FM stations come in fine.
as for the am radio you need to connect the am aerial to pick up am frequencies as for the cd player need a bit more info on that
Oct 14, 2010 | Aiwa XR-M10 Shelf System
The CD player won't recognize CD's.
Most of those CDs they sell are just a gimmick, nothing can replace a good hand cleaning with a cue-tip done by taking the whole thing apart. Take it to the local technician to get it cleaned properly first and foremost, or do it yourself if you feel safe enough taking all this apart and cleaning a tiny fragile little lens with a cue-tip and windex yourself. If a good hand cleaning like that does not work, then it means the reader head itself is defective and need to be replaced. If this is the case, don't bother. A cheap head will go for around 200$ usually and sometimes more, and at the price you get a new complete system it will be better buying a whole new sound system.
Jul 07, 2009 | Aiwa Audio Players & Recorders
Aiwa xr-ms5 cd recognition problem
If your player won't recognize a disc, make sure the CD is properly loaded and not scratched, and that the lens is clean. Clean the lens. Use only a special CD lens cleaner and follow the instructions carefully. Check the traverse assembly (the metal rod that the laser travels along and the gear that drives it) if CDs aren't recognized or won't play, frequent skipping occurs at random, CDs randomly get stuck in one spot, the player can't find tracks correctly, or cleaning the lens doesn't work. Dust and lint may be interrupting its function. good luck :-)
Jan 06, 2006 | Aiwa XR-MS5 CD Shelf System
80 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
