Question about Sony KP-53V80 53" Rear Projection Television
Sony KP-53V80 Unit powers up fine, No sound, no response from remote control for sound or at console. Almost immediate shutdown after Antenna connection is made or video connection.
    Novelist:
    Champion:
  • 277 Answers
If you're NOT still under warranty you should at least open the TV and look for a blown fuse near where the power cable enters the set. A lot of times you can buy replacement fuses at a local electronic or hardware store and they're easy to replace. Check the fuse. If it is blown, it will be obvious and make sure that the set is unplugged before replacing it. If it blows again, or if it is not blown, your problem is probably in the 'X' volt regulator and you will need professional help with the repairs. You can also check the board where the components are mounted and resoled any that look bad. Brief power outages may cause the TV to turn off on its own. If you are using a surge protector, try connecting the set directly to the wall outlet. In your case it could caused by a blown fuse, a leaky diodes or a bad solder joint at the horizontal drive transformer. All can be replaced at a local electronic or hardware store and they're easy to replace If this does not correct the problem, you may need to have your TV serviced. good luck!
Posted on Jan 15, 2006
SOURCE:
Sony model KP-53V80 wont show picture or sound
YOU LOST VERTICAL DEFLECTION THIS WILL REQUIRE PARTS REPLACEMENT
Dec 25, 2009 | Sony KP-53V80 53" Rear Projection...
Kp-65wv700 7 blinks
hello High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
shaun
Nov 10, 2009 | Sony KP-65WS500 65" Rear Projection...
I have a Sony Projection TV KP-53v80. I tried to turn it on today bu there is no picture no sound. The Timer/Standby indicator flashes 4 times. What does this mean?
No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted.
Check IC1509, Q1505
Please rate this solution
Jan 18, 2009 | Sony KP-53V80 53" Rear Projection...
Sony KP-53V80 is not turning on.
4 LED flashes indicated a faulty IC board
Sony big screen tv model# kp-53v80
It can be just an adjustment of your screen control. There is a "sweet spot" on the control where it allows the picture to come through. This is a common problem with sets that are getting old. If there is a problem with the high voltage from the color tubes then it will shut down the video until the problem is gone and it is safe again to show the picture. This is known as going into a shutdown procedure to protect the set. A technician will be needed to fix your problem since it will require proper troubleshooting and knowledge of high voltage system and safety procedures.
Sep 22, 2008 | Sony KP-53V80 53" Rear Projection...
Sony kp-53v80
Sounds like one of the tubes is shorting out causing the set to go into a shutdown status so it won't cause any major damage to the set or house.
Sep 06, 2008 | Sony KP-53V80 53" Rear Projection...
Sony kp-53v80
Check the 470UF Tank capacitor in the Switching Power Supply.Sometimes when heated,it gives trouble.
Apr 01, 2008 | Sony KP-53V80 53" Rear Projection...
Sony KP-53V80 53 in. Rear...
It's not a digital hi-def tv, so you either need a cable/sat box..or a converter once hi-def goes in and analog stops.
Mar 31, 2008 | Sony KP-53V80 53" Rear Projection...
Sony tv model #kp-53v80
you have most likely a shorted hori out out NTE2324 and look around hori there is a 1200pf 2k volt cap that goes bad.I have fixed alot of sonys with this problem.
Jan 28, 2008 | Sony KP-53V80 53" Rear Projection...
Sony KP-53V80 53" Rear Projection Television Logo
100 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
