Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Water Filter location
I purchased this unit from a friend. Can you tell me where does the water filter cartridge go, and if I can use replacement filters from Home Depot/Lowes
  • 725 Answers
The filter is in the toe grille under the freezer door ...it is a filter pn#4396508 you should be able to get it at Home Depot/Lowes
Posted on Sep 06, 2008
Does the b60 have filter and were is it
The filter assembly is several inches tall, with a basket-like holder for the cartridge at its base. The unit snaps in place over the outlet in the base of the water reservoir.
Lift and remove the cover of the water reservoir, which is located on the left side of the coffee maker.
Turn the filter unit's round replacement date dial to two months in the future. This offers a reminder of when it's time to check and replace the filter.
Open the cage at the bottom of the filter assembly. Insert the soaked and rinsed filter cartridge, and then snap the cage closed.
Position the filter assembly directly over the water outlet in the base of the reservoir. Push the unit down slightly until the assembly locks into place. You should feel it click into position.
Oct 06, 2014 | Keurig B60 Coffee Maker
Where is the water filter frs24wscb
Good Afternoon Friend,
I understand you want to know where the water filter is located on your Frigidaire refrigerator, model# FRS24WSCB. The water filter is located in the top back right-hand corner. To change filter follow the instructions below:
It is not necessary to turn the water supply off to change the filter.
1. Set ice maker lever (wire signal arm) to the OFF (up) position.
2. Hold filter cup firmly, and unscrew counter clockwise. (Some water could leak out as you remove cup. This is normal.) Filter cartridge should come down with cup. If cartridge remains in housing, pull down gently, while twisting filter back and forth.
3. Empty cup of any substance.
4. The large o-ring that seals the filter system sets in the o-ring groove down inside the cup. Should the o-ring fall out during filter cartridge replacement, simply place it back in the groove prior to screwing the cup back in place. If the o-ring becomes damaged, you will need to order a new one from the Consumer Assistance Center.
5. Discard old filter cartridge.
6. Remove new filter cartridge from packaging, and install.
7. Place filter cartridge in cup. The end with the small o-ring should be up, out of the cup.
8. Screw cup, with filter, back onto housing. Do Not Use Wrench To Reinstall Cup. Filter cartridge will self-align as cup is tightened. Be sure cup is completely tightened with PureSource Plus Logo facing outward. Do Not Tighten Past Stop.
9. Set ice maker level on the ON (down) position.
10. Check for leaks. Open refrigerator door. Wipe any water drops from the filter cup. Run a glass of water. If there is a leak, unscrew filter cup, and reinsert the filter cartridge. Check placement of large O-ring. Reinstall filter cup, making certain it is tightened completely.
11. To condition filter system and purge air from water line, run several glasses of water through water dispenser. This will also assure that the purest water possible is stored in water tank.
I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 01, 2014 | Frigidaire FRS26R4A Side by Side...
After i change the water filter de button of water still red
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
green when the system is reset.
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
Jul 29, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Where is the water filter for the ice maker located on a GE tfx24zr side by side refridgerator located
Filters situated in the interior liner of the refrigerator compartment of GE-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Remove the old filter by grasping it and slowly making a one quarter turn to the left.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard used filter.
Water by Culligan filter cartridges need to have a water filter adapter installed. This is a one time installment, and once you have this adapter installed, it stays in the refrigerator for all future filter replacements. If your refrigerator already has this adapter in place, do not remove it to replace the filter.
Smart Water filter cartridges do not require the use of the water filter adapter. If for some reason your refrigerator has an adapter in place already, you will have to remove it before installing a Smart Water filter cartridge. The adapter is removed in the same manner as the filter itself: with a gentle quarter turn to the left.
Remove the new filter from its packaging. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
Fill the filter with water from the tap, and then line the arrow on the filter up with the arrow on the cartridge holder inside your refrigerator.
The filter automatically pulls itself into position as you turn the filter to the right and lock it in place. Be careful to not over tighten the filter into position.
Run water through your dispenser for about three minutes to clear the system. Keep in mind that a newly installed water filter could initially cause water to spurt from the dispenser.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Hope this was helpful to you. Thank you for using fixya.
Jan 26, 2011 | GE Refrigerators
Where is the water filter located and how do i replace it.
The water filter is located in the fresh food or fridge side of the appliance, at the rear - in the upper right hand corner.
