Question about Oberwerk (11x70) Binocular
Bushnell Binoculars We have a pair of Bushnell binoculars. The casing has become super "sticky". Is there anything we can use to clean and restore it?
  • 1 more comment
  • ncriptide Nov 01, 2008
    I have the same problem My binoculars are the Jason Model 296, Perma Focus 1000. The rubber grips on top of the binoculars are super sticky and black comes off in your hand. Any solutions?
  • MidnyteMoon Dec 05, 2008
    My Bushnell binoculars, got them out last night to look at Saturn and Venus... same problem. The black rubber has become sticky over the years, and that black stuff gets on your hands and it's hard to get off. I had a pair of black boots that this same thing happened to, on the insides. Ruined my purple socks, LOL. It must be a certain type of rubber that this happens to?
  • Paul Seemuth
    Paul Seemuth May 26, 2016
    I have a sharper image 8x28 variable binocular compact that was very gooey from use and storage over the years. I can give a definite thumbs up to use Murthy's oil soap. Use full strength, place some on rag and wipe body and other surfaces till the black material is completely removed. IT may take 20 minutes with good rubbing to get it all off ( change rags or areas to minimize time). Works on rubber eye protectors also. Once you have removed the blackish material (white rag v good to see) taking another clean rag, to verify you got must off the unit then take a clean moist rag, rub the oil soap off ( should take no time at all then dry. My binoculars, though now missing most of printing and logos, feel smooth, no stickiness and works perfectly. A little soap save me better than 60 bucks for a new pair.
    Just to cover bases, I tried isopropyl alcohol, acetone and simple green and NONE of them work even marginally. The solvents made it worse so save time and get the Murthy's. PS. I don't work for them nor never have. Just used original comment suggestion!
USE ACETONE (FINGERNAIL POLISH REMOVER) PUT IT ON WITH A CLOTH..IT TAKES THE STICKY OFF BUT THE END RESULT ISN'T POLISHED. SO BE EASY WITH THE ACETONE...
Posted on Jul 04, 2009
  • knarfie Mar 21, 2011
    I bought a pair of these at a flea market, and had the same problem, with sticky goo completely covering the portion of the binoculars which houses the mirrors and prisms. i tried about 6 different solvents, including acetone (or fingernail polish remover) and what worked best of all was isopropyl alcohol. I used plenty of that, and lots of paper towels. It would be interesting to know the source of the stickum in the first place.
  • 3 Answers
I agree with the isopropyl alcohol. However, it still does not come off easily. You can, with perseverance, remove the sticky down to the nice hard surface. I then used car wax on the cleaned areas and it worked great
Posted on Sep 14, 2011
The very best solution is use Rubbing Compound & Heavy Duty Cleaner from Turtle Wax.
Posted on May 08, 2013
I want to Thank the person who told me to use wax. I used a cleaner wax for (cars,boats),and kept rubbing that black off until it all came off and left a shine. It really worked.Thank You.....
Posted on Oct 12, 2012
The best solution I had for cleaning Bushnell Binoculars is Murphys' Soap. "Pure Vegetable Oil Soap" Household Cleaner. It has no toxic ingredients, no chemicals. I used it straight from the bottle. It removed all the sticky substance. I was pleasantly surprised. A lot of arm work.
Marilyn Ulrick
Posted on Aug 18, 2015
The outside of My unit has become sticky and has an odd aroma. I think the chemical component coating is changing. I have included a picture Ser# CE0389 Respectfully, ken henson
Try applying the solution for sticky old Tupperware . Rub with a rag or paper towel moistened with household ammonia until the sticky surface is no longer sticky. Worked like a charm on my sticky Bushnell binoculars (and on Tupperware). .They were unusable before treatment. I suspect plasticizer migration.
Aug 12, 2015 | Optics
How can I fix the sticky black surface of the outside of my binoculars?
Try cotton pads (makeup removal type) and Isopropyl alcohol. it works about 75% of the time. Cotton balls can leave a lot of fibers.
Jul 29, 2013 | Bushnell Powerview Binoculars 8X25 Compact...
I have Bushnell Powerview 13-2521 which are about 12 years old. The coating on the exterior has tiurned
I cleaned my Tasco binoculars with Goof-Off and it seemed to work well. It was in horrible shape, with really sticky black goo.. now it feels smooth and clean again. Don't know how long it will last though.
Apr 16, 2012 | Optics
Rubber housing on Sigma binoculars has gone sticky
  • Moisten a soft cloth with ammonia or Windex. Rub it over the sticky area to remove some of the damaged surface.
  • Ammonia can be used as well, but should be used with caution as it can cause damage to some plastic surfaces.
  • If the sticky, damaged surface remains, it can be scraped away with a spoon or dull knife.
  • Please note that these fixes are only temporary. Once the plastic starts to degrade, it will continue and the problem will be recurring. It is best to replace these parts whenever possible.
  • Nov 24, 2011 | Optics
    I have a pair of bushnell imageview 8x30 binocular and digital camera. i need an insturction manual
    Pick the model of your binoculars/camera from the list at
    http://bushnell.com/products/binoculars/instruction-manuals/
    Jul 09, 2011 | Bushnell Cameras
    I have a pair of binoculars that need help; here are the only specs I have--written on the outside of the binoculars: Bushnell National Audubon Society 8x42WA 13-2000 430 feet at 1,000 yards. I...
    Unfortunately the rubberised coatings on some binoculars (and, indeed, the focusing and zoom rings on some camera lenses) go like that in non-optimum storage conditions - i.e warm moist areas, such as a kitchen cupboard. I'm afraid I know of no way of curing this - you may need to take them to a repair facility and ask their advice.
    Mar 11, 2017 | Cameras
    My Chinon 10x25R binoculars have the same problem.
    Simple use soft lint free cloth like old drying up cloth, you need about half a cup of methalayted spirits,can get this from any hardware store.
    poke finger into cloth dip into meths proceed to rub sticky coating off binoculars. you will need to keep changing to a new peace of the cloth as soon as it gets coated with the sticky black stuff off binoculars.
    keep dipping into meths eventually after say 6 rubs in a particular area you will see and feel a nice hard black plastic, continue all over effected area then finish off with any window cleaner polish until cloth remains clean.STICKY COATING IS NOW GONE IT WAS INFACT A COATING PUT ON THE BINOCULARS TO MAKE THEM NONE SLIP. job done. regards GER8
    Jun 09, 2009 | Winchester 10x25 Hunter's Grip Binoculars
    The rubber armoring is "melting" or getting all sticky
    It can be easily resolve, just go to the youtude, check for sticky melting solution. The sticky surface can be treated and back to normal.
    Dec 11, 2008 | Bushnell Optics
    Bushnell PowerView 13-1633 Binoculars
    Hi - This called the diopter adjustment which compensates for small differences in focus between the left & right eyes.
    See the following web page for adjusting :
    http://www.birdwatching.com/optics/diopter_set.html
    Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
    Informatica
    Sep 07, 2008 | Bushnell PowerView 13-1633 Binocular
    Oberwerk (11x70) Binocular Logo
    6,154 people viewed this question
    Top Oberwerk Optics Experts
    Joe Lalumia aka...
    Joe Lalumia aka...
    Mark Campeau
    Level 1 Expert
    Are you an Oberwerk Optic Expert? Answer questions, earn points and help others
