Question about Compaq Presario 1200XL104 Notebook
Laptop Boot Problem
I have a Presario 1200z notebook that powers on, fan runs but thats it. It never boots up, there is no display, internal or external. Also tried 2 different power supply sources in addition to just battey power. Removed all devices but it still displays nothing.
    Novelist:
    Champion:
  • 277 Answers
It seems all Compaq laptops are infected by this problem. If you are sure that the AC port and the AC adapter is working? Can you hear the laptop trying to boot? ..e.g. Hard Drive spinning up, Floppy Disk Drive noise, etc.. if so ...Try hooking up a external monitor.. Does it smell like anything has burnt? (Call for service) Is there anything that sounds loose when you shake it? (Call for service or you can to open it?) Try booting your laptop from a bootable floppy if you have one. Or use Compaq's Recovery CD. But I doubt if you use recovery CD, you might lose data on your HDD. Which O.S. are you using? The Boot-up mechanism checks all the hardware before starting Windows. Some times floppy drive doesn't allow the laptop to boot further by either not responding or sending wrong signal.
Posted on Jan 16, 2006
Laptop powered up lights on keyboard are lite fan's running but won't boot up
try booting up in safe mode first.this somtimes sorts it out.
if not let me know.
Mar 24, 2015 | HP Compaq Presario 2100US Notebook
In system configuratiopn what is the boot order in compaq laptop??
The boot order is the order of devices listed in BIOS that the computer will look for operating system information on. wheather you want to boot from a CD/DVD OR VIA INTERNAL HDD
Aug 06, 2011 | Compaq Presario 700 470024-192 Notebook
Compaq presario starts but will not boot up
Check whether your CPU fan is working. It could be due to Fan malfunction of the cabinet also. Seek technician's help, if not resolved
Aug 21, 2009 | HP 435768-001 - Compaq Presario C300...
I have compaq pc presario c300 i cant open windows meaning when i start up my laptop the xp window is just come n go faster (popUp)
When you boot up press F8 function key and Windows will give a list of boot options, select Last Known Good Configuration and hopefully Windows will start up correctly. If not boot up again, press F8 and select Safe Mode and Windows should boot up in standard VGA display mode.
If this doesn't work you need the Compac restore CD disk that came with your laptop. Boot up with this CD to restore your laptop, you most likely will lose data.
Jul 29, 2009 | HP Compaq Presario C304NR Notebook
My Toshiba Satellite A215-S7437 will not boot. Unfortunately by "will not boot" I also mean will not boot to bios, in addition to not booting normally. Essentially, when the power button is pressed, the...
you should see the post screen if the monitor is working. try hte fn and the monitor or display key. some laptops toggle the display this way. another possibility is the lid switch that shuts off the display when you close the lid. and it could be heat damage.
Jul 20, 2009 | Toshiba Satellite A215-S4747 Notebook
My laptop (Compaq Presario v2000) won't seem to boot up
Remove the battery. Plug power cord in. Turn on machine. Does it boot? Replace battery.
gurutim
Mar 17, 2009 | HP Compaq Presario V2000 Notebook
Compaq presario v5000
Boot into Setup and run the TOOLS / PRIMARY HDD TEST / SHORT TEST.
If it fails, try another HDD.
If OK, verify Boot Order is Floppy, CD-ROM, HDD. Exit Setup.
Print Table 1 Low Level Format instructions from http://support.microsoft.com/kb/106419
Boot with a DOS disk that contains Debug. Run the Table 1 script. Turn V5000 Off.
Boot with the HP Operating System CD. XP install should now proceed normally.
Good luck.
Sep 12, 2008 | Compaq Presario V5005us Notebook
Toshiba Satellite P200 doesn't boot
Try pressing FN/F5 keys simultaneously, or the key that toggles internal/external Display. Look for the double screen Icons on the keys.
Tap the Pause Key.
Restart and press and hold F8 key when Toshiba logo appears. When the boot Menu appears, select Last Known Good Configuration.
If all else fails ther should be a reset button on the side of the LT. Consult owners Manual for location
Aug 15, 2008 | Toshiba Satellite A100-S8111TD Notebook
Compaq Presario 1200XL104 Notebook Logo
109 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
