Question about Emerson MS9700 CD Shelf System
It reads "No Disc" on all 6 settings - Emerson MS9700 CD Shelf System
    Problem Solver:
  • 7 Answers
How often was the player used? Four years is a typical lifespan of a cheap CD player section if it sees constant use. First, let's see if the player tries to read the disc. Load a disc and listen. Does the player make squealing noises or is it totally quiet? Squealing noises may indicate that the player is trying to synchronize with the disc but can't due to an obstruction on the lens or in the laser path inside the pickup or a defect in the pickup. This can also be caused by an intermittent signal problem due to a faulty ribbon cable. Totally silent means that the photo sensor is not getting any usable input from the laser at all, meaning that the pickup is "blind" for lack of a better word. This can be caused by an obstruction of the beam by foreign matter on the lens or inside the pickup all the way to a marginal or failed laser diode and/or photosensor array. This can also be caused by a bad ribbon cable with one or more severed traces. You could try to clean the optics. It would involve taking the cover off and finding a way to take a slightly damped swab and gently rub the objective lens on the pickup clean, followed by a drying with the dry side. But, unless the player is prone to dust accumulation (which was a big problem with quite a few Aiwa shelf systems with the 3 disc changers), cleaning it may not help. Another possibility could be that the transmission ribbon which connects the pickup to the player electronics may have developed breaks, which is another typical problem with many shelf systems. Yet another possibility, which is the worst case: the pickup may have worn out. Again, if the player is four years old and was used constantly, it is very possible that the pickup has decided to give up the ghost. Another possibility, which is EXTREME worst case and is not likely to happen at any time with any CD player is a failure of the CD decoder chip. The decoder chip handles the 8-14 demodulation and error correction of the CD signal and outputs the processed signal as PCM for upsampling and conversion. If this chip fails, the CD player will spin up and synch to the disc but, without decoding, the player will be unable to read the TOC and play the disc. But, as I said before, this usually never happens as the semiconductor parts are the most reliable components in a CD player and usually never fail unless they were deliberately damaged by an external influence, like shorting out one or more leads with a screwdriver while the player is powered. In the latter three events, replacement parts may not be easily sourced, if at all, and the required labor to effect the repair may not be worth it. (In addition, a new pickup has a protective solder short designed to protect the laser pickup from static discharge damage. This short has to be desoldered in order to allow the pickup to function.) In this case, replacement of the entire shelf system becomes necessary. If buying a new shelf system, stick with some of the better brands in this area like JVC, Sony, Panasonic, Aiwa, Pioneer, and even Philips. Brands to avoid include Sharp, Sanyo/Fisher, RCA, Emerson, and any cheap store brands like Durabrand or CurtisMathes. But, in general, even the finest shelf systems are a compromise in design which can affect reliability. Most, even from the recommended brands, weren't designed to be serviced very easily when they break as people usually dispose of them rather than have them repaired.
Posted on Jan 18, 2006
SOURCE:
2006 expedition 6 indash changer wont read disc
it doesint read a copy disc if it is not a copy disc it is that you should try to clean it because it is durdy put on a cleaner on a disc and put the disc inside it should work again use a spray cleaner only
Nov 19, 2017 | 2006 Ford Expedition
6 disc cd changer wont read cd
have you tried factory (store bought) CD's or changed all of them out
Nov 06, 2013 | Alpine CHM-S620 6-Disc CD Changer
Turned unit on .error message.cannot read disc.tried wping disc. nothing follwed directions in manual.nthing treied to start over nothing on screen at all.
Hi, if this is occurring on a multiple video game, then it is likely that there is a problem with your wii console, perhaps either the disc drive is malfunctioning or there is a problem with it's optical lens not being able to read the disc....
So if it is more than just one video game you are having problem with, then give a call to Nintendo's 1-800-255-3700 (6 am - 7 pm Pacific, everyday) customer service number, or use their webform to contact them and they can set up the repair process for you..
Take care
Mar 14, 2010 | Nintendo Video Game Consoles & Games
Dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would...
dvd player keeps saying no disc when I try to play a dvd.what can i do? worked fine until about 3 months ago. started to say no disc when disc inserted but after opening and closing 3 to 6 times it would read.now it just wont read. any ideas?
Oct 12, 2009 | Cyberhome CH-DVD 300 DVD Player
My 6 disc cd changer won't read cds
unplug the power to the cd player for about 10 minutes or so. usually that reqiures unhooking the car battery. if that radio is of the anti-theft variety make sure you know the code and how to enter it before you remove power
Oct 05, 2009 | 1997 Ford Explorer AWD
Region problem and disc not reading
For your region problem:
1. Be sure there is no any disc inside the device.
2. Power on your player
3. Press <Menu> on remote
4. Using your remote control enter the code below, note that you must know what Region your player is CURRENTLY set to in order to know which code is appropriate:
for Region 1 use 2, 9, 3, 3, 4
for Region 2 use 3, 8, 7, 6, 7
for Region 3 use 5, 6, 7, 3, 2
for Region 4 use 7, 6, 8, 8, 4
for Region 5 use 5, 3, 8, 1, 4
for Region 6 use 2, 4, 4, 6, 2
5. A code should be displayed on the screen indicating the current Region setting of your unit.
4. Press the 9 (or 0) button on your remote control for Region free, or 1 for Region 1, 2 for Region 2 and so on...
5. Double press the <Menu> button on your remote
6. Enjoy :)
For vcd problem...Make sure that the Cd is written in a format which is compatible with the format with your dvd player. If you have a dvd player that can play formats like, avi, wma, etc. check that your cd writer is set on high quality mode and that the writing speed isn't set too fast. hope i was able to help^^
Jan 03, 2009 | Samsung DVD-R135
Won't read discs
Discs Must Be Loaded Label Side Down.
Sep 07, 2008 | Pioneer PD-M603 6-Disc CD Changer
Will not read disc.
i have only had the console for 3 weeks and my fans are clean and almost everything is still stock except online and **** i tried signing off and signing on during the game but then my game will just freeze need help soon getting pissed off
Jun 23, 2008 | Sony Playstation 3 (PS3) Console
Emerson MS9700 CD Shelf System Logo
356 people viewed this question
Top Emerson Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
