Samsung SL102 Digital Camera Logo
Posted on Aug 18, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Im trying to charge my camera via computer. . there is a red light on the charge cable connector and a green light on the camera which i have switched "on". it still says "low battery even after charging all night. when turned 'on' initially the green light starts flashing and then it stops flashing.
Anonymous
Level 2:
Sergeant:
  • Expert 304 Answers
  • Posted on Aug 18, 2011
Anonymous
Expert
Level 2:
Sergeant:
Answers
304
Questions
0
Helped
52321
Points
858
Hi, I'd suggest using a wall charger as they're able to provide more power to charge then a computers USB port. Often with camera's the USB port doesn't supply enough power so the camera doesn't charge at all.
Charge indicator
Perhaps you want to charge via a USB connector on your PC. Could be the PC connections are not correct for delivering 5V on that connector.
The manual also says:
Connect the camera directly to the computer; do not use a USB hub or keyboard.
Please try to charge via the external charger that came with the camera. If that fails too, please try to replace the USB cable.
I am trying to learn about the different coloured lights on the USB cable of the samsung L200 digital camera, to start with looking at this website i learnt the orange light meant that the camera is...
you should change either your battery or your usb cable when an orange light blinking on the usb cable indicator. .maybe one of those accessories was already defect..
I mistakely deleted pictures from my camera (Kodax Esay Share M340) Move picture to internal memory.How can i get the pictures back
If Try one or more of the following
Ready light does not turn on and the camera does not work.
Ready light blinks green.
  • Camera is operating normally.
Ready light blinks amber.
  • Wait. Resume picture taking when the light stops blinking and turns green.
Ready light blinks red and camera turns off.
Ready light glows steady red.
Ready light is off or glows steady green.
3helpful
2answers
How would i know when my Samsung camerais through charging
you can know if the camera is charging by the indicator light in the usb cable, green light means it was full charged..red light means that unit still charging.
2helpful
My nikon coolpix S220 wont charge. I had to buy another USB connector because my son lost his and it does not seem to recognize the camera at all and will not charge
The camera does not contain any charging circuitry and will not charge the battery when connected via the USB cable. In fact connecting via USB actually drains the battery faster because the camera has to communicate with the computer (even if only to say it has nothing to say).
The camera comes with a separate MH-63 charger. Take the battery out of the camera, put it into the charger, and plug the charger into a wall outlet. Once the battery is charged, you can put it into the camera and try connecting it to the computer.
Better yet, don't connect it to the computer. The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use Nikon Transfer or any other photo cataloging program.
3helpful
2answers
Should the power light be green or red, when I turn camera on it shows a green light then turns red
Red light indicates that the camera is out of charged., Try to charged your battery for 3-4 hrs if you encounter flashing red on a fully charged battery you need to call kodak 1 800 235 6325 ext 12
You can charged you camera using 5V AC Adaptor or a USB cable taht attached into the computer
1helpful
2answers
Pentax
You can charge the battery using the USB cable. The camera has a built-in recgargeable Li-ion battery, but the AC charger is "optional" ... go figure...
Nice camera, btw...
I'm not aware of any indicator light on the camera. The optional external charger has a red lighht that turns amber, then green.
2helpful
2answers
13helpful
2answers
Need pin out info for aqua vu 4 pin connector
I figured it out:
Here goes: There are 4 wires inside the Aqua Vu cable that runs to the underwater part of the cam.
Red = Hot or 12 volt power from battery postive (red) terminal
Black = Ground - ground to battery negative terminal
White= Video input (or center of video coax)
Green= Infrared lighting control, if you ground the green wire against the black/ground, you will see
that it switches ON the infrared or "Christmas" lights. Simply put a switch on the green wire after you ground it, so you can switch your IR's on and off.
Feb 17, 2008 • Cameras
7helpful
6answers
Kodak md853
I've had my camera for a long time so I don't think I'll get the option of taking it back and exchanging it but I keep having the same charging problem. I just tried the flash button trick... the green light is on, steady, and holding. I'm not going to touch it any more and I hope that if I leave it this way for a bit it'll charge up.
My advice is to NOT LET THE BATTERY RUN DOWN past half charge, otherwise it won't have enough power to stay on long enough to register the fact that its plugged in to the computer.
Oct 18, 2007 • Cameras
Top Samsung Cameras Experts
ZJ Limited
ZJ Limited
Are you a Samsung Camera Expert? Answer questions, earn points and help others
