Question about RCA RT2380 Home Theater System System
Unit won't allow me to change modes
I have an RT 2380 Home Theater System. Once the power is on (red light on the power button is on), I try to turn on any mode (tuner, dvd, etc.), the power turns off (red power light goes off), and I can get nothing to happen in any mode. I cannot turn the system on again unless I reset the unit by unplugging it and plugging it back in, however, the same problem will occur again when I pick a mode.
  • rdkat Apr 05, 2008
    similar problem. Eventually get it to turn on, but only volume control on unit works. Can not get remote to make any changes. When I try to turn it on w/remote, system goes dead with a loud click. Factory reset does nothing.
    Novelist:
    Scholar:
  • 128 Answers
If you're NOT still under warrantee you should at least open the reciever and look for a blown fuse near where the power cable enters the set. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the receiver to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your reciever serviced.
Posted on Jan 19, 2006
Only red standby light comes on,Hit power button on remote, light goes out,unit turns off and have to replug into wall to get red light on.
There would be some problem in the output amplifier stage. Thats why its going to protection mode.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Jun 18, 2016 | Audio Players & Recorders
Button standby
The receiver is in protect mode, most likely due to a damaged amplifier. This protect mode, keeps the unit from turning on and causing further damage to itself and/or your speaker system. For more information, please visit my website at audioserviceclinic.com. Thank you.
Jul 27, 2013 | LG Lsb316 Sound Bar With Wireless...
Subwoofer pops when first powered on
If the cable is really old try getting a new one. I would recommend either a monoprice cable or a mediabridge cable both are as high quality and much cheaper than a monster.
Feb 07, 2013 | Denon DHT591BA 5.1 Home Theater System...
I have a RCA DVD Home theater system and I plug it in and the blue standby light comes on, but when I push it or other buttons on the unit, it just powers off and then won't turn turn back on at all....
I am having the same problem...i plug it in the standby light xomes on but i press the power button and nothing happens...mine is a rca rtd315wr model
Sep 03, 2011 | RCA RT2360 System
Stanby light flashes red. System will not turn on. Trouble shooting does not work
Have you tried unplugging the power supply cable. Wait a couple of minutes then plug it back in. See what happens.
Or HOLD steady the standby button for a couple of seconds and release it once you see the color change to blue. Hope it works.
Jun 24, 2010 | Philips HTS6515D Theater System
I have a HTS3410D Home Theater system. I cannot
a blinking or pulsing power light usualy means a problem with the power supply. Check for burned resistors or swallen capacitors on the power board it will be the one with the one with the main power running to it.
Nov 17, 2009 | Philips HTS3410D/37 700W DVD Home Theater...
How do you reset the system (RT 2500 )
unplug and hold the power button while turning unit on. it will start back in demo mode.
Jun 19, 2009 | RCA RT2500 System
Sony DAV-C770 Red Light Flashing but nothing is on!
power supply or power amplifire unit problem.give it to repair proffesional.
nuwan.
Jan 19, 2009 | Sony DAV-C770 System
Panasonic SC-HT75 Home Theater system
with the unit switched on press and hold the stop button and press the power button once. if that doesn't work then try it with the play button.
Mar 31, 2008 | Panasonic SC-HT75 System
Power cord for a rt 2500
Sandworms, that is the exact problem I had after a power out. It doesn't look the same as ducast's problem though. I posted the same solution in another thread. Here's hoping it works for you too.
When the red LED on the power button would glow, but it wouldn't turn on. Try unplugging it and plugging it back in repeatedly and it will eventually turn on. If that doesn't work try moving it to another outlet then try plugging it back in and out.
Oct 29, 2007 | RCA RT2500 System
107 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
