Question about Pioneer SD-P55A3-K 55" Rear Projection Television
One More On Convergence Popping Out
As a follow-up to the original- If I have to replace the STK's can I recalibrate the set from the user convergence in the menu or will it require something more precise from the service menu. Pioneer's service menu isn't exactly user friendly and I'd assume I'll need the manual for that. Also on the STK's, I believe this one came from the factory with STK392-110's. Thanks, Bob
    Problem Solver:
  • 14 Answers
Not sure if this is the same model , but I had a > pioneer PTV that I replace > the Convergence amps on and still couldn't get > full range on the Blue too. > See those caps around the Conv board? I had about > 10 - 15 of them > leaking......replaced and problem solved.
Posted on Jan 17, 2006
SOURCE:
Convergence problem
Both convergence chips need to be replaced and or some resistors and set adjusted.
If have the original remote go into menu and select convergence to see if it will adjust---if not chips etc need to be replaced.
Set most likely uses 2 stk-392-120 chips but a few use the -110 chip.
May 29, 2012 | Philips Televison & Video
My tv is a magnavox and we bought it about 3 years ago and it is now showing like a double picture the color is hazy and pinkish looking the model is 51MP392H/17
The problem of your unit is the convergence. Try to adjust it using the original remote control in the setting menu, then goto the convergence section adjust the red and blue convergence, you should move red and blue UP, DOWN and LEFT or RIGHT, if you cannot move them far enough the convergence IC is defective, replacing this IC will restore the original setting of your tv. This convergence IC is attach to a large aluminum plate it is the heat sink this IC has a marking of STK-#### followed by numbers, remember be careful when replacing this IC you may accidentally tampered or damage the PCB and cause much damage to your unit. Or you can contact a technician to do it for you and save you from stress good day and best regards. Try to check this link for the convergence http://www.google.com.ph/search?q=convergence+ic&hl=tl&sa=X&tbm=isch&prmd=ivns&bav=on.2,or.r_gc.r_pw.&biw=798&bih=472&ech=1&psi=JZdtTvDCPIe4iAe72sTABA.1315804977740.3&emsg=NCSR&noj=1&ei=MpdtTpa4OKKSiQfBpcjGBA
Sep 12, 2011 | Philips Magnavox 51MP392H Rear Projection...
When I try to do the manual converegence on my sony kp51ws510, I cannot get the squares around the + to change to red or blue and consiquently I cannot adjust the convergence. Flash focus works fine but...
You need to replace the convergence IC, They start with STK make sdure you get original stk IC's and not cheap china made or aftermarket parts as they will not lasts long in your set. if you pay less then 15 bucks for your IC that really is no bargain cause it is most likely an aftermarket IC
Aug 14, 2009 | Televison & Video
Shadow images and scrolling banner curves upward and back down.
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Mar 15, 2009 | Panasonic PT-53TW53 53" Rear Projection...
Double image
Your TV most likely has one of two possible problems.
  • Screen looks 3D
Jan 27, 2009 | Sony KP-57HW40 57" Rear Projection...
Replacement STK numbers for convergence amps
This unit does not use the STK series convergence amps.The convergence power supply is what you need.I will provide that number for you after while.
Jan 19, 2009 | RCA P52960 52" Rear Projection Television
Hitachi 50" 50GX30B PJTV
Solution:
Your TV has a convergence problem. Here are some of the most common symptoms.
Screen looks 3D
Screen is bowed in but stationary.
Using your original remote go-to the tv settings then goto the convergence or magic focus section
You can get a repair kit that includes all the parts from www.TvRepairKits.com.
They have put together a kit for the Hitachi TV sets.
The kit includes a photo instruction guide, original Sanyo STK chips, convergence resistors, etc.
Everything you need to fix it yourself. Its a fairly easy fix on the Hitachi sets.
Oct 20, 2007 | Hitachi 50UX57B 50" Rear Projection...
Picture Problem , Sony Projection TV
Your TV most likely a convergence failure. ( common problem )
  • Screen looks 3D
Here are some photos of convergence problems.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Oct 01, 2007 | JVC AV-56WP84 56" Rear Projection...
Convergence problem
That unit has a convergence repair kit that should fix most problems. Order it directly from Hitachi p/n# X480295. It contains: Rk42 3.3 Ohm 1w Rk46 1.8 Ohm 1w Rk50 3.3 Ohm 1w Rk54 1.8 Ohm 1w Rk58 3.9 Ohm 1w Rk62 2.2 Ohm 1w Ik04 Stk392-150 Ik05 Stk392-150 And I would strongly recommend testing all the resistors in that circuit for change in value. Are you using a good heat sink compound on the STK's when you installed them? That and ordering the japanese knock-offs for STK's are the two most common critical mistakes made. Originally that unit had two STK392-110's for conv. amps. Even Hitachi recommends subbing to a STK392-150 or 180 for greater reliability. You do realize that for the cost you have after two failed attempts you probably could have taken this to a reputable shop and watching the ball games now. :) (no disrespect intended) Good Luck! Bill
Jun 01, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Colors separated
You need change STK392-560(can use STK392-570)
I guess it happend when holding bolts weaken to radiator.(Check other STK on next radiator)
You have to change STK on right radiator.
Disconnect small connectors. You can l leave Hi Voltage two lines(RED). unscrew board.
Pool board out.
Unscrew STK. Set board verticaly. Just pool STK bu pincet and heatup solder. One by one...
Clean halles.
Set new STK with thermopasta on board in to hallsradiator. Screw up.
Wet contacts by liquid fluse. And sosler them.
Clean up by alcohol...Check for short by lense...
Apr 28, 2007 | Sony KP-57WS500 57" Rear Projection...
Pioneer SD-P55A3-K 55" Rear Projection Television Logo
81 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
