Question about Maytag Washing Machines
Our Maytag front loader will not run a lot of cycles and come up with error message 10
    Novelist:
  • 166 Answers
Turn off the power at the soure for 10 minutes and see if it rests and then try it!
if it's a no go then you need hands on service!
bless you
Posted on Sep 07, 2008
MY MAYTAG NEPTUNE FRONT LOADER WASHER KEEPS SHUTTING OFF AND THE E3 ERROR MESSAGE IS ON THERE
Transmission or clutch assembly not engaging due to going out or slipping. even bad door switch
Sep 20, 2014 | Maytag Washing Machines
Error message SUD and F21 even after unclogging the filter
Push the pause/cancel button twice to clear your message. Then run through a rinse/spin cycle. Next try a normal load without any detergent. SUDS is usually from too much detergent. If this fails, checked the hose for kinks. Check connections and if all that fails, you will probably have to replace the pump. Good Luck!
Feb 04, 2014 | Maytag MAH6700AWW Neptune Front-Load...
Maytag 3000 washer has error message SUD. What is this and how do I fix it. It occurs in the spin cycle every time I wash. I am using Tide HE detergent. It even does it when I use Zero detergent.
The SUD message usually indicates that the sensor detected excess suds and shut down the washer until the suds subsided. To my knowledge, Zero isn't an HE approved detergent so the amount you use has to be really tiny to avoid the SUD error.
With the Tide HE, you still may be using too much detergent. However, you should check the drain pump and outlet hoses. Sometimes a slow or blocked drain can trigger the error. There is often a filter at the drain to keep foreign objects that were left in the clothes from damaging the pump. Make sure that nothing is in this "coin trap". Have a bucket ready when you take apart the drain to catch the water left in the washer. The pump is accessed through the back panel. (Some front-loaders actually have an access panel so you don't have to remove the entire back.)
If you see excessive suds during the wash cycle, run the washer through a complete cycle while it's empty without using any detergent. This often will rinse out any detergent that may have been left from previous loads.
I hope this helps.
Jul 20, 2012 | Maytag Neptune Washing Machines
Maytag front loader HE washer.
cheak your tube if there is a nail or an object is stuck in one of the holes
Jan 24, 2010 | Maytag MAH6700A Neptune High Efficiency...
Won't spin or drain, have tried to rerun cycle and checked drain hose
Check pump / outlet filter , refer to instruction book , clean and replace then re- try
Nov 01, 2009 | Maytag Neptune MAH5500B Front Load Washer
Error number 3?
From the tech manual:
Drive system is not working
correctly. Bad windings, speed
sensor, wiring connections, or
Control Board.
May 11, 2009 | Maytag EPIC MFW9700S Front Load Washer
Maytag neptune error? message
Unplug for 10 min to reboot the curcuit board. This will reset the system. Sometimes selecting numerous cycles or pushing buttons a lot in a short period of time can overwelm the little brain in the curcuit. This action will clear the memory of any unwanted comands in the curcuit.
Apr 28, 2009 | Maytag Neptune MAH5500B Front Load Washer
MAYTAG PREFORMA 2 SPEED 10 CYCLES 2004 TOP LOADER
Check your lid switch, some machines stay running when you add clothes when it agitates, but will shut off if you lift the lid in rinse and spin, lid switch may be broken.
Jul 15, 2008 | Maytag MAH6700AWW Neptune Front-Load...
F05 on Maytag MFW9700SQ1
I have had my epic front loader washer and dryers for 1 year now. I picked them after carefully researching other brands/models and reading many reviews. Epic had the most positive and satisfied reviews/ratings of all at the time.
I have a large house with 6 furnished suites and I do the laundry for all suites weekly, so there is a lot of laundry. The Epic machines have been great, even with some overloading abuse by the cleaning staff.
I did, however, just experience my first problem - the "Control locked problem"
I googled and found this excellent site - and the fix for the problem (hold "cycle end signal" button down 3 seconds). Worked like a charm...
I tend to think that all of the digital front loaders for all brands will have a problem like this once in a while, as they are fairly complex compared to the prior generation of washer/dryers.
However - your problems with your new machine sounds bad - like you may have gotten a lemon.
I bet they would send you a new replacement machine at no charge if you called Maytag... I would try that first before shopping for a different brand/model...
good luck!
Apr 14, 2008 | Maytag EPIC MFW9700S Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
