Question about Kenmore Refrigerators
Kenmore model number 59652679202 side by side
Due to hurricane gustav we lost electricy for a few days...once we returned home we cleaned out the refridgerator and I used clorax to wipe down the inside...it still has an oder....any suggestions...
5 Suggested Answers
HVACRH20
  • 237 Answers
SOURCE: GE refridgerator
If the unit has an ice maker or water dispensor, etc. there's always a chance a connection is loose or a valve is leaking by. If no other water is hooked up to the refer, then the defrost cycle water that should drain down to the bottom underneath pan is what is likely. You may have to take the inside rear panels off to see if the drain line is plugged up, that would allow water from the defrosting of the coils to drip inside the fridge vice outside like it should.
Posted on Jan 02, 2007
  • 409 Answers
SOURCE: Drain pan oder
hi there,
you will have to start by removing the kickplate. which is the panel under the doors. it's held on by 2 screws. remove the screws and remove the kickplate. you should have no problem pulling out the drain pan then. you can clean it with bleach no problem.
thanks
Posted on Sep 30, 2008
  • 11 Answers
SOURCE: No ice from icemaker of Kenmore Elite model 106
I just resolved an issue with my kenmore elite side by side refrigerator icemaker (model 106).
It was expensive because I took the long road to fixing the unit myself.
My problem: No water going up to the freezer water dispenser into the icemaker but the water in front of the door working just fine.
-first thing i tried was the simplest. The Internet is clogged with this miracle fix of using a hair dryer to melt the frozen water line going to the dispenser output. This is highly unlikely for our model since the water line is protected within the refrigerator frame.
-2nd thing I replaced my water filter (thinking that there wasn't enough water pressure to trigger the solenoid valve. $40, and still no luck.
-3rd thing was I tested for voltage going to the solenoid. No voltage going to solenoid, so I wasted $30 for a new solenoid.....still no water.
-4th thing was I ordered a new IR sensor and receiver (since the reciever end is where the relay that sends the voltage to the solenoid to turn on and allow water to go up to the dispenser).
My IR sender and receiver appeared to be working flakey.
Installed, still no water. $58 BUCKS ON EBAY (EVERYWHERE ELSE $100+)
-I finally removed the freezer front little white door, I TURNED OFF THE FREEZER SWITCH SO NO VOLTAGE WAS PRESENT, removed the release latch underneath the freezer unit and disconnected, and removed the freezer unit to inspect it further.
When I removed the protective white cover that covers the mechanical wheel, I had a few parts come flying out of it. Turns out that the wheel accessories were damaged. THERE ARE NO REPAIRABLE PARTS ON THE FREEZER UNIT. I FOUND ONE ON EBAY FOR $39 BUCKS + $9 SHIPPING! $48 BUCKS, SWAPPED THE HARNESS AND BOTTOM COVER, AND IN 20 MINUTES, I WAS BACK IN BUSINESS. STARTED MAKING ICE IN ABOUT A HALF HOUR!!!!!
when in doubt, replace the freezer unit for $48 bucks! 7 out of 10 times it will fix your problems. All techs replace the IR set at the same time too which will set you back another $58 bucks.
Good luck! ;)
Posted on Mar 16, 2009
SOURCE: Defrost line blocked and dumps water in front of frig once a day
Double door Maytag. Water frozen in the bottom and leaking onto the floor. Happened before and don't wish to pay the same repair person who "repaired" it 6 months ago to come out again. What can I do?
Posted on Jul 28, 2009
We lost electric to our KitchenAid refrigerator freezer due to hurricane. Electric has been restored and we can hear the motor running but it's not cooling. It's been two days.
That's tough, sorry about issues due to hurricane. Once power was restored, unit should've started with no issues. But I fear that an electrical surge might have taken out a weak component. If lights are working, fans working and control working, but no cooling, it could be the relay/overload on compressor. It could also be a control board that was damaged. It's just hard to say. I suggests to get a qualified service tech to look at. Good Luck
Sep 15, 2017 | KitchenAid Refrigerators
Hurricane names
Mitch (1998), Katrina (2005), Wilma (2005), Ike (2008), Gustav (2008), Irene (2011), Jova (2011), Matthew (2016), Hermine (2016), Otto (2016), Irma (2017)
Sep 13, 2017 | Miscellaneous
Ice on bottom freezer
What is the model number of the unit?
Nov 05, 2012 | Whirlpool Refrigerators
Our power has been out for six days due to Hurricane Sandy. When we got power back today, the fridge wouldn't come on. Keeps tripping the ground fault. suggeations?
I am sorry for the problems you are having. I live in New Orleans so I know what you are going thru.
Nov 05, 2012 | Kenmore Refrigerators
VALSI 5,500 WATT GENERATOR WILL NOT START
All generators need to be run once a month. All things from the tank to the and including the carb will get gummed up with dried out fuel. I have a whole house generator and a 5500 watt gen set on my motor home. I keep fresh fuel in the stand alone house generator in California in case of a bad earthquake. I drain the gas after every run and keep all vehicles full of fuel just in case. Run gen sets at least once a month or pay pay pay!!
Apr 05, 2009 | Watts Onan Portable Generator - 4000 ,...
Odor coming fromback panel
you can also use bleach let it sit there for a couple of days so it will kill bacteria and odor the smell is all the meat and blood that drain down to the pan
Oct 17, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator not cooling properly
you need to turn the frezzer downso it lets more cold air into frig. and put the frig setting back in the middle,aslo vac off your coils under the frig.all this should work,if not let me know,also check to see if you have any frost buildup on the freezer walls-mike
Oct 14, 2008 | Kenmore 53642 / 53644 Side by Side...
Comp was reformated
Don't worrly Fixya will help you in findding the setup disc very easily... To download the drivers, Please click on the below link or copy the URL and paste it in your web browser.. And Select DRIVERS, and select the operating system you are using and download the drivers..
http://www.brother-usa.com/downloads/Default.aspx
Thank you......
Oct 02, 2008 | Brother MFC 420CN All-In-One InkJet...
Generator will not generate electricity.
I assume it is a hand start genset. The most common problem if it has been sat for a while is rust on the ignition timing flywheel. If you take the pullcord housing off (recoil) then you will see a big flywheel with what can only be described as a big forked prong with a couple of wires on it. This flywheel should be stainless steel and rusts when sat around for a while without use. Its job is to complete the circuit to the spark plug every time the flywheel passes the forked prong at a given spot on the flywheel, the faster the wheel turns the faster the spark hence the engine runs quicker. Clean the rust off with a releasing agent (wd 40) hey presto!!!!!!!!!!!
Sep 17, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Ice maker trobleshooting
We lost power due to hurricane Ike and now that the power is back on the ice maker is not working. Is there a reset button or what needs to be done to get it working again?
Aug 10, 2008 | Kenmore 22.0 cu. ft. Side-By-Side...
Refrigerators Logo
103 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
