Question about Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control
Ceiling fan my main light switch is on, but my remote will not work. i turned the main light switch on the wall off by accident and that is when the remote and everything stopped working. i can't even turn the light on and off by switch, cord or remote. how do i program the remote to work. i no instruction manual.
  • StanWert Nov 12, 2008
    I have the same problem. the remote light is on, yet none of the controls work. Turning on the power from the outlet doesn't help.
    What is required to replace the fan reciever?
Hampton bay cieling fan argenta 61413 manual or instrutions
Posted on Dec 11, 2008
My fan and light worked and now it doesnt. The batteries are good. I think I deprogramed it. I need the codes and threw out the book.
Posted on Nov 15, 2008
If the switch is "OFF" on the wall, the remote will not control anything. The power has to reach the receiver first. If it worked before you turrned the swich off, than one of two things. Either
A: You blew a circuit to the unit or
B: Your receiver went out.
First thing I would do is check that POWER is getting to the receiver.
Posted on Sep 19, 2008
Why Ceiling Fan Fixture does not work
You get what you pay for! Shouldn't buy a store brand.
Jul 14, 2014 | Hunter 52" Ceiling Fan With Light And...
Just installed a heller ceiling fan with remote, it works fine from the remote but the light nolonger works from the light switch
All the switch on the wall does is turn the power on/off. You have to do everything from the remote with the wall switch on.
Dec 27, 2013 | Hampton Bay 24002 Ceiling Fan
My remote lights up when you press the button but it's not controlling my fan.
Controlling a ceiling fan/light using a wall switch causes the remote control to lose its memory. You will have to start all over at the beginning. Remove batteries from the remote, push all buttons to eliminate a stuck button as a cause, then reinstall batteries but do not push any button yet. Be sure all wall switches are off. Go to the power source for the fan/light (not the wall switch) and turn it off. Wait briefly, then turn on the power at the source again. Try remote operation. If successful, use only the remote to control operation. Forget about using the wall switches.
Dec 21, 2013 | Dryers
Dimmer not working but the light does come on.
What kind of wall switch do you have? Is it a remote wall switch? You can't use a basic Fan/light control with a remote.
Jun 03, 2013 | Hampton Bay AC414-LRU 52'' Kemper...
Monte Carlo ceiling fan and light not working
Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
Lastly, there always is the possibility that some gremlin changed your original control setup.
Jun 23, 2017 | Dryers
The remote controls the fan speed but wont dim or control the light. the unit wont work if the light switch is off so I cant use the fan at all unless the light is turned on
mcdevito75 here, Generally the Ceiling fan motor is hooked up by-passing the wall switch but still to the hot laed going to the wall switch whlie the lights are hooked up to the hot lead after the wall switch, So without the remote, Manually operate your fan and lights. First with the wall switch off the fan should work and the lights no work. Now turn the fan off with the pull chain on the fan shroud close to the ceiling. Now turn wall switch on and lights should work with wall switch and the fan should also work. if so, re-program the remote or change the batteries or even re--place the remote.
Jul 26, 2010 | Hunter Ceiling Fan Light Remote Control
Fan with remote won't work with wall switch. I
I just recently purchased a hunter ceiling fan w/light and remote. Had it installed and wall switch would not work, only remote. I contacted Hunter company directly about this problem and I was told that they redesigned their fans with remotes so that only the remote works for turning off power to fan. The person who made that made that BRILLIANT change should be fired. So to those of you who own a newer hunter an product with a remote ne your wall switch will not work tat s te reason why.
Jul 14, 2009 | Hunter Ceiling Fan Light Remote Control
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Wall switch
I had this same problem (sort of) - my daughter lost the remote to our fan and it would not work from the wall switch. What you have to do is go up to where your fan is connected to the ceiling, slide the canopy down, and remove the remote transmitter. Then just rewire the fan normally - white to white, black and blue to black, and the ground wires together. Turn on the power and your fan light should work with the wall switch. You will have to pull the cord for the fan to work.
Jan 07, 2008 | Honeywell HFS641P Stand (Pedestal) Fan
Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
321 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