To change the filter, open the fridge door, clear the top shelf and grasp the filter. All that is needed is to turn the filter to the left about a 1/4 turn for it to drop down. A few drops of water may spill onto the shelf. To install a replacement, remove the protective cover (shown as a red cap above), and position under opening for filter. Gently push upward while turning the filter to the right. The filter will pop in, and as you turn about 1/4 of the way around, it will be drawn up a small amount until seated. At this point it will no longer turn any further.
More info about the filter is below (taken from the manual).
Please rate this reply - thanks!
The water "Filter Indicator" light
• "Filter Indicator" light lets you know when it is time to change your water filter cartridge. The light
will change from green to orange. This tells you that it is almost time to change the current cartridge.
It is recommended that you replace the cartridge when the light changes to red. (see "Install the water filter" section for more information)
• If you install water filter, throw away the first six glassfulls of water filter, or until water flows clearly to flush impurities in the water supply system.
Using the dispenser without the water filter
• You can not use the water and ice dispenser without a water filter cartridge because the water line
blocks at water supply.
Ordering replacement filters
• To order more water filter cartridges, call 1-800-SAMSUNG and ask for accessory Part # DA29-
00003A or contact your authorized Samsung dealer.
Jan 04, 2011 | Samsung RS265LABP Side by Side...
I CANNOT REMOVE THE WATER FILTER LOCATED IN THE UPPER RIGHT INSIDE THE REFRIGERATOR. I TRIED TO TURN IT COUNTER CLOCKWISE BUT IT WILL NOT COME OUT. THE PART NUMBER ON THE FILTER IS UKF8001. ANY...
  1. 1. Look for the water filter cartridge. On some refrigerators it is located in the back, upper right corner of the refrigerator compartment. Some refrigerators have it in a tubular-like slot under the door and accessible from outside.
    2. Remove the old cartridge. On the cartridges that are located inside the refrigerator, the cartridge should be slowly turned to the left. Don't pull down on the cartridge. A small amount of water may drip. On the type that are under the door, follow the arrow labeling for the direction to unscrew it. Slide it outside.
    3. To replace a filter, fill the replacement cartridge with water from the tap. This will speed up water flow after installation. Run water from the dispenser for three minutes after replacing a filter to clear the line. Refrigerators with a filter warning light require you to reset the light. Press and hold the Reset Water Filter button to do that.
Jan 18, 2010 | Refrigerators
Is there a filter on the water for my Refridgerater Model #FRS20WNF. If so where can I buy a new filter and how do I replace the existing one? The water is starting to taste funny.
HI. This unit is not equipped with a water filter. If there was a filter, it would be located on the front/lower grill area(bottom part of your unit). It would be accessible there.Unfortunately, this unit dose not have a filtration system.
Oct 22, 2009 | Frigidaire Refrigerators
Water not coming out of the dispenser. Ice maker
Check the unit for an in-line water filter that may be plugged. Check your manual for the location and procedure to change the filter cartridge.
Aug 23, 2009 | Refrigerators
How to remove water filter on Whirlpool ED2VHEXVQ00
the filter is located in the front of the unit just below the freezer door whirlppol has 2 filter options one has a push button next to the round filter cartridge that whne pushed releases the filter. the other option is a twist out filter simply turn 1/4 tun counter cloclkwise and the filter will come right out.
after replacing filter run aprox 1/2 gal of water to clear air and remember to reset filter monitor according to your owners manual
Jan 21, 2009 | Whirlpool ED5VHGXM Side by Side...
Kenmore Fridge - Bad Testing Water
Your refrigerator definitely has a water filter. If you have gone 5 years without replacing the filter, you and your family have probably been drinking contaminated water, for some time. Water filters should be replaced every three to six months. On some refrigerators, and in cases of higher water consumption, the filter must be changed every 60 days. Sears sells replacement filter cartridges for Kenmore refrigerators.
The water filter on your refrigerator is located at the front base of the unit, in the grille, below the freezer door. There, you will see a round cap. Turn the cap counter-clockwise, until the handle is vertical.Then, pull it out of the grille. The filter cartridge is attached to the cap. After removing the cap and filter, slide the cap off from the existing filter cartridge. Slide the cap on to a new cartridge, and re-insert with the cap handle in a vertical position. Push it in, firmly. Then, turn the cap clockwise, until the cap handle is horizontal.
Oct 24, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
145 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
