Question about Samsung S630 Digital Camera
Batteries New alkaline batteries last about 30 minutes if I'm lucky. Someone suggested removing the time/date capacitor, its the small silber color cylinder below the lcd screen when you open it on the back as it was discharging the batteries. Time won't show but everything else works. Don't know where or how to do this and do you know if it works? If not any other suggestions? I'm going to Yellowstone on 9/7. thanks, nbg
  • bybeth Sep 21, 2008
    Really appreciated the response and I'll go purchase the kit as I really like the camera and the pictures I have taken have been really crisp and clear. Thanks again for being someone I can go to for answers!!!
I had the same problem......I went to the store that i bought the camera from and i bought a kit that contained four rechargable batteries, a battery charger, & it also came with a car cord that goes into your cigarette lighter so you can charge a set in your car. PROBLEM SOLVED for $26.00 + tax.
I take a whole lot of pictures (freelance photographer) and I ALWAYS have one fresh set. As soon as the set in my camera goes low i throw them on the charger and put a fresh set in my camera. By the time the fresh set goes low, the set in the charger is ready.
Posted on Sep 21, 2008
New thermostat and control box only shows two EEs and does not work, Any suggestions?
There is an error in your thermostat...duh! Take the batteries out and replace with Brand New Alkalines, after 30 minutes. Meanwhile turn OFF or disconnect your furnace from the power source for 30 minutes. How? Turn the Circuit Breaker that is labeled for it (usually a 220 volt). This is to allow the computer in both items time to reset. If this is getting you too concerned about the power and all have a professional from Sears do it for $100.
Sep 30, 2015 | Heating & Cooling
Date and time need to be reset everytime i charge the battery
in most of digital cameras there is a small rechargable battery or a capacitor bank used to store settings in memory for few minutes. if that battery is dead it cant hold settigns at memory.
Nov 12, 2011 | Nikon COOLPIX S570 Digital Camera
Battery life-I put new batteries in and it lasted less than 30 minutes-maybe 20 pics before the camera stated replace batteries. Is there a reset-
If you are using alkaline batteries, you should switch to rechargeable NiMH batteries. I highly recommend the Sanyo Eneloop products. You should be able to get 300 to 400 shots before you need to recharge. Get two sets of four AA Eneloop batteries. Don't mix them. They hold their charge for a year and can be recharged a thousand times.
Jul 13, 2011 | Canon PowerShot SX10 IS Digital Camera
Zoom H4 Battery Problem
I am having the same problem with my Zoom-H2. I have 2 2650 mah rechargeables, and the draw is such that 20-30 minutes of record &/or playback kills the batteries. Last night I just turned the power on and did nothing. 5 hours later the batteries were dead...
This isn't a solution. It is a reaffirmation that you aren't crazy!
Jan 05, 2010 | Zoom H4 Handy Recorder
Batteries die with 5 minutes of using.
Hi
Digital camera's eat batteries mainly due to flash being used all the time.
If you don't need to use the flash don't, it will last longer.
The best batteries i found to use with my camera are Duracell Alkaline.
Thanks for choosing FixYa!!
Jun 10, 2009 | Kodak EasyShare Z1275 Digital Camera
Battery Life
This is a typical problem with these cameras. The culprit is a failed onboard battery. The battery is for retaining the time and date while replacing the removable batteries. If you put batteries in and set the time and date- then remove the batteries for about 30 seconds- put the batteries back in- if it asks you to set the time and date again the onboard battery is no good. If you remove the onboard battery your camera will be very usable and the batteries will last 100 times longer. If you can change the batteries quickly you will not have to set the time and date because there is a small capacitor that will retain a charge, in other words it works better without the battery. I have done this to about 15 of these cameras and all worked great afterwards. You will need a precision philips screwdriver to remove the 7 screws that hold the case together. The onboard battery is small, like a hearing aid battery, mounted on the lower board just behind a piece of brownish cellophane like material. Just cut the material open and look in there between the boards and you will see it. It is mounted flat grap it with some precision long nose pliers or tweezers, wiggle it until the solder joints fail and remove it. Re-assemble and your paperweight is a camera again. If you do it wrong ,which is unlikely, you still have a functioning paperweight.
Dec 04, 2007 | HP Photosmart 635 Digital Camera
Battery life
I bought a pack of Kodak rechargeable batteries at Walmart for $15.00 9 months ago and they are still going stron - they go for about 4-5 hours without needing to be recharge, not to mention 4 come in the pack and the camera only takes 2 so I always have 2 extra ones ready.  I love this camera and use it non-stop on a regular basis (I took over 200 pictures yesterday at my daughter's soccer game) - get the rechareables and I think you will be happy.
Jun 27, 2007 | Samsung Digimax S730 Digital Camera
Camera keeps turning off
Digital cameras are very Voltage Sensitive. Using Nicad or NiMh batteries will not only , "Not" solve the problems above but will
actually aggravate the above problems for one reason.
Rechargable NiCad or NiMh batteries only produce 1.2 volts fully charged and will only give you 2.4 volts when used in pairs with this camera. This falls below the cameras desired 2.8 - 3.0 voltage requirement and will only result in about 30-40 pictures at most.
This camera requires a constant 2.8 - 3.2 volts to run properly. Kodak won't tell you this !!The camera was designed with Oxy Akaline batteries in mind.New alkalines will produce 3.2 to 3.4 volts in pairs but only for a short period of time.The issue with the Oxy Alkaline batteries is that they simply will not last very long in this camera due to its power requirements.
But there is a really great solution to the problem . You can purchase a CRV3 rechargeable Li-ion battery that fits right into this camera.
You will get a realistic 180-250 photos per charge.The Li-Ion battery maintains a constant 3.0 volts for a very long period of time
and will allow the camera to function the way Kodak originally intended it to and can be recharged. You will find rechargable CRV3 battery kits on ebay or other online battery stores at a very reasonable cost.
You can also use a Lithium Non rechargeable CRV3 battery that will give approx 250-300 photos per battery but you may
find non rechargeable Lithium batteries cost prohibitive.
I use the rechargeable Li-ION Battery exclusively in this camera and it functions perfectly since I switched. I have a pair
of CRV3 Li-Ion batteries so I always have a fully charge CRV3 ready to go.
For reference I was only able to get about 30 pictures with the high capacity 2800 Mah Rechargeable NiMH Batteries I used prior
to using the LI-ION Battery. I get on average about 175 pictures per full charge from the LI-ION Battery.
Jun 14, 2007 | Kodak EasyShare C875 Digital Camera
Drained Batteries
I use professional $70k cameras for work and it's the same type of thing. If you're not using it, take the batteries out. With my A75 I have some energizer 2200mpa rechargeable AA's and the seem to last about a month or so. If I happen to be "cranking" through pictures though (upwards of 300-500) in one sitting, it will suck them dry. The rechargeable batteries last longer than the Alkalines. I was heistant with the rechargeables but for $20 I picked up a 15 minute charger and the 2200mpa AA's, now I recommend them to everyone with a digital camera. Digital cameras eat Alkaline batteries in a hurry.
Aug 31, 2005 | Canon PowerShot A75 Digital Camera
Samsung S630 Digital Camera Logo
127 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
