Question about Maytag M7DH65B2A Dehumidifier
Part needed I need to order a drain spout hose attachment.
  • 2,071 Answers
Just click below;
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Hope this may help;
DON'T FORGET TO RATE:
Posted on Sep 07, 2008
  • 706 Answers
Try this link to a parts supplier ( shows you a breakdown of the entire assembly) http://www.appliancefactoryparts.com/search/modelinfo.php?modelsID=123312
Hope this helps..
What do i need to do with my unit to drain into a nearby drain in my basement?
Find the drain hose connection if there is one and attach a length of hose of sufficient length to reach the drain.
Aug 15, 2016 | Professional Series dehumidifier model...
My delonghi airadry slim is not draining through the hose
Did you punch out (or cut) the plug that the hose connects to? If not, its blocking the water from draining to the hose.
Keep it in case you want to go back to the bucket.
Also, make sure the unit is higher than the drain and that the hose is not kinked or clogged.
Please rate 4 stars if this is helpful. Thanks and good luck!
Jul 29, 2017 | Dehumidifiers
Hose connected but not draining and bucket filling
I am also an air conditioning tech, with same problem and same soleus dehumidifier problem. you must remove the plug and install the drain line hose adapter. Hose must lay flat and have no "hills" for water to drain. With this done pull your drain pan out and set aside. look under right side facing the dehumidifier and you will see a small spout. Has a lip like a little tea pot. Plug that spout. I used a foam ear plug used in work shops. Now give the front of dehumidifier a slight rise on front wheels about the thickness of a pies of cardboard 1/8 to 3/16 of an inch. Now put drain pan back in an start up. The problem is the drain pan was made with very little differance in pitch between the the hose drain and the bucket drain. Remember to check your drain hose periodically and the air filter also. Good luck
Sep 09, 2011 | Soleus CFM-40 Dehumidifier
I tried to drain direct via garden hose, perfectaire PA50 dehumidifier. I unplugged the plug, connected the little hose that came with the thing..connected to the inner spout and to the hose adaptor,...
Aug 15, 2017 | DeLonghi 50-Pint Electronic Control...
I attached a hose to the drain hose connector. When I insert it into the drain hole it is blocked by the back of the dehumidifier. What iw the correct way to insert? Can you send a better diagram?
The drain hose connector MUST be attached to the unit, before attaching the garden hose.
First, the connector is attached to the unit. Second, the hose is hand tightened to the connector.
If you haven't been doing it in this order, that's the problem.
Mar 13, 2011 | LG LHD459EL Dehumidifier
Have hose hooked up but it does not drain. Compartment fills with water and needs dumped manually. Want the hose to work so twice-a-day dumping in basement not needed. Thanks!
You connected a hose to the hose outlet on the catch tank ... right? The tank will not drain even though there are no kinks in the hose and the end is lower than the tank, right? Did you put a hole in the tank before you attached the hose? I will bet not ... and I will not laff at you ... I did the same.
Put a hole in the tank (where the hose attaches), reattach the hose and all will be well.
Thanks for your interest in FixYa.com :-)
Aug 09, 2010 | Soleus 30-Pint Dehumidifier
How do you hook it up to a floor drain?
With most portable dehumidifiers use a bucket to catch the condensate. Then the bucket is full the dehumidifier stops, then you need to empty it and replace the bucket to get the dehumidifier to start working again.
To make this unit run continually, the bucket can be modified so a garden hose can be attached and the hose can be feed into a floor drain. To do this look at the bottom of the bucket, there should be a hose connector where you can attach a standard garden hose. You will need to drill out the center of the hose connector with a 1/4" drill bit. Then you can attach the hose to the bucket and the other end into the floor drain.
Jul 01, 2010 | Whirlpool AD25BBK Dehumidifier
I want to change my deLonghi Dehumidifier from emptying into the container to continuous flow into the sink. I was given this from a friend, not new and dont have a manuel or the hose to change it over....
You may have a older model that has a collector tank with a protruding tube on it. If so just cut the end off the tube and slide on a piece of clear 9.5mm internal diameter PVC / Rubber tubing suitable for a fish tank air / water pump and secure it with a nylon tie wrap.
Continuous external draining for newer models with clear collection tanks.
If the appliance is to be operated for long periods of time but you are unable to empty the tank, you are recommended to use the continuous drain facility.
• Drill the inside of the drain spout using a small drill bit. This is located behind the rear grlle in the lower centre of the opening.
• Fasten the rubber hose to the spout. For models without drain hoses supplied, we suggest you purchase a rubber hose around 2m long, with an internal diameter of 9.5 mm.
• Make sure that the hose is not higher than the spout, otherwise water will remain in the tank; also check that the hose is not twisted. N.B: Keep the rubber bung. You will need it to plug the hose or close the spout if you revert to draining into the tank
Sep 28, 2009 | DeLonghi Dehumidifiers
Need manual with exploded diagram
If your model has a condensate (water) reservoir, there should either be a threaded hose fitting located at the bottom of the reservoir that will accept a standard garden hose, once you punch out the plug inside the threaded coupler.
If you do not have a threaded hose coupler on your unit's reservoir, remove the reservoir and look inside the area above it and there should be a small hose fitting that you can attach a standard garden hose to, to allow for constant draining without having to use and empty the condensate reservoir daily, etc.
If you don't have either of these items, you'll need to purchase a new condensate reservoir with a hose drain attachment to allow use of an auxillary drain hose. You'll need to contact Maytag customer service for the correct parts and assistance.
Maytag Customer Service
533 Benson Road
Benton Harbor,MI 49022
(866)616-2601 U.S.
(800)688-2002 Canada
Hope you found this Very Helpful and best regards!
Aug 18, 2009 | Maytag M7DH45B2A Dehumidifier
Danby continuous water flow will not work on a dehumidifier it still fills the bucket
Please try the following:
1) Remove the bucket.
2) You will notice a round outlet/spout where the water drips from into the bucket.
3) Remove the plug from the backside of the unit (you will now see a hole to the bucket area).
4) Feed a hose through the hole from the back and attach the end of the hose to the round outlet/spout.
5) Place the other end of the hose on a floor drain outlet.
6) Put the bucket back into the unit.
When the unit is turned on, the water will now flow through the hose instead (into the floor drain). When you want to use the bucket again to capture the water, you will need to remove the hose.
I hope that helps.
Apr 25, 2009 | Danby DDR601 Dehumidifier
Maytag M7DH65B2A Dehumidifier Logo
346 people viewed this question
Top Maytag Dehumidifiers Experts
Bill Long
Steve
Mike Squire
Are you a Maytag Dehumidifier Expert? Answer questions, earn points and help others
