Question about Frigidaire Refrigerators
Frgidaire model PHSC239DSBO icemaker will not stop cycling and water is running all over. I have removed it and defrosted it replaced it. Recent power loss with Gustav. It appears to function-but after the water is released it continues to turn and release more water. I watched it for 3 cycles and turned off 2 times.
5 Suggested Answers
  • 473 Answers
SOURCE: Whirlpool icemaker
Need to check the heater on the ice maker with ohm meter to see if it shows resistance. If no resistance then replace the whole ice maker. If resistance is good then the best thing to do is replace the ice maker module and thermostat (bimetal).
Posted on Oct 06, 2007
  • 6 Answers
SOURCE: Icemaker not signalling for water.
cheek the condenser fan.if its opration is not correct.
Posted on May 23, 2009
SOURCE: Water is not going into icemaker, I've replaced
I have a maytag side by side with water in the door, the cold water works but the icemaker doesn't. No water flow into the icemaker, it doesn't appear to be iced up. Can not tell if the selenoid works.
Posted on Jul 14, 2009
SOURCE: Freezer Defrosts and contents thaw causing water on floor
This problem will probably get worse with time. I had the same problem. After much trial and error I managed a repair that had I known, would have been solved for $42.00. The offending part is called the temperature control unit. It is located behind the light panel in the refrigerator section. (right side) The part number is Wpl 61005651. To install this takes patience and some dexterity. Anyone male or female can do it if you're reasonably handy. Remove the cover panel gently pulling the front down. The reach back with both hands and press in the rear while pulling the whole thing forward. you may want to remove the two top shelves to give yourself space. Now with the innards exposed you will need to remove five screws that attaches the assembly to the refrigerator. To do this you can remove the four screws in the top first. 2 Phillips head and two 1/4 inch hex head then finally removing the 1/4 inch hex head screw in the rear. The whole assembly will now tilt down. Gently unplug it from the two electrical connector attachments. reach over and pull the curled end of the temperature probe from the hole on the left that extends into the freezer. (it is not attached to anything) Now with the whole assembly loose move it to a comfortable work area. The temperature control unit is located under a plastic housing on the right side facing the unit or conversely, the left facing away. Reach under the assembly and pop the housing from the main unit. it is slotted into four holes. by simply pressing the hooks inwards and pushing up, presto. Uncurl the wire probe from its track paying attention so as to reuse the same route for the new. Remove the three electrical wires by pulling them gently straight off the pins. Make special note of which goes where; not too hard as there are only three. The housing is now in your hands. Unscrew the one screw holding the cover on then pop the temperature control unit out. Be sure to set trident fork unit on top in the same position as the old. I set mine to one of the extremes before removing the unit at all. This is done by moving the freezer temperature lever to one side or the other before starting the replacement. Now if you've been paying keen attention to the dis-assembly the re-assembly should be a piece of cake. Install the unit, route the probe, re hook the electrical wires on their respective pins, plug the unit into the two receptacles, push the curled end of the temperature control unit into the freezer section then replace five screws and panel cover. congratulations you just saved well over a thousand dollars. If you want pictures of how its done just email me at Nrbroderick at gmail and ill gladly provide them for you. Happy fixing.
Posted on Mar 22, 2010
Water & ice in bottom of freezer
Most likely cause is a blocked defrost drain line. The freezer has a defrost cycle which turns on a heating element below the evaporator to clear any built up frost or ice. This defrosted water should then drain through a plastic line to below the unit. Check for drained water in the drip pan or plastic moulded container over the compressor. If it is completely dry then follow the blocked drain line, clear it. If further assistance is required please provide details of What brand and Model your unit is? Hope this helps.
