I have exactly that same car sitting in my garage that I am rebuilding (was thrown away by a neighbor).
The car was made by Dumar International. Looks like the company changed names to MotionTrendz http://www.motiontrendz.com/
The reverse switch most likely needs to be cleaned. If you are technically inclined, you can disassemble the forward/reverse switch and clean the contact points with the eraser of a pencil until polished/clean. If the reverse still doesn't work, you might need a new control box as one of the internal relay's may have become stuck.
SOURCE: Hello. I have a disney princess bed tent that my d...
I got a Princess tent with sleeping bag from Disney foer my daughter thisevening and I too thought the instructions were missing ( foud this site upon searching for it online) until I looked at the hanging label sewn to the pink satin cover for the collapsible posts. look on both sides. You will see the instructions in 5 steps. in case you don't have it,
1, unfold tent and lay bottom flat on a surface,
2. straighten poles and snap together at joints,
3. Insert poles diagonally into sleeves on top of tent.
4. place the end of each pole in pocket on bottom corners of tent,(poles will bend as this is being done.)
5. Hook corners of rain fly into four loops on sides near the top of the tent.
http://www.youtube.com/watch?v=kt5Kw2qxe9Y&feature=related
the above video also explains about snapping the poles. goodluck
hope this helps
