Question about Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D
DRIP PAN Our refrigerator door was not closed good. All the meat in the freezer thawed out. How do we remove the drip pan so we can clean it out. There is a terrible odor from the dried blood from the meat.
  • rachjohn Oct 06, 2008
    FFU2065WO freezer
    Was out without power for 2 weeks. Cleaned the freezer out but didn't see the drip pan. Since power came on, the stench has been terrrible. Can't stand it any longer and so the freezer is put out on the covered patio and plugged and running empty with baking soda, and kitty litter in it. I've cleaned the drip pan pout since then. Poured bleach in the drip pan. Cleaned the freezer insides with Lysol. What else can I do? It's been 9 days and I don't smell any improvement.
    Rachel
  • 76 Answers
Can you provide me with the make and model of your fridge plz so we can start to fix this problem for you.
Thank you.
Wouter.
Posted on Sep 13, 2008
Does this fridge have a drip pan
All fridges have a drip pan. Pull your fridge away from the wall, pull the lower cover off, and you will be able to locate it with a flashlight
Aug 04, 2016 | Igloo Cooler Igloo - 10.0 Cu. Ft....
How does one clean inside of freezer which had spoiled meat?
Hello Norm;
My name is peter. I am a retired field service refrigeration technician.
Plastic liners hold odor.
1.) Scrub down the liner with vinegar and water. Place baking soda on the shelves and close the door.
2.) There are special air fresheners for freezers to prevent odor. Sears carries them for about $12.00.
Mar 22, 2015 | Freezers
How do i replace the cracked drip pan in the french door refigerator
  • Unplug the refrigerator from the power source and remove the decorative vent cover at the bottom of the fridge under the door. Some vent covers are screwed on but many just snap onto clip that hold them in place.
  • Pull gently on the exposed front edge of the drip pan and ease it out towards you. The drip pan slides on runners on each side of the bottom of the refrigerator. It may be full of liquid or debris so go slow and steady and then discard it.
  • Line up the new drip pan with the two side guides beneath the refrigerator and slide into place. Use the flashlight if to make sure the drip pan is in the groove on each side.
  • Clean and replace the vent cover by clipping or screwing it into place. Plug the refrigerator back into the power outlet
  • Dec 15, 2013 | Freezers
    I have a 17 cu ft. frost free freezer, Model F17WCE and I believe the tube is clogged. I thought if I found the plastic tube, I would wash it out. I saw the tube from the front of freezer, while lying on...
    Usually you can access a service panel to where the fan and evaporation department is.
    I don't know about a wood but I did work on an upright not long a go and took some pics.
    See the drain hole below the fan on the floor there?
    Thats what ya gotta clear. I use a shop vac myself but I let the freezer thaw all the way out , you could use a hair dryer to melt the ice.
    Aug 13, 2011 | Woods Upright Freezer V1613RW3
    How do I remove the drain pan to clean it. My freezer is frost free frigidaire upright. The defrost timer went out and some of the food defrosted and drained into the pan and on the floor. There is some...
    On older freezers/refrigerators the drip pan could easily be removed. On newer models its now part of the base frame and their is no way to remove it. Dam shame if ya ask me since it was recommended noraml to remove and clean drain pan every couple months, but hey ain't modern technology great hehehehe
    Gene
    Aug 01, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
    I had some meat go bad in my freezer. I've cleaned and cleaned with hot water, dish soap, bleach, vanilla extract, oxyclean, and just now tried vinegar, next I will try squeezing lemon and/or placing...
    just spray it with 75/25 bleach/water it will kill any germs/smells....
    also syringe the drain hole with bleach.(you only needed to wash out with clorine bleach and let it dry to totally clean the unit....)
    Jul 30, 2010 | Maytag 15 cu. ft. / 425 liter Upright...
    Have a 17 cu ft upright manual defrost freezer. Started to notice that items in door were soft a week ago. Warning light was on but the rest seemed ok. Today noticed a puddle from thawed meat. Sounds like...
    Good day,
    Serious problem. Either there is a freon leak or a restriction inside the tubing that carries the refrigerant.
    Needs the attention of a pro.
    Note. If the unit is under 5 years, leave it alone. It is still under factory warranty. Call for warranty service.
    May 12, 2010 | Freezers
    Need to empty drip pan. How do you remove the
    The standard procedure is to remove the plastic grill at the bottom of the front of the freezer and then slide the pan out for cleaning and emptying. Might as well vacuum dust out while your at it. Helps the compressor operate at a cooler temperature.
