Question about Sony CDP-C910 10-Disc CD Changer
Internal breakage a cd was inserted incorrectly into changer and now a plastic part on the inside(the arm which moves/shuffles the cd) has cracked off. what advice can you recommend? can this be repaired or can something be replaced-what is the best way to go about this? thanks!
    Scholar:
  • 124 Answers
I assume that after it cracked off the mechanism doesn't work anymore. anyway, even if it does, the damaged part can damage other parts as well, and CD's also. so even if it works for now, using it is not a good idea in my opinion. about fixing it - unless you are a technicianm, i cant think of a way to fix this hardware problem by yourself. you can only hope that replacing only the damaged part is a possibility, otherwizei assume you will have to replace the intire unit.
Posted on Feb 02, 2006
Cd changer shuffles but won't play
Check its laser pickup assembly for any dirt or dust. Click here for more details
Sep 04, 2012 | Pioneer PD-M403 6-Disc CD Changer
I get E-01 error of my cd changer
The fault is actually inside the CD changer, when one disc is selected the changer moves the gearing inside to slot from one CD to the other.
While this operation is happening the selection arm jams !!
Then giving an error at the radio display..
To fix the problem, disconnect the CD changer from the trunk of the car,
take off the top plastic slide cover,
with a small screwdriver slowly move the gearing so that the CD disc holder will move back to the load - unload position.
Pop out the CD holder.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again,
grease the moving parts with light lubricant
Good Luck
Feb 24, 2011 | Mercedes-Benz C-Class Cars & Trucks
No shuffle capability! Help!
hit the thingymajiggermabob inside of it with a hammer than it shall work if not get a new one problem solved
Dec 18, 2010 | Yamaha CDC-697 - CD changer 5-Disc CD...
I have a Phillips MC/50. The CD changer keeps changing and won't play, just keeps flipping. If you use the tuner, you still hear the clicks of the CD changer. You have to unplug it.
There is a switch inside the changer that will not release. Most likely the plastic stop it rides on has broken off . This is common when the changer keeps shuffling the disc all the time
Dec 18, 2010 | Philips MC-70 CD Shelf System
My original problem WAS that the magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame INSIDE the...
there are small drive belts that provide the power to operate the different parts to eject the CD magazine, i suggest you remove the covers and check these belts for slack/strech, it is a common reason for this problem
Jan 28, 2010 | Alpine CHA-1214 12-Disc CD Changer
The magazine wouldn't eject which i'm told is due to a weak or dirty belt or gearing. I have a temporary solutuion for this (which is to undo the top of the frame inside the caring which releases the...
Hi
Open top cover, if the empty magazine was left inside the cd trays it can slide out into the playing area and jam the unit, check it like that anyhow. Sometimes you can see a small metal tab to release the magazine.
However Error1 means Battery inside CD Changer needs to be replaced.
And NO CD.CD error message means No CD in magazine or no magazine in CD Changer.
To fix the problem, disconnect the CD changer.
Replace unit, reconnect the optic and power lead, switch on radio and the unit will work again.
grease the moving parts with light lubricant.
Thanks for contacting fixya.com
CD Discs have been displaced inside the unit while moving
Had this happen to me awhile back while I was fixing a DVD scratch problem with my 400 changer. As I recall, the top cover comes off easily (a few side and back screws and perhaps an internal top try cover) and you can access the disks easily to reset them in their slots. Obviously, you should unplug the unit before you open it.
Jan 28, 2009 | Sony MegaStorage CDP-CX455 400-Disc CD...
Disc error
hi, does it take the tray out or stop half way?
the alpine changer mechs have a problem with jamming up.
this also covers the mercedes and BMW models too.
if its just tray 3 thats not working then it could be the tray try swapping the tray around this will rule out the mag/cart/tray. that way we can tell if its the changer or the mag/cart.
if its all trays that it dont work on the try tapping the mag with the handle of a screw driver while its trying to load, this is normally enouight to unjam the loading arm..
Mark
Blue ICE
Feb 24, 2008 | Alpine CHA-1214 12-Disc CD Changer
Sony CDP-C910 10-Disc CD Changer Logo
136 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Gyula Lacz
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
