Question about GPX DV7500 System
Progressive Scan Mode Resetting
Hi, Accidentally I had set my DVD player GPX dv7500 to progressive scan mode. Now the video output is no longer visible on my TV. Can u pls. let me know how to reset this back to the interlace mode? Thanks RR
Hi, Open the CD and press return on the remote to reset it back to Interlace mode. Thanks Annarr
Posted on Jan 14, 2006
  • JOhn
    JOhn Oct 30, 2014
    I had the same problem and it worked perfect. Thanks!
How do you get higher than 480p resolution on playback?
Hi Chuck, I copied this from the MWD7006 manual - I hope it helps.
If your TV is compatible with 525p (480p) progressive scanning and you want to enjoy that high quality picture, you must use Component Video cable connection and progressive scanning mode.
To set the mode, set "PROGRESSIVE" to "ON" in SETUP menu, so that the "P-SCAN" indicator on the front panel lights up.
When "PROGRESSIVE" is "ON", video signals from the unit's VIDEO OUT and S-VIDEO OUT jacks will be distorted or not be output at all.
If your TV is not compatible with progressive scanning, use this unit in interlace mode and set "PROGRESSIVE" to "OFF" either in SETUP menu, or by pressing and holding [PLAY B] on the front of the unit for more than 5 seconds, so that the "P-SCAN" indicator on the front panel lights off.
Download Magnavox MWD7006 Owner Manual
Jan 25, 2014 | Philips Magnavox MWD7006 DVD Player
Hi, I've a small problem cocerning this dv-363 player. I accidentally set it to 'progressive'. Now I cannot undo. I tried holding the buttons on remote and on machine itself, still not working, can you...
Progressive Scan is a menu option relating to video output of this player. Assuming you have the original DVD remote, this should be easy.
* From the user manual (pages 50-51 of the pdf document):
About progressive scan video
Compared to interlace video, progressive
scan video effectively doubles the scanning
rate of the picture, resulting in a very stable,
flicker-free image. Progressive scan video is
available only from the component video
output.
If you connect a TV that is not compatible
with a progressive scan signal and switch
the player to progressive, you will not be
able to see any picture at all. In this case,
switch everything off and reconnect using
the supplied video cable (see Easy
connections on page 14), then switch
back to Interlace. Switch the player to
standby then, using the front panel
controls, press STANDBY/ON while
pressing 'back to Interlace.
Hold these 2 buttons together for about 10-15 seconds or so, but only while the player is in standby mode. *
If you have lost the manual, you may be able to download the user guide (as an adobe reader (pdf) document) from:
http://www.retrevo.com/support/Pioneer-DV-363-K-DVD-Players-manual/id/385bh937/t/2/
(it will ask you for an email address prior to downloading - use a blank address if possible and enter the security code in the fields then save the document)
If the above suggestion does not switch it back to interlace, you will need a TV with progressive scan function to enable you to access the player's on-screen menu and in 'Initial Settings' 'Video Output' 'Component Out' section, select 'Interlace'. and press OK from remote as required.
Either way, it should NOT require a workshop service, and is simple enough to do at consumer level with the right TV type.
Mar 05, 2011 | Pioneer DV-363 DVD Player
I was using my dvd players component outs for a year but my hi def tv died so when I hooked up my old tv to the single video out I can't get any picture out of it. I think I need to get into dvd player set...
If its an old Sony dvd player then check Progressive Scan button at rear or some may have it on front to turn off to get composite video output (yellow video out)
And if it does not have any manual switch for progressive scan then turn off dvd player by pressing power button on its remote control, press 3, 6, 9 on dvd remote and press power to turn dvd player On.
That will turn off / disable progressive scan mode and you will get video output from yellow video out jack.
Jul 31, 2010 | Sony Televison & Video
Cannot turn off progressive scan mode on blue screen to play dvd
If you have not already seen this or done it - it worked for us:
On page 18 of the user manual under Progressive scan there is a Caution which says - If you set Progressive Scan to On in error, you must reset the unit. 1) Remove any disc from the unit and close the disc tray. See that "dISC " is displayed on the display window. 2) Press STOP (9) and hold it for more than five seconds before releasing it. The video output will be restored to the standard setting and a picture once again be visible on a conventional analog TV or monitor.
May 20, 2009 | Zenith XBV442 DVD Player/VCR
Turned progressive scan on, can i turn it off without being able
Try these methods for resetting the scan on your dvd."To reset the VIDEO OUTPUT, turn Off the player, turn back On, open the disc tray and press and hold the Stop button on the player for 10 seconds to reset the scan mode." The Reset procedure doesn't seem to work on all versions but you can sometimes get a usable B&W picture allowing you to get to the menu and change the settings by connecting the composite video input of your display to the Red Pr/Cr or Green Y component output jacks on the rear of the cabinet.
You can also go into the Menu and set it blind with the following key presses on the Remote:
1. With the unit Stopped, press Setup.
2. Press Enter.
3. Press the Down Arrow 3 times.
4. Press the Right Arrow Once.
5. Press Enter. Hope this helps you with your problem
Apr 14, 2009 | Cyberhome CH-DVD 300 DVD Player
Magnavox MDV560VR DVD/VCR combi
f you accidentally set Progressive Scan to ON (within
Analog TV), press STOP 9 for five seconds to restore the
picture to normal operation.
Aug 13, 2008 | Philips Magnavox DVD/VCR Dual Player
Progressive scan mode
SD-K530SU - Turning Off Progressive Scan Mode
Once the setting for Progressive Scan output is entered,
an image will only be visible on a Progressive Scan compatible
TV or monitor. If you set Progressive Scan to On in
error, you must reset the unit. Pointing the remote at the
player, press the STOP (x) button to stop any disc that is
playing. Next, press the STOP (x) button again and hold it
for five seconds before releasing it. The video output will
be restored to the standard setting, and a picture will once
Nov 06, 2007 | Insignia NS-DVDR1 DVD Recorder
Progressive scan
lpug ur dvd. without turning the power on press and hold the stop button then press the power button
Sep 22, 2007 | Pioneer DV-373 DVD Player
GBV441 Goldstar DVD Player / VCR Combo
this is the right solution, the solution in the User Manual doesn't work
Nov 04, 2006 | Goldstar GBV241 DVD Player/VCR
GPX DV7500 System Logo
326 people viewed this question
Top GPX Audio Players & Recorders Experts
Steve Allison
Steve Allison
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
