Question about RCA P52928 52" Rear Projection Television
Video and Sound Going Out
All of a sudden, with the coax input, the picture has snow, the sounds has lots of static. Through Input 1 and Input 2 all is OK.
    Novelist:
    Scholar:
  • 128 Answers
Your problem could be the cable: A. A weak signal coming from the cable company B. A bad cable or connector within the house. For the above, call the cable company and ask them to check the signal levels on your block. And, remove the plate where the cable comes out of the wall and look for shorted or bad wiring that may cause a weak signal. Also, if you have another set in the house, connect it to the same cable outlet to see if it has similar audio blackouts. Your problem could be the tv set itself, as well. C. Go into the on-screen-display and make sure you are on stereo audio and NOT SAP. SAP settings are not to be used unless you are using the second language or audio program feature. D. The sound detector inside the set could be defective. Which would require service. So, the first thing to do is to determine exactly where the fault lies; inside the set or outside the set. Then attack the problem at hand. If the set is defective internally, I think you will need a tv tech who can diagnose the problem; it must be tested and measured to find out the exact part (this set has over 3,000 compnent parts inside).
Posted on Jan 19, 2006
No video or audio from HDMI inputs, (DirecTV and Xbox), rca aux input or Component input. Over-the-air HDTV from the Antenna is perfect audio & video
HDMI Input Problems - TV Not Showing Image - TV Repair ...
? 2:34
https://www.youtube.com/watch?v=ZtaUPX1tHP0
May 26, 2015 - Uploaded by ShopJimmy.com
Basic troubleshooting and replacement tips for HDMI inputs that are not ... video or audio from your HDMI port, you can take the source video ...
no signal? -hdmi - LG 55LE5400 tv - Forums - CNET
www.cnet.com > Forums > LG
CNETJun 14, 2014 - Sunday my husband hooked up an RCA ANT571 antenna with great results. ... The Roku first showed no signal on the TV. I tried hooking the Roku up to other HDMI ports, i changed the hdmi cables, .... Sound comes through, but not picture. ..... Video; All Video · Apple Byte · Carfection · CNET Top 5 · CNET ...
No sound on LCD TV - Desktop HDMI connection [Solved] - CCM
ccm.net > Forum > Hardware
Oct 11, 2012 - The video is excellent, but there is no sound coming out of my TVspeakers. ..... I also tried inputs besides the "HDMI 1" input and the other RCA ...
HDMI vs Component ' TVBlanket
Feb 03, 2016 | RCA Televison & Video
6MTH OLD HOTPOINT PLASMA TV SUDDENLY HAS NO PICTURE NO SOUND
Hiya!
Sounds like it's on the wrong input, maybe it's analog tuner. Have you tried changing it's input?
Feb 21, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Had sound no picture isn't cable box I unhooked
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Oct 05, 2014 | Televison & Video
No sound on coax audio input from HDTV
Check your settings on your tv. You may have to turn off the internal tv speakers in the setup menu in order to get any audio output from the jacks on the back.
Dec 20, 2012 | Sony STR-DE835 Receiver
Snow no connection to cable box
the fact that you are seeing snow tells me that your tv in in the tuner mode .. your cable box is more likely hooked up to the AV input (composit video + 2 sound channels ..3 wires total) .. or it could be hooked up to component inputs (5 wires total) ... you will have to go to the menu of the TV and choose the proper input ... if your cable box is actually connected thru the tuner (coax cable to RF input .. one cable) then you have to select the same channel on the tv as what the cable box is set to .. that is usually chan 2 or 3 ... there is also an svideo input on your tv .. that can take the place of the composit input ..
here is a diagram of the back of your set so you can determine how its hooked up ..
http://www.fixya.com/support/p169436-zenith_p42w46x_42_in_edtv_plasma/manual-6443/page-8
lots of other good information there as well
Oct 03, 2009 | Zenith P42W46X 42 in. Plasma EDTV
No sound from optical or coax digital inputs
You have to use the system setting using the remote and turn on the inputs you want to use. Hope this helps.
Keith
Oct 16, 2008 | Denon AVR-1602 Receiver
No sound
Steve make sure that the coax is connected to the output on the DVD/VCR and to the TV's cable or antenna input. This should give you picture and sound on CH 3. If you use RCA jacks you must also use the yellow video plug as well on the same input on the TV as well as on the DVD to get both picture and sound to the tv. The place yoou put the RCA's on the TV will determine where the image will be displayed e.g. if connected to VIDEO 1 on TV YOU MUST CHANGE THE TV TO THE INPUT NAMED AUDIO 1. You can do this by using the input or source button on the remote control for the tv or go into the tv's menu and perform the task that way. I hope this helps you resolve the issue. Thanks for using Fix Ya and let me know if I can be of more assistance.
Oct 15, 2008 | RCA DRC8295N DVD Recorder/VCR
Mitsubishi rear projection no picture and static sound
I assume you are using a cable input, such as a box or the main Cable line connected directly to the TV. examine the main Cable Coax, look at the copper wire that sticks out from the connecter, make sure it is long enough, if its to short, gently pull it with a long nose plier until it reaches the rim of the connector. Sometimes when connecting the coax to a source, the copper wire in the coax is to short to make contact, and as a result you get no signal. Hope this solved your problem.
Jul 03, 2008 | Mitsubishi WT-46809 46" Rear Projection...
I need set up help
Most amps these days have to told which input is being used,ie if you have the dvd into dvd video input for picture and are useing coax or optical for sound you have to go into the setup menu on the amp and find the input menu and tell the amp the dvd is on optical or coax.
hope this helps.
CABLE GUY.
Jun 27, 2008 | Pioneer VSX-D510 Receiver
Female coax connector in tv bad?
If your cable converter box has audio/video connections on the back of it,you don't need to worry about using that RF coax connector. Just hook it up the same way your DVD is hooked to the TV input jack. Get a 3-wire cable (yellow-red-white)hook it to the same colors on the back of the cable box and hook the other end to an unused input on the back of the TV. Then select that input with your remote and watch TV.
Aug 30, 2007 | Sharp 27J-S100 TV
RCA P52928 52" Rear Projection Television Logo
89 people viewed this question
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
