Question about Amana AOGD2750 Stainless Steel Gas Double Oven
Double oven willnot light
I have a amana aogd2750 oven bottom works fine top ignighter glows but no gas please help.
Tyler
kls1@optonline.net
    Novelist:
  • 166 Answers
Peace,
ngafm at your service,
It sounds like a bad igniter in that oven or a bad gas valve restricting the gas flow in that particular oven.
Unfortunately this will require hands on service!
How old is this wall oven?
ngafm
Please give me a good rating before you sign of!
If the appliance is 10 years old or more you may not be advisable to put good money into bad! New appliances are so much more efficient today that they can save you a lot of money in energy!!!!
You need a hands on tech for this repair!
Posted on Sep 07, 2008
How to test amana bake igniter
bad control board if ignitor works on broiler
Jan 24, 2013 | Amana AOGD2750 Gas Double Oven
No flame
when this happens it is usually because of a faulty flame/gas safety valve.
Sep 08, 2008 | Amana AOGD2750 Gas Double Oven
The to oven bake doesn't work but the top Broil works. What ever brings on the igniter for the bake isn't working because I get ne power to the egniter. I don't have a wiring diagram to check any futher.
I replaced my Amana Gas wall oven Model AOGD2750E Lower Oven bake Igniter and temp sensor but still not working. I'm Thinking maybe the relay module is at fauly, Any suggestions, I need help!. Thanks
Jan 27, 2011 | Amana AOGD2750 Gas Double Oven
How do I light my Jennair gas oven? The burners are working fine but oven will not turn on. Igniter was just replaced.
You need a new gas regulator on this oven to get the oven to work properly. This is a simple repair and can be performed by you!
Oct 20, 2009 | Amana AOGD2750 Gas Double Oven
Ovens do not come up to set temperature
most common issue wsith these gas wall ovens is faulty ignitors, i would reccomnd replaing the ignitor(s). that being said i wouuld also reccomned a servicer with experience on this model for they can be a more tricky then ohter ranges out there, and the possiblity of "shorting out" adddiont al parts is higher on this model! and no one is currently producing a double self cleaning, full sized gas wall oven, so id hate to see you ruin this one!!!
Feb 16, 2009 | Amana AOGD2750 Gas Double Oven
How do you light a gas oven
Chances are your hot surface ignitor is bad. Take off the bottom panel inside the oven you will have to removes grills also. You will see a center beam under the panel that is where the flames of your burner are. The hot surface ignitor is right there at the start of the burners. As a test turn the oven on and notice it hot surface ignitor glows. If it didn't glow then it needs to be replaced. Easy fix only held on by two small screws 1/4 size nut runner and two wires. You will have to cut the wires as they run back into the back of the oven. The new one just take the wire nuts that come with it and attach. Don't make the wires too short as you will need the length. let me know how it goes ken
Jan 11, 2009 | Amana AOGD2750 Gas Double Oven
Bottom oven won't turn on;
85% of these are usually the ignitor getting week and not allowing the gas valve to open prideapplianceser@sti.net
Dec 31, 2008 | Amana AOGD2750 Gas Double Oven
Replacement glass door
all my online part lookups also claim NLA. keep looking though cant imagine they're all gone everywhere
Mar 06, 2008 | Amana AOGD2750 Gas Double Oven
Top oven bake igniter comes on, but gas does not.
Check the voltage on the 2 wires going to the oven gas valve. If you get 120v when the ignitor is on with no gas coming out, you have a bad gas valve. If you get voltage, but it is not much, it is the ignitor. The ignitors don't burn out completely on the ovens, they just get a little dim and no longer ignite the gas and eventually will not turn on the gas valve
Dec 19, 2007 | Amana AOGD2750 Gas Double Oven
Amana AOGD2750 Stainless Steel Gas Double Oven Logo
165 people viewed this question
Top Amana Ovens Experts
Dan Webster
Dan Webster
Oloyede Monsuru
john mabry
Are you an Amana Oven Expert? Answer questions, earn points and help others