    Please rate this answer for me. Thank you.
    Mar 26, 2010 | Kenmore 20.3 cu. ft. / 575 liter Upright...
    Woods freezer has thawed twice in the last year.
    HI, you will need to inspect the compressor to make sure it is cycling in intervals. if the compressor is not cycling, this will confirm compressor failure. The evaporator fan blows cold air into the freezer and from there it vents into the refrigerator. Occasionally the vents between the freezer and refrigerator can become clogged with ice, food or other debris. In most refrigerators the cold control for the refrigerator opens and closes these vents. That mechanism may become inoperative resulting in the vents becoming stuck open or closed.
    Inspect the vents to determine what is preventing the free flow of air. An overcrowded refrigerator or freezer may be the cause. In other cases the vents may need to be cleaned or ice melted away. To remove a build up of ice, use a hair dryer set to "low". Using a higher setting may damage the freezer. WARNING: Do not let melting ice drip onto the hair dryer. In some models, the vent is located under the temperature control console. The housing either snaps into place or is held in place with screws. Remove the screws, or gently depress the retaining clips with a small screwdriver. Allow the housing to hang by its wiring. A freezer vent control may also have to be removed to access the vent. In some freezer-on-top models, it may be necessary to remove the floor of the freezer to inspect for obstructions.
    The condenser coils dissipate heat. If dust and debris accumulate around the coils, your refrigerator may not be able to cool properly, it may run continuously or it may stop completely as a result of an overheated compressor. You should clean rear-mounted coils once a year. Unplug the refrigerator before cleaning. Refrigerators are heavy, never tip one forward or backward. Never attempt to move a refrigerator without an assistant. Vacuum or brush the coils. If coils have a filmy build-up, use warm soapy water to clean them. Take care not to spill or drip water onto the components of the refrigerator.You should clean floor level coils at least twice a year. Unplug the refrigerator before cleaning. Vacuum or brush the coils. Remove the grill from the front of the refrigerator and use a vacuum with a wand attachment to remove any dust and debris. The grill should snap off and on. Pull firmly toward you and possibly upward to remove the grill. If it does not come off with a modest effort, check for screws or retaining clips that may hold it in place.
    Another inspection point will be the door seals. This is a easy way for the cold air to escape from your unit as well. this will cause the temperature to rise. The seal should make smooth continuous contact with the refrigerator case. When the seal does not seal completely, warm air enters the appliance. This results in more frequently compressor operation and possibly the inability of the appliance to maintain proper temperature. To test the seal, use the dollar bill test. Place a a dollar bill or a piece of paper between the seal and the refrigerator and close the door. Now pull the paper out. You should feel tension as you pull. Retest along the entire door seal. Replace the seal if the test was unsuccessful.
    Next will be the door switch. The interior light in most refrigerators, and the fan in some, are controlled by a door switch. When the door is closed, the switch is depressed and the interior light goes off and the fan resumes normal operation. If the door is misaligned or the switch malfunctions, the refrigerator may become warm as a result of the non-operation of the evaporator fan and the heat generated by the interior light. Test the switch for continuity using a multimeter. Set the multimeter to the ohms setting X1. Place a probe on each terminal. The multimeter should change from a reading of infinity to zero when the probes touch the terminals. With the probes still touching the terminals depress the switch, the reading should change back to infinity. If it does not pass both of these tests, the switch should be replaced.
    Be sure to confirm evaporator fan function as well. if the fan is defective, it will prevent proper cooling as well.
    This will conclude the most common issue with a under preforming unit. I would advise to check all the above and, if the unit continues to not cool after all the above adjustments are made, i will recommend replacing the cold control device,thermostat and main circuit board.
    Concerning the defrost switch:
    To test whether the defrost timer is simply failing to advance, locate the advance screw and turn it clockwise until you hear it click. This advances it to the next mode. If it was cooling before, it is now in defrost mode. Simply wait about 35 minutes and check whether it has left defrost mode and has resumed cooling (listen for the compressor). If it does not advance, the timer motor is probably bad and the entire timer needs to be replaced.
    Dec 24, 2009 | Woods Freezers
    Open Questions:
    See all Frigidaire 13.7 cu. ft. / 388 liter Upright Questions
    Frigidaire 13.7 cu. ft. / 388 liter Upright Freezer AFFU1466D Logo
    505 people viewed this question
    Top Frigidaire Freezers Experts
    Charles T Nevin
    Charles T Nevin
    Dan Webster
    Dan Webster
    John Tripp
    John Tripp
    Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
