Question about Whirlpool LER3624JQ Electric Dryer
Power Suply Cord
The supply cord power and receptacle over heated. Where can I find a replacement power supply cord?
  • HFC40 Sep 06, 2008
    Dryer is a Whirlpool LER3624JQ1.
  • HFC40 Sep 10, 2008
    Much thanks. Bought a new receptacle and the power supply cord at Home Depot. Installed both in about an hour.
  • 706 Answers
If the cord is the ONLY item you need and NOT the terminal block in the dryer, then Home Depot sells replacement cords with a molded plug attached as well as ring lugs on the opposite end for terminating them on the dryer block. You'll need to know if you are using a 3-prong or 4- prong set up in order to get the correct cord. Hope this helps..
Posted on Sep 07, 2008
Whirlpool AW041608 Washer not functioning. Power supply is good, but no lights on
Power supply???
Are you referring to receptacle it's cord is plugged into?
Or did you open it and check for power where the washers power cord terminates inside the washer?
Nov 12, 2014 | Washing Machines
My dryer will not heat. was working fine but i moved and had to rewire a new cord on then when complete it will turn on but no heat. Is there a chance the thermal fuse needs replaced?
Verify your voltage at the wall receptacle before assuming you have a dryer problem. You should be reading 220-240VAC across the two HOT (left and right) terminals. If the voltage is not correct, you may have a breaker tripped somewhere. Most homes utilize a single dedicated 220VAC breaker for the dryer circuit. However, some older homes, may use two 120VAC breakers. So, if you are missing half your voltage, you may have a breaker tripped, or a bad receptacle.<br /> <br /> If the voltage IS correct, you may not have your power cord installed correctly. Since you mentioned you changed the power cord, you may want to go back and verify how you have it installed. The following link explains how to properly install an appliance cord to your dryer:<br /> <br /> <a href="http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord">http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord</a><br /> <br /> <br /> Make sure you have the wires correctly terminated at the terminal block in the back of the dryer.<br /> <br /> <br /> If the power cord is installed correctly, and the voltage at the receptacle is correct, UNPLUG the dryer and check the continuity of the power cord. Perform a resistance check from end to end to ensure the cord isn't broken.<br /> <br /> NOTE: The reason a dryer will still run with half the input voltage, but won't heat, is because the drive motor only uses 110-120VAC to run. This voltage is tapped off the source voltage. The heating circuits, however, require the full 220 service to work.<br /> <br /> If you have any questions about these procedues, please post back with your MODEL NUMBER and let me know. I hope you find this helpful.
Aug 24, 2010 | Whirlpool Dryers
SAMSUNG LN52B610 TV TURNED OFF BY ITSELF. CANT TURN TV ON. NO RED LIGHT ON TV FOR POWER. OUTLET WAS CHECKED AND HAS POWER. CORD IS IN GOOD CONDITION. PLUGS FIR SNUG IN...
Hello.
If you have multimeter available you can actually check if voltage present at the end of your power cord first.
If it's OK than you have to remove back cover from your TV and locate power supply board. It's very easy - it should be next to the power cord receptacle. First look for capacitors that have bulged tops instead of flat ones. If you locate any - replace them and check if it's going to take care of problem.
Right next to receptacle connection is fuse located and you have to check if it's open. Replace it if needed. If new fuse got blown right away - you have short in power supply board. If fuse is OK - connect power cord and using multimeter try to figure out if 5V is supplied from Power supply board to the main board (the one that have all inputs attached to it). If 5V is present but power LED in front of the TV is still dead - you could have problem with main board.
Best regards.
Russ.
Aug 17, 2010 | Samsung LN52B610 52 in LCD TV
Hoover 0910dryer not heating. element replaced not long ago
Hi, the possible causes are: Possible Causes: The wall receptacle, power cord (plug) and electrical supply must be in good condition and wired correctly for the dryer to heat.
  • Supply Issue - Loose or missing connection on supply wire from circuit breaker.
  • Plug Issue - Loose or missing connection in the wall. Defective, worn or damaged wall plug.
  • Cord Issue - Loose, missing or incorrect connection of the power cord to the dryer terminals.
If gas dryer and does not heat, Gas Dryer heats with a gas burner, make sure the gas supply line valve is open.
Also, for electric dryer,
Electric dryers require two 30 amp breakers or fuses in the house electrical box to run and heat. If one breaker is tripped or one fuse is blown, the motor, the timer and lights can work but the dryer will not heat.
May 01, 2010 | Washing Machines
HP a820n No Power-up after City Power Failure
You have a bad power supply. It is not an expensive fix. Remember HP's take HP power supplies. When ordering either look on ebay for your model or order from part supplier.
Aug 22, 2009 | HP Pavilion A820n (PP165AA) PC Desktop
Not charging when the charger cord is in
You either have bad power transformer or a bad opwer receptacle on the laptop.
You can test the power supply with a multimeter. If it gets the correct voltage, your receptacle on the laptop is broken. Repair requires replacement of the motherboard, and probably will not be cost effective.
Jun 23, 2009 | Dell Latitude D600 Notebook
Wont start till I pull on the cord to make connection.checked cord with volt meter,its o.k.help. stampvs@yahoo.com
If you have unplugged the unit and performed a continuity (resistance) check from the end of the power cord to where it connects to the terminal block at the back of the appliance, then the next logical step is to perform a voltage check of the wall receptacle itself. If the voltage at the receptacle is good, but you are having connectivity issues with the appliance plugged in, the receptacle terminals may have become loose, or you may have a power cord that has a loose or broken wire. This intermittent connectivity can cause the receptacle and/or power cord to heat up and cause a fire. With the appliance unplugged, connect an ohmmeter to either end of the power cord and perform a continuity check. Move the power cord to see if the readings are constant. If you have intermittent resistance readings, you have a bad power cord. If the power cord still checks good, then I would recommend having an electrician check your wall receptacle before using the appliance again. If you still have questions, let me know. I hope this helps you.
Jun 19, 2009 | Frigidaire Electric Dryer
Duet 4.4 Washer (not steam) power cord too short
Hi, you might be able to find an 8 foot dryer power cord at your local building supply or hardware, or electrical supply store. It will be labelled for a dryer. First look at the dryer receptacle. The cords come in two types, 3 or 4 wire, so get the one that will match youyt receptacle. The wirte should be # 10 minimum.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hot leg of power supply cord melted
This is almost positively caused by a poor electrical connection. If the connections at the cord to the dryer are good and tight, check the receptacle that the cord plugs into. Turn the breaker off, remove cover or receptacle, and tighten all connections. If necessary, replace the dryer receptacle along with installing a new cord.
Dec 11, 2008 | Dryers
Dryer Cord melted....
The power cord overheats and melts due to a failing power cord receptacle (the contacts loosen over time). To correct this problem, the receptacle and power cord should be replaced.
Jun 18, 2008 | Dryers
Whirlpool LER3624JQ Electric Dryer Logo
202 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De GO PATS
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
