SOURCE: When I try print invoices
Which quickbooks are you using? Which platform (Vista, XP etc) If you have Vista, only QuickBooks 2008 and 2009 will work.
SOURCE: Hp6500 won't print my invoices from Quickbooks, Help!
Quickbooks generally give problems with every darn printer on the planet.If you are not using the latest quickbook version then try this. save the document on your desktop and then close the original file.Then open the saved file and select the path to print and click on file point to set print area and then click on set to print area click on ok on the dialog box.Then try to print once again and see if it works.....it should if it doesn't call in to HP at 18004746836 and we will be happy to resolve your issue via a remote access session with your computer
SOURCE: cant get my printer to
Setting Top of Form, Forms Tear-Off ON (Step A) ! If you turn the platen knob when the printer is turned on, you will cause the Top of Form to mis-align. Always turn the printer off before turning the platen knob! 1 Turn the printer ON. 2 Park the paper. 3 With paper out of the unit, (red alarm light should be on) press SHIFT (1) and QUIET/TOF (5) to reset the current Top of Form. 4 Press FF/LOAD (3) to load the paper. 5 Press SEL/MENU (6) to take the printer off line. The SEL light goes out. 6 Wait until the paper moves up to the tear position, then press and hold TEAR (4). The paper moves to the current Top of Form. Keep pressing and holding TEAR. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response Thanks, Joe
7 Press and hold SHIFT and release TEAR.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: When printing invoices, the first page skips one
Set the page length at the printer's settings according to the real page length. If your paper is punched on it's sides, you can compute the real length knowing that the punches are 1/2 inch each other (or you can simply measure it). For more details, please specify the type of software you are using (ms-dos, windows, etc).
