Question about Kitchen Ranges
Jenn-Air S160 Jenn-Air Electric self cleaning oven (model S160) oven door won't open after I used the cleaning cycle. I don't have the owners manual to get instructions. Help. We've cut the power to the stove hoping it would unlock when we powered back up. Didn't work.
  • sheebers Oct 16, 2008
    i used the self clean feature but oven door did not unlock- nothing seems to work on oven except the clock. Please help!
  • Mary Klinge
    Mary Klinge Mar 25, 2014
    You have to turn the oven dial to make it unlock
I did it by mistake. I tried to move the lever over and of course, it didn't open but went to restart. I hit the cancel button and then tried the door again and it opened. Yup, we all here feel likes dorks!
Thank you!
Posted on Sep 07, 2008
What is 15 year old Jenn air stove, model S 160 worth? It is in good shape and has just recently been checked by SEARS and operates fine. New racks, new knobs, and new broiler pan. Completely cleaned up. Looks like new!
Posted on Oct 17, 2008
There's a safety feature built in which will not unlock the door until the oven has come back down to a safe temperature after a cleaning cycle.
Posted on Dec 30, 2008
Self cleaning ovens
Perhaps it hasn't cooled down enough; or you may have to run the self-cleaning cycle again. The oven has to reach a certain temperature before it starts to turn the residue to ash.You may have interrupted its cycle.
It then has to cool off sufficiently to safely open the door.
Dec 22, 2012 | Jenn-Air Kitchen Ranges
TRYING TO FIND SELF CLEANING DIRECTIONS FOR MY JENN AIR S160
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Aug 31, 2010 | Jenn-Air Kitchen Ranges
Self cleaning instructions
If the model number is correct, the self-cleaning instructions are as follows:
1. Make sure oven door is closed and press "CLEAN".
2. "REMOVE RACKS" should be displayed. Remove all oven racks to avoid damaging them.
3. Select "CONTINUE" using the Quickset pads on either side of the control panel.
4. Set LIGHT soil level by entering "200" using the number pads for 2 hours cleaning. Select MEDIUM for 3 hours. Select HEAVY for 4 hours.
5. "CLEAN", "TIME", "LOCKED" and the cleaning time countdown will be displayed while the oven is cleaning.
6. "OVEN COOLING" will appear when the cleaning time is complete, but the oven door will remain locked until it is safe to open. (approx. one hour after cleaning cycle ends).
These instructions are almost verbatim on page 23 of your owner/operator's manual. If you no longer have a manual, you can go to managemylife.com and enter your model number under the "Manuals" link. Your owner and installation manuals are listed in a .pdf (Adobe) format that you can download or print for FREE.
If you have any questions, or if your model number is different, please post back and let me know. I hope this helps you.
Feb 20, 2010 | Jenn-Air JES9860 Electric Kitchen Range
How to turn off self clean oven Jenn air slide in older model after it is done cleaning
the self clean cycle will run for 2-3 hrs and the door will remain locked for another couple hrs while cooling let it finish and wait till the next day basically if it still wont open (sorta common) the door lock assy needs replacing.
Oct 08, 2009 | Jenn-Air SVE47100 Slide-In Electric...
I need direction on how to start the clean cycle on my jenn air
CLEAN PAD
Use to set a self-clean cycle or a delayed
self-clean cycle. One press of the Clean
pad sets up an immediate clean cycle. A
second press of the Clean pad sets up a
delayed clean cycle.
• Clean oven
frame, door
frame (area
outside of gasket)
and
around the
opening in the door gasket with a nonabrasive
cleaner such as Bon Ami*. These
areas are not exposed to cleaning temperatures.
• Remove air grille.
• Remove oven racks. If racks are left in
during a clean cycle, it may impair function
and they will discolor. Turn off the
oven light and close door.
* Brand names for cleaning products are
registered trademarks of the respective
manufacturers.
TO SET FOR IMMEDIATE START:
1. Press Clean pad once.
2. Press the Auto Set pad for 3 hours of
cleaning time, press again for 4 hours
and again if 2 hours of clean time are
desired.
3. CLEANING and LOC plus the clean
time will appear in the display.
4. When the clean cycle is complete,
CLEANED will be displayed. LOC will
remain on until the oven has cooled
(approx. 1 hour).
5. When the oven is cool, LOC will no
longer be displayed and the door may be
opened.
6. Wipe out the oven interior with a damp
cloth. If soil remains it indicates the
cycle was not long enough.
TO CANCEL SELF-CLEAN:
1. Press Cancel pad.
2. If LOC is NOT displayed, open oven
door. If LOC is displayed, allow oven to
cool.
Thanks for using Fix Ya, Please take the time to rate this solution.
clarkco
Feb 08, 2009 | Jenn-Air JDS9860A Dual Fuel (Electric and...
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Jenn-air gas electric grill range
any power to unit at all?? clear, start, clean ,button?? what happens when you push them??? clock on?what happens when you try to set to clean again??? it should activate hte door lock latch at which point cancel and it should reset itself. with any luck! what happened thankgiving how was it fixed
Mar 14, 2008 | Kitchen Ranges
Selfcleaning Jenn-Air electric oven
How do I clean my jenn-air double oven when I lock oven door and turn oven to clean mode set time to start I don't get anything. Also when I lock the oven door the oven lock light does not come on.
Dec 05, 2007 | Jenn-Air JJW8230D Electric Double Oven
Jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Nov 18, 2007 | Jenn-Air SVE47100 Slide-In Electric...
Kitchen Ranges Logo
1,907 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
