Question about Philips MX3700D Digital Surround Sound Receiver System System
Weak sound with Philips MX3600D
The system works perfect when I play a DVD, but when using the TV there is very little sound coming from the speakers and the center one has no sound at all. I've turned the speakers off in the TV. ( Sony WEGA ) but that did not fix the problem. I have to turn it up to max and still do not have a good sound. Thank you for your help.
eagle338
  • 4889 Answers
SOURCE: philips hts 6510 no disk prompt does not play dvd
Ok looks llike a lens problem..Try this
Get a lens cleaner CD with liquid..Put two drops of liquid on the brush of the lens cleaner..insert the CD in your drive and play it..If it plays fine otherwise you will need to replace the lens..Get it replaced rather..should run you about 25-50$.If you want to get it repaired give it for repair only in a Philips showroom..
Posted on Oct 15, 2007
SOURCE: Philips HTS3357/05 home cinema system
Same problem here with HTS3357/12... This system is also REALLY **** from an electronics point of view (I have checked inside and I know what I am talking about), that's the reason why the sound is so horrible on the front and rear speaker.It is as simple as a SCAM.
No more Philips for me.
Posted on Mar 25, 2008
SOURCE: Just bought a Philips home theatre system HTS3544 low sound?
You may also need to change the speaker set up. Go to DISC setting (one of the top selections on the remote) make sure you have no Disc in the DVD player. When in this mode press setup on the remote. On this menu you will have a option to adjust the speaker volume.
I had to increase my speaker volumes to get better sound. This setting is not accessible if you try to do the set up in other than DISC setting. Be sure to check the SURROUND setting. The SURROUND button on the remote will toggle between stereo and surround as stated in a previous post.
ST
Posted on Mar 27, 2009
SOURCE: cracking popping type sound coming from front and center speaker
if u are trying to connect the audio of ur tv as input to flow out from the home theater; this is a common thing; u need to replace the audio cable that connects the tv to 3565 with a good quality cable
Posted on May 13, 2009
SOURCE: philips HTS8100 owner. Have
Same problem with my HTS8100. Little-to-no sound. Sometimes sound comes on very intermittently. I downloaded the software patch from the Philips website and installed it. This fixed the sound problem for about a week, then the problem came back. I'm not sure what else to do.
Posted on Jan 21, 2011
I want to use my TV's speakers with Samsung ht320z not surround sound.How?
You have to hook up the audio cables to the TV from the DVD stand alone player. Red and White is audio and Yellow is Video. The player will play movies and the sound should go to your TV speakers. If not you will need to set it on the TV in the audio source to play from your speakers on the TV. John
Apr 15, 2012 | Samsung HT-Z310T Theater System
Ps3 running through my Philips DVD
If you where to connect the ps3 to your tv directly wouldnt you get sounds still thought the dvd system?
Mar 22, 2008 | Audio Players & Recorders
Hi, I just bought a Philips HTS3540 home theatre system and I am having problems hearing the TV (Sony Trinitron) through the home theatre system. The DVD / CD / Radion work fine on the philips, but I...
Ok my situation is similar-i did exactly as u described here bobhifi and it worked initially . Then after some weeks suddenly the Aux display now shows 'AV1 Coax' and no sound is coming out of my LG DVD speakers except under Tuner and DVD modes. Pls help
Mar 28, 2011 | Philips Televison & Video
IM tryin to hook up my samsung home theater system to my philips tv. It works when watching dvd, but when i switch to my basic tv cable it doesnt play sound out of my surround sound speakers. How can i...
Check what type of Audio input it has on it. It should either have an Optical Audio input(glowing red while unit is turned on) or an Audio input(red and white jacks) You would run the correct cable from the Audio Output on your tv, To the Audio Input on your surround sound reciever. Let me know if this helps solve your problem.
Mar 04, 2011 | Philips Magnavox MRD20037 System
My home theatre was connected successfully playing the cd movie, but after turning off the dvd and go back to watching tv the sorroung system speakers do not give a sound to the television. is it that i...
hi,
select tv input on ur theater system. u can hear audio fro the frond left and right speakers. if u want to hear the audio from the surround speakers, then press the A-MODE button on ur remote to select different type of sound modes. press again and again to select different sound field. select one which suits u.
ok
Dec 27, 2010 | Curtis DVD5091 Theater System
No sound out of 4 of 5 speakers when using tv only.
switch around rca cords and verify its not a bad wire(s),Check and see in the TV menu audio settings are correct/ balances R/L etc. audio outputs are on,Try different theater amp if you have an extra.
Jan 26, 2009 | Samsung HT-X50 System
How do you get DVD player SOUND to play through the TV speakers
plug the stereo headphone jack to your dvd headphone output then connect it to your tv audio/video in and press the tv/video switch in your tv remote control.
Jan 07, 2009 | Sony DAV-SB500W System
No sound coming from unit when on TV selection
I don't know if this will help but although I have a different system to listen to the tv through my 5.1 system before I got my new tv I had to switch the tv to external speakers or the sound would only come out the tv speaker
Dec 29, 2008 | Philips HTS3544/37 Theater System
Philips Pet706 portable dvd will no longer play sound without earphones
try connecting it to small external multimedia speakers (usually played with computers) that come with a small jack simmilar to that on earphones.
Aug 13, 2008 | Philips PET702 Portable DVD Player
No sound through TV
In case you connect the System to a TV set using the Scart Connector, only the video signal is terminated, Audio is actually not wired inside the SB100 Scart connector.
Sound will only be amplified through the system itself (through the satelites and Sub) it can not be utilized as a stand-alone DVD player.
So after connecting your surround speakers the problem will be solved
Apr 30, 2007 | Sony DAV-SB100 System
Philips MX3700D Digital Surround Sound Receiver System System Logo
203 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
