Question about KLH R5100 Receiver
No audio output
What is the mfg code for the audio output amplifiers IC chip
    Genius:
  • KLH Master
  • 1,550 Answers
Check the numbers of the parst attached on aluminum heat sinker.
Posted on Sep 13, 2008
Audio output only out of one output
hello sir,
often this is sound IC fault, if one IC there change it and it will fix the other audio output, as the sound IC have two outputs and one of it doesn't output the audio,
if two sound IC's, it's a must one of it is faulty, you better change both for long run of the audio amplifier
good luck
Oct 18, 2015 | Car Audio & Video
Is audio output (from main ic) is imputed in utc2003 audio amplifier ic?
Is the UTC2003 IC your main IC?
You can't find inputs or output of this IC?
This IC is power Operational Amplifier simply. It has TWO inputs noninverted = pin 1 and inverted = pin 2 and ONE output = pin 4. Pin 3 is ground and pin 5 is supply voltage. It's simple as the rake! What is your problem? Sorry for my rusty English...
Feb 03, 2015 | Audio Players & Recorders
No audio output. muffled output from Phones jack
you need to check the power supply of the amplifier with the help of a voltmeter. if that is OK the power amplifier IC(integrated circuit) is gone bad, see for overheating of IC.
Sep 26, 2011 | Roland Ac60 Acoustic Chorus Guitar...
How to connect an amplifier to a dvd player..this is my dvd player model number--sony- mhc-gnz77d..
Connect to unnamed amplifier and for audio or audio AND video??? Hmm. Find its manual.
The mhc-gnz77d is a mini theater system, not just a DVD player.
http://audio.manualsonline.com/manuals/mfg/sony/mhcgn999d_mhcgn999ds_mhcgnz88d_mhcgnz77d_mhcgnz55d.html
Page 83 - digital output is the only audio output.
Sep 04, 2011 | Sony Audio Players & Recorders
F61 will not come on
F61 is an error code that shows amplifier output chip is defective and need to be replaced in Panasonic SC-AK640 unit.
Amplifier output chip replacement requires soldering work and local repair shop will do this job as it is not user level repair.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Feb 10, 2011 | Panasonic SC-AK640 Shelf System
Audio Receiver Input Selector
i , too, i working with Amplier sony TA-V715
Apr 03, 2009 | Sony Audio Players & Recorders
Power Protect still comes on now and again
Amplifier output chip in stereo is defective and unit gives error message of push power protect.
You need to replace output amplifier IC and check supplied voltages.
Feb 28, 2009 | Sony MHC-RXD5 Shelf System
Power On + red LED turns on + but final relay (click) don't come so no sound
Your audio output transistors are shorted and your unit is staying in "protect " mode to protect your speakers from 40 to 60 volts that is being sent at them from the shorted outputs. If you can use a meter you won't need the schematic MOST likely because the outputs are USUALLY the only parts that short out. The output transistors( or chip ) are mounted to the large, finned heatsink. The #'s on the transistors start with "2SA-" and "2SC-" followed by numbers. There are two output transistors per channel. If your unit uses an IC for audio output then the # on the IC will be "STK-" followed by numbers. These parts are available from tritronicsinc.com. Good Luck!
barneyluc
Oct 17, 2008 | Denon PMA-2000R 2-Channel Amplifier
Set dead
That code always be for audio amplifier IC damaged.Change it
Jul 09, 2008 | Panasonic Home Theater System System
KLH R5100 Receiver Logo
Top KLH Audio Players & Recorders Experts
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a KLH Audio Player and Recorder Expert? Answer questions, earn points and help others
