Ensure TV's 'mute' is not on. use buttons on TV to adjust volume up and down. if not working properly, you may have a volume adjustment on your cable modem which needs to be turned up to maximum. if sound works, all is well. if sound still not acceptable your TV needs repair.
if TV buttons adjust volume OK, and your remote for TV does not properly adjust volume, try fresh batteries. if
remote still not working properly, you can buy replacement on EBay or try a genaric remote from a dollar store. also, i may have an extra remote for you.
SOURCE: Samsung 40 no picture
I bought a 40" LNT4061F Samsung Flat Screen 02/15/08 and 10 days later the picture went out on me. I was just watching TV when all the sudden the TV turned off on its own. I turned it back on and got a blank white screen. I couldn't even get the menu to appear. The sound was there, but no picture. I called Samsung for help and they said that they would have to send out a service tech. This all happened Sunday, the 24th of February. They said that I would hear from a service tech in 24 to 48 hours. Well 24 hours is up, I hope I hear from them tommorrow. I'll give an update when something happens so that others may know what to expect.
SOURCE: samsung 46 '' HDTV 1080P --------no sound
what is the complete model number of your tv?
does the volume control display pop up with a headphone or speaker sound on tv mode?
SOURCE: Samsung LE26R7 LCD TV I get
Hi,assuming you have the volume up on your receiver, and on your TV, the
problem must be in either: The A/V sockets on your TV = try another
set of sockets (eg: AV1, AV2, AV3,etc)
The scart-to-AV lead supplied with the receiver = take it back to your supplier.
The receiver itself = take it back to your supplier.
Note,
though, that some new TVs have so many A/V, Component, S-Video sockets
on the back that it is hard sometimes to work out which audio sockets go
with which video socket, so you may have (for instance) the yellow
video plug in AV1 while the red & white audio plugs are in AV2.
Hope you're able to sort it out.
Also, check the 'mute button' if your using those cheap black scart leads,
please get rid and buy better ones as they are only to get you started
and wear out quickly hence your problem..
You can do the old Sky trick of pulling the power cord out for 30 seconds and that did the trick.
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if it
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
