Kenmore 110 washer dryer leaving water on the floor
I think it is the pump but how do i get the frount off the washer so i can see the pump clealy
  • 261 Answers
Ok if your washer is newer than 1987 then here goes. On the washer console is two clips just in from left and right edges, use a putty knife and slide it under the console at the inch mark left and right pushing slightly back on the console. After this is rolled back you will see a plug on the top for the lid switch, unplug this after the machine is disconnected from power. Now there is two brass clips that will come out using a slotted screw driver, do this by inserting at the top, not the back panel, into a square recess where this clips, push back and if right the clip pops out, note how it removes, opposite to replace using same force and palm to replace. The housing is the dog house and it will pull forward as it retains on the black frame on the base where the feet are with pegs. Once tilted towards you the house will pull out and you can start with the tub and go down, and also examine the house for water marks. The pump is below this with a hose from the tub and one to the drain attached to the motor with a clip top and bottom. Feel along the bottom for drippy water or pull the clips and pull straight out and flip as the bearing or front cover leaks 9 of 10 times. If this is the problem use part 3363394 to replace.
Posted on Sep 07, 2008
Should I buy a new washer? I have a great Kenmore, Heavy Duty, 70 Series, model 110, serial number C83193200. Yes, it was made in 1983 and now leaks water from the bottom front onto the floor.
It could be a dry rot hose or the pump could be leaking might be an easy fix it depends whether you want to repair it or spend allot of money on a new dryer are u pretty handy i could assist you on how to fix it .
Nov 24, 2012 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer leaking intermittantly while drainong
Take a look at this service manual. You model may be a little different but the process should be the same.
Nov 04, 2012 | Washing Machines
I just got a used kenmore model number 110 88752792 stackable washer and dryer. it had a 4 prong cord.I live in a travel trailer, it has a 24 inch wide space for a stackable washer and dryer that the 110...
You will need to get 230v to allow the dryer to work if your service panel has 230 you will need to get a 30 amp two pole breaker and run 3 wire #8 in size. Then get the socket and plug for the dryer. The 110 in the model number simply means made by whirlpool and is a pretty good machine but requires 230 volts to dry with heat.
Jul 28, 2010 | Dryers
My washing machine leaks when it's does the washing cycle
if the leak is at the frount of washer than you have a bad seal in water will nead to replace the pump.
Jan 17, 2010 | Kenmore 22422 Top Load Washer
Washer will not drain ALL the water out
It was the coil in the wigwag assembly. The washer was not spinning causing it not to pump out all the water
Jan 25, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 Series leaking water from bottom
I used to work for Sears as a home repair technician and washers and dryers were my specialty. Most likely the problem is with your water pump. I ran across this issue many times and what happens is people leave things in their pockets and it destroys the pump. A hair pin or coins, I have even seen socks and under ware get stuck in them causing leaks. What you want to do is tip the machine back and look at the pump. It is located right at the front of the washer with two hoses connected to it. You will want a pair of hose clamps though if you don't want water all over your floor. Disconnect the pump and look inside it for anything causing the motor inside to not work, this will cause slow draining and even leaking. If it looks clear then look for any cracks in the pump. If there is a crack then it needs to be replaced. Just call your local appliance repair place and tell them what you need. Pumps run around 30 bucks or less on average for Kenmore's. If everything looks good on the pump check the hoses that run from the pump and make sure there are no cracks or holes in the hoses. If they look good then the only thing left is the tub and the overflow tube. Chances are though that your pump is what the problem is and it is an easy fix. Good luck.
Jan 20, 2009 | Kenmore 22422 Top Load Washer
GE WCSR2080B4WW - After wash cycle the washer does not spin and..
your washer must drain to may have a blocked or failed get to it thru the frount.use a putty knife between the lid and the frount ,push the comes up take frount off.pump has two hose .pumps white or tan smaller.God bless,tom
Jan 01, 2009 | GE WSM2700W Unitized Spacemaker Washer and...
if you are using a rubber drain hose look for a kink for flattened area this could be restricting flow out of washer replace hose with the plastic hose that comes with it..also ck hoses and pump for restriction ( socks ,thongs) lastly remove pump and ck impeller for severe wear impeller should be almost same diameter as pump case if it's a lot less replace pump
Aug 29, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Duet washer had an F2 problem: Plugged water pump. I have emptied the water pump. Now the washer will not come on.
check that the frount bottom interlock switch is in place and closing correctly it will be on the frame of the frount where the frount panel attaches
i would check this first
May 05, 2008 | Washing Machines
The rubber seal on the kenmore elite he 4t front loader has a rip and water spills on the floor how do i repair it.
remove the top of the dryer, the bottom assess plate the console the frount panel the fbric despenser dwawer, unbolt the door latch best to remove the door from the frount panel pull arround on the lip of the seal the part that is holding it to the frount panel
once the frount of the seal is loose from the frount panel remove the frount panel and set aside
remove the spray tube from the rubber seal center top of seal
remove rear clamp
reinstall in reverse
Apr 25, 2008 | Washing Machines
Washing Machines Logo
Top Washing Machines Experts
