Question about Nintendo Wii Console
Disk won't eject from wii
My wii is not ejecting a disk and i followed some of the "help" suggestions but it doesn't seem to work....I know that this is a popular problem but i really need your help...Please....my dad thinks I broke it......it has fallen over a few times but not dropped on purpose....So if u can help please do
Signed,
Waluigi Lover
  • 32 Answers
Your disc is stuck in Wii Console, It needs to eject manually. You might check out Wii Fix Guide, that gives step by step information on Dis-Assembling with screenshots, even a novice can fix the disc eject problem with the help of this DIY Guide. It also gives information on fixing many Wii Related Problems, so its a kind of Wii Problems Reference Fix Guide
Posted on Mar 04, 2009
    Scholar:
  • 125 Answers
I looked it up at the troublshooting center on Nintendo.com, I found this: If a game freezes while playing, usually the power, reset, and eject buttons will not respond. Try unplugging the AC Adapter from the back of the console, then check the air vents to make sure they're not being blocked. If that does not help, it looks like you may have a problem with the wii itself. You should contact Nintendo customer support about how to get it repaired. You can call them at 1-800-255-3700. Hope it fixes it for you! Good luck! :)
Posted on Sep 08, 2008
When I insert a disk into my wii console, it will accept the disk, make a clicking sound and then eject the disk. This happens with every wii game i've tried. Any suggestions?
my friend,Christina, had the same problem, but didn't handle it right. SHE threw it on the ground. Don't do that. Just take it into GameStop. Then you can either get it fixed, or you can trade it in for a new Wii.
Mar 21, 2013 | Nintendo Wii Console
My wii keeps ejecting my game cube games, even tho they are scratch free. I put the game in and the disc icon doesn't even spin as if the game is not there then after 3 seconds of putting the game in...
I had this same problem, its just a issue with the disk driver hand (Its the hand that pulls GC disk and Wii disk into the disk holder) to fix pick up the wii, tilt it upright (to where the back of the wii (where the USB ports are)) is facing the ground and the disk slot is facing the ceiling. Simply put the disk in the console and gravity should do the rest. Also the disk will eject really easily so don't worry about the disk getting stuck inside of the console.
Dec 10, 2011 | Nintendo Video Game Consoles & Games
Disc will not eject
your problem seems to be a failure in the Slot load Tray. it seems that the mechanism which assists in ejecting the Disc could require repairing/replacing.
i would suggest getting in touch with Nintendo customer services about this issue due to it being an internal hardware fault !
hope this helps ?!
Oct 27, 2008 | Nintendo Wii Console
Wii
hello micky1965
Try holding down the eject button for at least 10 seconds after turning on the console. If that doesn't work (or you've already tried that). Try the following steps.
1. Unplug Wii from power outlet.
2. Plug in Wii again.
3. Press power button.
4. Press Eject button for at least 10 seconds.
5. If the disc doesn't eject try holding down the power button for 10 seconds and then the eject button again.
If that fails then either return the console to exchange for a new one or contact Nintendo consumer support. Info follows:
Nintendo Consumer Service Contact Information:
Telephone: 1-800-255-3700
Email webform:
| Nintendo - Customer Service | Contact Us! |
I wouldn't attempt to manually remove the disc (by trying to disassemble your Wii) as it may void your warranty. It could simply be a faulty console in which case Nintendo should replace it within 2 weeks (according to posts I've read). It seems to be a somewhat common problem.
If holding down the eject button doesn't work, there's really not much else you can do. Sometimes unplugging and replugging does the trick.
I've had problems with discs not ejecting and some combination of the steps I wrote above solved the problem.
riz.
althought i have a guide for opening inside the wii.?
Apr 08, 2008 | Nintendo Wii Console
Wii help!
we got it to work eventually by using a pin (ie a dressmakers pin). We realised the eject button wasn't clicking when pushed down, so was physically stuck, so used pin to pop the left hand side of the eject button out/up. Works a treat now.
Feb 20, 2008 | Nintendo Wii Console
Nintendo wii system gamecube game is stuck inside ,everything else still works
it's the ejectijon button cause i have the same problem but with a wii disc
Feb 09, 2008 | Nintendo Wii Console
Wii console will not eject disk
I managed to eject a WII disc out manually very easily:
- Disconnect the drive
- You see the white plastic mechanism on your right side and the wheel connected to the motor
- turn the wheel towards the back side of the drive while pushing the half inch square plastic piece towards the left.
You will see the disc coming out while you are turning the wheel.
Nov 25, 2007 | Nintendo Wii Console
Unable to load games
I have a very similar problem that my wii console gives me black screen with disk read error every time I inserted a new disc that worked previously. The way I worked around this problem is by
1. ejecting the disc
2. powering off(hold the power button for about 10 seconds)
3. unplugging the power cord
4. waiting one minute or so
5. plugging in again and re-inserting disc
This worked every time when I switched disc.
Nov 17, 2007 | Nintendo Wii Console
Cd stuck
Well, Recently the same thing happened to me, My bro dropped my WII on the floor and the eject button on it got stuck i was soo mad!!!
I tried loads of ways nothing really hard, just follow this and hope fully the WII will eject:
1.Make sure the WII is stood up properly.
2.Then switch on the WII (As i said early the WII won't eject the CD.
3.Now look near the eject button if it is stuck follow (A) or if not coming out follow (B).
(A1).Right if it is stuck and not coming out then the top bendy bit of the eject button put your nail through it and press it down it should eject but after a while it did not work any more for me :(.
(A2).Now, Disconnect all the Cable's in the WII not TV leave it for a while (and don't smash it again!), After a while approx 5 Min's plug 'em back in, switch on the WII then press eject hopefully that will work :D.
(B1).Now if it does not come out either look inside the drive or WII (I don't suggest that) or just do what i did with A2 hopefully that will work.
Hope your WII works by now and enjoy ejecting cd's from your WII but 1 more thing before you go (DON'T BREAK YOUR WII AGAIN OR YOU WILL HAVE TO DO THIS ALL OVER AGAIN :P AND IT MIGHT NOT EVEN WORK IF SMASH IT TO MANY TIMES!!! SO BE-CAREFUL!!!!
Sep 30, 2007 | Nintendo Wii Console
Nintendo Wii Console Logo
80 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
