Question about Kenmore 24032\24036 Top Load Washer
Kenmore Elite Catalyst beeps all the time
I bought this used from an applaiance shop and just recently it started beeping all the time and coming on by itself and then it would just beep. Now it won't come on at all. Is there anyway to fix this??
  • Anonymous Nov 29, 2008
    I have the same exact problem! Were you able to fix it?
  • yen_yen7 Nov 29, 2008
    I have the same exact problem? Were you able to get your washer fix?
I have the same problem. My machine beeps through the whole washing cycle, then at the end of the cycle it stops. All the lights comet on with 10 min on the display.
it does start to beep for no reason. in the middle of day or night.
any suggestions would be appreciated.
Posted on Nov 21, 2008
  • rio_grand Dec 02, 2008
    I don't get any error message, but my machine did stop the beeping FOR now. Until next time it decides to act up. I think it might be a short in the panel. That's my guess, but I am NO expert by any means.
    Novelist:
    Champion:
  • 261 Answers
Probably don't have an error code as this one gives a code only in diagnostic mode. Sounds like one of two problems, a control board or a ccu. On that console there are three screws on the back recessed at the sides and middle, back these out and flip the console over onto the lid of the washer. See the cable connecting them? First unplug the washer, second unplug the console from the gray box on the right, once done plug in the washer, you should here the water, rinse, door lock and tub turn in sequence. If this happens replace the console board. A parts store can order this from your model and serial number.
Posted on Sep 10, 2008
  • 116 Answers
Does it give a error code? f (something) ?
Posted on Sep 07, 2008
KENMORE ELITE FRONT LOAD WASHER, NO DISPLAY IS ON AND WHEN YOU PUSH THE START BUTTON IT JUST BEEPS ONCE and that is it. Thanks Craig..
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 13, 2010 | Kenmore Elite 45986 Front Load Washer
I have a Kenmore Elite washer, Model 110.20096993, it starts beeping with about 10 mins left in the cycle and shuts off. Any thoughts?
I have the same model - it displays 10 minutes and keeps beeping in series of 3 (beep beep beep...... beep beep beep... etc..) ran through a cycle successfully but kept beeping like that the whole time. I unplugged it for 10 minutes but had the same symptoms after plugging it back in. I unplugged it for 24 hours, and that seems to have cleared the problem up.
Jun 12, 2010 | Kenmore Washing Machines
I have a kenmore he5 electric dryer. We have
I am having the same problem. I think there is a design problem. They have tried to fix mine 3 times (replacing the dryer with a new one on the first try!) My dryer is only years old. I'm so disappointed with Sears and Kenmore.
May 23, 2010 | Kenmore Elite HE4 Electric Dryer
Have Kenmore Elite Catalyst Washer showing F3.
I have a top load Kenmore Gold Catalyst Cleaning Action washer that is stuck on permanent press mode. The digital display reads 8 min. and will not turn off or clear.When it is turned on the, the timer goes to 37 minutes and beeps repeatedly through all cycles. It will not clear even when I unplug it. How do I fix this annoying thing!!? Thoughts please.
Bill
May 22, 2010 | Kenmore Washing Machines
Kenmore Elite Catalyst Washer Keeps beeping and displays 10
I'm not sure if you've solved this already but our Kenmore Elite washer had a similar problem that got worse. It ended up being the whole touch panel had to be replaced. I was able to diagnose and replaced it myself with help from the Tech sheet that is underneath the touch panel. Our Kenmore Elite dryer also had to have this paenl replaced several years ago when it was fairly new. Hope this helps.
Sep 08, 2009 | Kenmore 3.2 cu. ft. Top Load Washer
I have a kenmore oasis elite it beeps all the time and flashes F2
Code F2 means a stuck button. I removed the interface and lightly sprayed each with contact cleaner. So far this is working. The interface costs about $160 and contact cleaner, $10. Good luck.
Mar 18, 2009 | Washing Machines
Kenmore Elite Trio Frige...Beeping three times in a row suddenly
this unit has a history of the light circuit failing and it will cause the lights to either stay on or off. if they stay on, it will melt the housing around the upper bulb area. it has a recall and should be covered by sears for no charge. it is the control board failure and has a sticking relay for the light circuit, needs board replaced.
the 3 beeps are the unit thinking it has a door open. turn off the alarm on the door control board and call sears 800 # for repair.
Dec 25, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Beeping start button
possible stuck button on inter face ,, this sounds like kenmore oasis dryer
Oct 28, 2008 | Kenmore Elite HE4 Electric Dryer
Dryer isn't working
I had success.  I found the manual....unplugged the dryer, and rotated the inside drum several times to check for any coins or small objects.  I did not find anyything, but if something small was lodged it is not hampering the dryer.  I plugged it back in and it worked right away...
lizzardhips
Oct 26, 2008 | Kenmore Elite HE4 Electric Dryer
Beeping Dryer!
Hi, the the glowing igniter does not functioning need to replace / the sensor tip will send signal to computer box that the glowing are busted.
Jan 18, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 24032\24036 Top Load Washer Logo
394 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
