Question about RCA P52921 52" Rear Projection Television
Voice keeps going off,all I get is a buzzing sound.If I unplug the TV and plug it back in right away the voice comes back.This is happening every few minutes. I purchased my TV in 1999.
    Novelist:
  • 196 Answers
Willing to bet it's that infamous cold solder joint problem with the tuner located inline with the mainboard. Discontinue use of the set and have it checked out by a repair professional. This problem will only get worse and can cause a failure with your television's EEPROM which will keep the set from running at all.
Posted on Jan 30, 2006
My tv went black no picture , I have voice but no picture what do I do?
Hello CJ, try unplugging the cable box and the TV, then plug them back in, also unpluging the cable box from the TV, then plugging it back in. Let's hope one of these fixes it.
Bill
Oct 25, 2014 | Televison & Video
Tip
Samsung Intensity: How to avoid the voice recognition prompt
The Samsung Intensity has many nice features. It comes equipped with voice recognition software, which many people like. However, for others it is merely annoying. If you keep your phone in your pocket or purse, you might hear a muffled voice saying "Please say a command" from time to time as the phone's voice recognition button is bumped.
Fortunately, you can disable this voice prompt (if you want to) with just a few simple steps:
1. Press the voice recognition button on the upper right hand side of the phone.
2. Press the right options button to go to the Settings.
3. Select Prompts (#5).
4. Select Mode (#1).
5. Select Tones Only (the last choice).
6. Hit OK to save the change.
Now, when you accidentally bump that button, you'll just hear a short single tone, rather than the voice prompt.
If you want to reduce the volume for the voice recognition (either for the voice prompt or for the tone) that can be done easily as well. Follow the steps above to get to the Prompts menu, and select Audio playback (choice #2). Highlight the choice for Earpiece, and hit OK to save your choice.
The voice recognition function will now use the earpiece to play any sounds, rather than the speakerphone, so whether you set it for a voice prompt or a tone, the sound will be much quieter and hopefully you won't even notice it.
You can also lock the phone when you're not using it, which will disable the voice recognition button so you don't have to worry about bumping it. To lock your phone, just hold down the zero (0) key for two seconds. You'll see a message on the screen that the phone is now locked.
on Jul 09, 2010 | Samsung SCH-U450 Cell Phone
How do I get rid of the voice over on some programmes on my LG 47LF6 model tv?
It sounds like you are talking about "described video". Does your signal come through a set top box before going the TV or is the cable hooked directly with the TV? If going through a set top box first, you need to change the setting in the set top box.
Oct 06, 2014 | LG Televison & Video
I have a Phillips Fla screen and a few days ago it started making this loud buzzing/hissing sound that somewhat goes away once the TV is on but comes back with a vengeance when we turn the TV back on i...
Most likely if a buzzing or similar sound that is there even with set off--you have a noise coming from a transformer in the standby power supply which is running all the time if the set is plugged in----
Someone would have to open set and listen for it---either a part, a board, or hot glue would have to be used to mute the vibration that is making the sound----one way we locate is with cover off probe with a plastic tool to see where it is.
If you are not able to do this have a tech or a shop "look" for it.
Dec 03, 2012 | Televison & Video
I turn on my DYNEX LCD-TV model DX-L26-10A and the screen says 'Please Wait" for a few seconds and then I hear the voices for the channel, but there is no picture and there is a buzzing sound coming...
I turn on my DYNEX LCD-TV model DX-L26-10A and the screen says 'Please Wait" for a few seconds and then I hear the voices for the channel, but there is no picture and there is a buzzing sound coming from the back of the unit.
Nov 15, 2010 | Dynex 32 in. LCD Flat-Panel HDTV
Logitech 9000 recording problem
My suggestion for recording music of any sort is to disable the cam mic and use a good quality mic plugged into the sound card as the mic in a cam is more suited to voice.
Aug 24, 2009 | Logitech QuickCam® Pro 9000 Personal Web...
No sound in the Garmin GPS, tells me "no voice found"
turn the unit on off, on off, keep going to the sytem language, eventually you will be able to tutn back on the text to speach, mine does same thing, pain in tha ***.
Bill
May 27, 2009 | Garmin Nuvi 760 Car GPS Receiver
My turtle beach x1 headset has a buzzing sound coming through the headset do you know how to fix it?
Do you have your play n' charge kit plugged in? if so, then thats what is causing the buzzing sound
Dec 27, 2008 | Voyetra Turtle Beach Ear Force X1 Headset
Toshiba HD Projection TV
Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Or send to ptscorp.com
http://www.hdtvoice.com/voice/index.php?s=
good luck
please mark the post with a fixya
Feb 26, 2008 | Toshiba 50HX70 50" Rear Projection...
RCA P52921 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
Steve Allison
Steve Allison
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
