Question about Refrigerators
Replacement parts side by side Frigidaire FRS26ZRG ice collection bin and augger
  • Refrigerators Master
  • 19,396 Answers
I am trying to install a new heat motor on a frigidaire refrigerator model frs26zrg. I am having frost build up on front side of ice maker, assuming its from flapper not closing all the way.
I assume your frost is at the front of the ice bin? If so, your correct. Room temperature air is leaking in to a 0 degree environment and causing frost build up. First, I would see if the ice door closes 100% without spring by pressing your finger on the door. I've had bad ice doors that were warped. Next, inspect supporting rod and spring and make sure they look ok. An eye test should suffice. Next, without heat motor, the spring should keep door shut 100%. See if that helps, good luck!
Sep 18, 2015 | Frigidaire Refrigerators
Which numbers give the coldest setting in the fridge section of the Frigidaire Refrigerator
THE COLDEST SETTING IN THE FRIDGE SECTION OF THE FRIGIDAIRE SIDE BY SIDE FRIDGE, MODEL # FRS26ZRG IS # 6
Oct 21, 2014 | Frigidaire Refrigerators
Ice Maker leaks water into the ice collection tub.
The ice maker is not metering the water correctly and it will need to be replaced. Here is the part to order.
Jul 06, 2013 | Frigidaire FRS26R4A Side by Side...
Changing ice maker for fridadire part # FrS26zrg
Can you add water to the ice maker from tap water, Allow the water to freeze and if the ice maker drops the ice into the ice bin and then does not refill with water will point to your as the problem=> 218658000 Water Inlet Valve
If the ice maker sits there with ice and does nothing the problem will be the ice maker=> 5303918277 Ice Maker Assembly
I will be here should you have questions, Thanks Sea Breeze
Dec 08, 2012 | Frigidaire FRS26ZSG
Icemaker is making ice but the ice dispenser is not working
Check the ice storage container. The ice dispenser will not dispense ice until the first supply ice has dropped into the ice storage container.Remove excess ice from the back of the ice container. Make sure ice cubes are not jammed between the ice maker and the back of the ice container.
The auger won't engage or turn to dispense ice.Remove the ice bucket and with a hair dryer warm up the inside where the fork is that turns the auger in the bucket and try it and if this does not help then you will have to replace the auger motor ,, chances are the motor is just froze up .--------
If there is nothing jammed then try this./Remove the ice bin out.And then clean the ice bin.
Rotate the auger with your hand.If its hard then there is problem with auger motor.If the auger is not rotating fine then its faulty auger motor or the auger motor is frozen,if you notice ice getting collected there.
Take a hair dryer and blow hot air on the auger motor for few minutes.Take care you dont blow hot air continuously.
But if that is not helping then disconnect auger motor connecting wire wait for 2 minutes clean the connector and reconnect the connector back and see.If that is not helping at all.Then,replace the auger motor.
To see how auger motor looks.Please click the link below:---
http://www.appliancepartspros.com/part_details_lgimg.aspx?part_id=3965455&image=0
You can get required parts from sears part direct online site or from repairclinic.com site.
This will help. Thanks. Helpmech.
Feb 21, 2011 | Frigidaire FRS26H5AS Side by Side...
Frigidaire ice maker always crushes the ice
Solenoid that switches blades from crushed to cubes is most likely not working and should be replaced
Sep 05, 2017 | Refrigerators
Ice maker stuck on crush, continues to crush ice when cube button is pushed.
Remove ice bucket,check solonoid on back wall behind bucket may be stuck in up position pull down and recheck dispencer.
Jul 14, 2009 | Frigidaire GLHS66EE Side by Side...
Frigidaire side by side ice maker, water and ice dispencer inop
It would depend on the age of the refrigerator whether repair is economical. If the refrigerator is under ten years old repair it. If it is over ten years old you have to consider how much life is remaining for the refrigerator. Burnt smell source must be located because that is the key to your problem. It could be a simple matter of replacing the switch in the door.
Jul 05, 2008 | Refrigerators
Frigidaire Ice Maker not working
sounds like you got a water valve problem. it will be found at the lower back side of fridge where the water hook up is at.
Mar 14, 2008 | Frigidaire FRS6R5EMB Side by Side...
Refrigerators Logo
420 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
