Question about Sony STR-D665 Receiver
Getting Surround to work
It's been a few years and trying to get the surround to work on my STR -D665 Receiver but can't remember how to hook up the cables.
My components are as follows. Sharp Aquos LCD, with an HDMI cable to the PVR. It's getting the sony DVD/VCR combo to produce the surround is where I am having trouble.
The easiest way is to hook up your DVD/VCR combo directly to the back of your Sharp LCD TV, then run a component audio output from the TV to the audio input in the back of the receiver. Make sure you hook up your front, center and rear speakers correctly to the receiver, then go through with the speaker calibration steps - per manual, then it should work with no problem. Good luck!
Marc
Posted on Apr 15, 2009
Unit will not power up, when plugged in to AC the mute -20 dB is lamp is illuminated. Is there a reset feature?
Sony consumer grade electronics are notorious for electronic component failure due to the low quality grade of their components. It's likely that the whole circuit is not receiving power. If you are handy you can search the internet for a service manual and follow the flow chart to troubleshoot the defective circuit.
Dec 22, 2013 | Sony Str-d665 Dolby Pro Logic Surround...
Surround sound hookup between my 2008 sony bravia and sony A/V surround sound receiver which is older.
the yellow on an RCA setup is a video signal not audio, so just hook up the yellow to video 1 and red /white to audio 1 or whatever number it happens to be
May 09, 2012 | Sony BRAVIA KDL-46V3000 Television
I have a sony STR-DE897 and my rear speakers dont get sound when plugged into the surround back ports..Is there a certain setting in order for the rear surround spreakers to work? or does that mean the...
There are a few things required for the rear surround channels to operate;
1. The surround back channels must be enabled in the surround setup menu.
2. The media being played through the receiver must have audio encoded for the rear surround
channels. There are only a few exceptions to this but I'll exclude the explanation for simplicity.
3. The audio level of the speaker channels must be set high enough to be audible.
Enter the surround setup menu with your remote. Use the center button on the remote to toggle through the selections, press down on it to enter the selection.
You will navigate to a selection in the surround setup menu that says "surround back" or S/B with a selectable yes or no indication. Press on the center button to enable them.
Media like DVD or Blu-ray that has 6.1 or 7.1 channel audio has separate, or often referred to as "discrete" or "matrixed" audio intended for playback through surround rear speakers, depending on the music or movie. If your media is encoded for 5.1, then there will be no audio sent to these speakers. However, with the different modes of on-board digital processing of this receiver you can still have audio through these speakers.
Last but not least is the actual playing level of these rear surround channels. They may simply be adjusted to quietly. Enter the setup menu with remote, choose "level" and navigate to the rear surround channels. You can adjust the level up or down in 1/2 dB level increments by toggling left or right with the center button. Each surround channel can and should be adjusted independently and equally.
Dec 14, 2010 | Sony STR-DE897 Receiver
Trying to hook my Wii up using the AV audio Jacks
Connect the Wii to your television. Then connect the variable audio output from the TV to the audio in on the monitor section of the receiver. Then use the TV/SAT input selection on the receiver and dolby prologic 2 as your sound mode.
Dec 23, 2009 | Sony STR-DE575 Receiver
Sound only some out of 2 speakers at a time. I need all 4.
Here you go buddy:
http://www.docs.sony.com/release/STRDE685.pdf
May 19, 2009 | Sony STR-DE685 Receiver
My surround rear spks dont work
The rear speaker decoding has to be enabled for them to function, regardless of the media. Enter the speaker setup menu and choose "yes" for the rear surround speaker decoding.
Mar 10, 2009 | Sony STR-DA3000ES Receiver
"Protect" flashing on STR-D665 Receiver
Check if you connect corectly the speakers wiresnand if they are right connected the audio amplifier Ic are damaged
Nov 28, 2008 | Sony STR-D665 Receiver
Attaching a surround sound to a Hitachi 60CX29B
the red green and blue are component video
to get the surround sound to work the red and white audio outputs from the tv go to the audio inputs on the reciever , and to get the digital surround sound the optical also has to be hooked up
Nov 06, 2008 | Hitachi 60CX29B TV
No sound from back speakers
Remember the rear speakers are called surround... Did you select surround on the unit? if it says stereo then you will only get fronts, select surround to get the rest.
Jul 13, 2008 | Sony STR-DG510 Receiver
No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Dec 06, 2006 | Sony STR-D665 Receiver
266 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
