SOURCE: having problems programing rca remote
Try these codes for Emerson TV: 0463, 0236, 0019, 0180, 0280, 0179, 0154, 0177, 0178, 0038, 0185, 0282
You can find the remote control codes for different brands
of devices from
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv
If none of the codes work then we have two other solutions:
1. Searching For Your Code
If you have tried all of the set-up codes for your brand of equipment ,or your
brand is not listed, and you are still not able to get the unit to respond, try
the following procedure to search for your code.
If you don't find a code that works, the remote will flash four times when you
reach the end of all the codes for this device type.
Make sure that the remote is pointed at your device during the search, You
may have to press this sequences of buttons up to 100 times to search the
entire library of codes.
2. Learn the buttons from the original
Line up your original remote and the head-to-head before completing the
following steps.
Now you can repeat steps 3 through 5 to learn other functions onto other keys
or press and hold SETUP until the Cinema's red light flashes twice to lock in
your new feature. (If the red light does not blink twice, stop and repeat steps
through 6).
To test the new feature, press and release the device key in which the new
feature was learned followed by the key on which the feature was learned
More help for programming your remote can be found here:
http://www.hifi-remote.com/manuals/ofa-l.shtml?URC-7800#device
Hope that helps! Should you have any further questions,
please feel free to post them here.
P.S. - If you find that the solution/answer
I provided led you to, or resulted in a fix, please close the ticket with a FixYa!
rating. I would be very grateful for your show of appreciation.
Thank you for using FIXYA!
Cheers!
IrishDruid
SOURCE: RCA Universal Remote set to my Emerson TV
RCA Universal Remote Control Programming Codes
Programming Your Universal Remote.
The remote may already be set up to operate your brand of TV, VCR, or Cable Box. It is pre-programmed with following codes:
For brands that require programming, there are two ways to program: Using Code Lists or Code Search. Use Code Search if the code lists are not available or if the codes from the lists do not operate a device.
Programming a Device using Code Search:
Programming a device using the Code Lists:
Emerson CODES
011,026,027,028,029,030
031,032,037,042,053,064
065,067,075,076,079
TV Can Not Be Programmed on this remote. Sorry.
=> http://remotes.com/remotes/documents/RCA/257003.pdf
SOURCE: i need rca rcr312w universal remote durabrand tv codes
HI i have one dvd player im lose the control and i have one universal control no have a book code
and my dvd the brand is only GDS OK I NEED YOU HELP ME THANKS....