Feb 14, 2014 | GE Refrigerators
Ice maker stopped dispensing
Refrigerator - Icemaker Not Dispensing,or Not Making Ice Check that the feeler arm on the icemaker is in the down position and is not blocked. If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker. For more information on the causes of new icemakers not making ice. For more information on normal ice production. Side by Side models: The filter may be loaded with sediment that can cause low water pressure. The water pressure must be between 40 and 120 psi. Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production). Test the water pressure: Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate. If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place. If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced. If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter. If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator. If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly. Ice not Dispensing Due To Clumping Ice: Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons: Low food load: The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting. Lack of use: When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up. If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production. For more information on the causes of clumping cubes. If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Aug 05, 2012 | Maytag Refrigerators
Water leaking onto floor coming from under refrigerator
Their are a couple things causing that leak
1) the water valve(s) for the icemaker/door dispenser are leaking. Pull the refrif. out,remove service panel from the rear and inspect the valve(s) for leakage. Sometimes their is just one valve on certain models their is two.
2) the drain for the auto. defrost cycle in the bottom of the freezer back wall is blocked so the defrost water is running out of the freezer door at the bottom
Good luck,i hope i have able to help you stop the leak,
Aug 20, 2011 | Amana Side-By-Side Refrigerator 26 cu. ft....
Have a side by side kenmore ref. and the ice machine is not making any ice. The ice maker switch is on and I am getting water. Model on my manual reads 106.58916801. any suggestions.
Hi and welcome to FixYa. I am Kelly. Having determined your icemake is PN W10190960 , here is a link that will help you test your icemaker:
The steps are pretty straight forward and will isolate exactly which component of the icemaker / system has failed.
I would like to note that these icemakers are very reliable. They do occasionally fail but most of the time the problem is the freezer is not defrosting properly so the airflow through the freezer is blocked by ice build-up in the evaporator coils due to that defrosting problem.
Your unit has an electronic control board that controls the defrost circuitry.
If you check out the icemaker assy per the first link and still have the problem I would recommend doing a manual defrosting by unplugging the unit. Then remove the contents of the freezer section and place a fan blowing into the freezer section for just over 2 hours. This makes a water mess so be prepaired.
After the manual defrosting cycle restart the unit and reload the freezer contents. After about 12 hours check the icemaker to see if it made any ice at that point. If this solves your icemaking problem it will only be temporary if you still have an automatic defrost cycle problem. Your unit should defrost at least 3 times in 24 hours.
Thanks for using FixYa.
Apr 01, 2010 | Refrigerators
Icemaker does not fill with water
Try using an hairdryer or defrosting the unit completely , this often get rid of blockage caused by frozen lines fixing the problem.
The water lines can also be unblocked from dirt using a thin flexible shaft. This after defrosting.
If all that does not fix the problem, then you may need to check the wiring to icemaker solenoid.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 11, 2009 | Whirlpool ED5GHGXMQ Side by Side...
Icemaker does not work
If all that does not fix the problem, then you may need to replace the water valve, the icemaker solenoid, or the whole icemaker assembly.
Dec 15, 2008 | GE Profile PCF23NGW Side by Side...
Foul rotting vegetable type odor in top of Kenmore refrigerator
If the icemaker motor or heater short out it will cause a foul odor. I have never heard it described as cooked broccoli, but it can be pretty bad. Remove the icemaker and inspect the bottom of it where the heater element is and remove the white cover of the motor and look in there. You can take the three screws out of the motor module and see if anything is burned on it.
If you can rule out the icemaker, the next things to check would be the evaporator fan motor and defrost heater. Generally, if a fan motor starts causing an odor it will stop running completely and if a defrost heater goes out it will quit defrosting. It is possible, but unlikely, that something has gotten into the evaporator area and is sitting on the defrost heater so that it is "cooking" during the defrost cycle.
Check the icemaker first, it is the most likely cause of the odor. Post back with complete model number if you need further assistance and we will go through checking everything else.
Oct 24, 2007 | Kenmore 50522 / 50524 Side by Side...
Ice maker is not getting water.
check and reset the temp in the ice maker freezer coils them self's
Aug 08, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Refrigerators Logo
56 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
