Question about GE WBVH6240F Front Load Washer
Washer keeps pausing
My first frontloader worked like a charm for the first four months - now it keeps pausing itself at times during the cycle. It is usually in the WASH cycle when it does it and it sits there and hums like it is doing something. I have went through all the troubleshooting tips and nothing works. Mine is a GE WBVH6240HWW.
  • 1 more comment
  • slme Sep 22, 2008
    Mine does the same thing. Happened before and the repair guy said the computer board was fried. Had to replace it which cost a fortune. Now, just a few months later, it's doing the same thing. So, I'm wondering if the removal of debris solved your problem so I don't have to call the repair people again.
    Thanks!
  • bigb0612 Nov 29, 2008
    IT KEEPS PAUSING AND IT DOESNT FILL UP WITH WATER
  • longamanda Dec 08, 2008
    My washer started pausing in the middle of washing cycle and also would not drain or spin extra water out of the clothes once the cycle was complete. Now it will not even finish a cycle without pausing every 5-10 minutes. The timer continues to count down but it isn't washing the clothes.
  • 725 Answers
You may have something in your drain pump.
1) Remove the three screws in the bottom remove bottom panel.
2) Remove drain pump cover (have towels or pan to catch water that comes out)
3) Remove any debris from pump, check that the impeller is not damaged and can be moved freely.
4) reinstall drain pump cover and bottom panel
Let me know if it helps
Posted on Sep 07, 2008
My washer keeps pausing during the cycle
Hi claire64 - Usually when "PAU" displays on the screens, it indicates that the unit thinks that the door is not securely latch when you started the cycle, or the cycle has been interrupted. Try pressing "PAUSE/CANCEL" or "START/PAUSE" once to resume washer. If proves to be ineffective, try reprogramming the unit by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes, restart unit and resume cycle. If fault reoccurs, then it typically means that the unit either has a faulty door latch assembly or a communication error from the control board. Since there are cost differences in parts, it is always a good idea to have a service tech properly diagnose your appliance.
Mar 03, 2013 | Frigidaire Affinity ATF7000E Front Load...
My front load washer keeps pausing and stopping many times during a wash. i have to hit pause/start to restart it but i did not push pause to stop it it does it on its own
There is an access panel on the back of the unit. 6 screws and on the bottom is a rubber hose that comes from the tub. inside that rubber hose is a filter cup. i have the same unit and mine did the same thing. took it out pulled clog out put it back together. works like a charm. hard to get at but you can do it. use a drill with a Phillips head to make it quicker. Also have pliers and a pair of channel locks on hand.
Nov 05, 2012 | Frigidaire Affinity ATF7000E Front Load...
My GE Washer continues to keep pausing during the wash cycle. After we push the button to restart it pauses again after 5 to 6 minutes and continues this throught out the entire wash cycle. We also went...
Please, check to insure that your washer is properly grounded. If you do not know what that means, call an electrician. Modern wash machines are controlled by circuit boards that operate on low voltage and are vulnerable to static electricity. Spikes or gaps in the electrical service from your power company could also be the problem. Your electrician should be able to help you with that as well.
Oct 05, 2017 | GE WSXH208A Front Load Washer
Frigidaire front loading washer keeps pausing during sanitize cycle
Sounds like the unit might be sudsing up too much or something is not allowing the sensors to operate and advance to the next cycle. Contact your purchasing dealer and have them come out since it is so new and under warranty.
Jul 30, 2012 | Frigidaire Affinity FAFW3577K Washer
My maytag clothes washer Bravo quiet series 300, keeps flashing a Sd error code. Or it may be 5d
What does the Sd code mean?
This code indicates that excessive detergent suds occurred during the cycle. The washer will not be able to spin out water with the excess suds. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the wash action and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This process is necessary and may occur several times to eliminate the suds.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations.
Use only HE High Efficiency detergent for BravosTM washers.
Is "Sd" displayed and the wash cycle dial is flashing?
This indicates the washer was not able to clear all the excess suds from the washer. Re-select your desired cycle using cold water. Press Start/Pause. Do not add detergent.
Is "Sd" displayed and the wash cycle dial is not flashing?
If "Sd" is displayed and the wash cycle dial is not flashing, allow the machine to continue running, even if it appears that nothing is happening. When "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the wash action will pause to allow the bubbles in the suds to break, and the washer will add water for better rinsing. This rinsing process is necessary and may occur several times to eliminate the suds.
Is the drain hose kinked or clogged?
Make sure that the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose.
To remove the error display, press Power/Cancel or Pause/Cancel once.
If Power/Cancel or Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start/Pause.
NOTE: If the error remains on the display, and all of the other questions above have been checked, call for service.
Dec 27, 2010 | Maytag Bravos 3.8 Cu. Ft. Washer
Affinity Washing Machine, 3 months old, pauses during cycle. Does not give any error code. Have tried different cycles, eventually it will run the cycle. Doesn't happen with every cycle, yet. Switches...
Did you figure out this problem? I think these machines are JUNK! We purchased our first Frigidaire Affinity in April 2010 & by September it started ripping our clothes apart. Not every cycle. At first we thought it was the dryer but nope - it was the washer. Something to do with the drum. We had it replaced in October 2010. Then after the truck dropped off the replacement, I tried doing my first load of laundry. It lite up & did nothing. Something to do with the motor. Again, we had a 3rd machine replacement. I wanted to give up, get my money back & go buy something else but I wanted it to match my dryer so I was kinda stuck. Our 3rd machine is now going to pause constantly during a cycle. I've read up on it & tried various things such as less soap, checking the drain etc. & nothing has changed this problem. I'm calling the store on Monday & demanding my money back & they can take back the dryer too. I have a feeling this might be a bit of a fight but I am disappointed with the results of this machine. We've lost about $100+ in clothing from the first machine, plus all the down time in all 3 of these machines not working & having to worry about going to do laundry elsewhere.
Sep 11, 2010 | Frigidaire Affinity ATF7000E Front Load...
During wash cycle the washer stops at 11 or 12 minutes left and screen reads F . i have a frontload whirlpool duet HT
Just F on its own?
Try to clear it doing the following:
Select PAUSE/CANCEL twice to cancel the cycle. Select
DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and select HOLD TO START. If the problem
remains, call for service.
Hope this helps comment back if you need further help,
Jul 06, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Keep stopping pausing
If you leave the machine to itself, will it go through the whole wash satisfactorily? If it does, then the start and stop is designed into it. What it is doing is stopping and reversing the washing action. That is so the clothes will not wind up in a long rope shape, like the winding up of a towel like you use to do to a towel to snap your bother or sister in the showers or at the pool. It UNWINDS the load... It goes a few turns one way, then pauses, then a few turns the other way and pauses. Hope this helps..... 2529817.gif
Nov 27, 2009 | Frigidaire ATF6000ES Front Load Washer
Washer pauses at various times during the cycle
Did you find a solution? Mine just started doing the same thing.
Jan 30, 2009 | GE WWSE5200B Top Load Washer
Spin Cycle doesn't work on our GE Energy Star frontloader, please help
You may have to remove the lower panel and clean the drain pump filter. Easy job, once the panel is removed the filter will be right in front. Get a bucket and unscrew the filter cover (3 very small screws at the bottom of the front panel) and you should find a ton of lint and stuff in there. This model has a pressure switch that detects if there is water in the tub. If so it will do this pause and slow spin. Once the pump filter is clean you should be good again. It worked for me.
Apr 08, 2008 | GE Energy Star WCVH6260F Front Load Washer
GE WBVH6240F Front Load Washer Logo
470 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
