Question about Panasonic SC-AK600 CD Shelf System
Does not play CDs. After closing, tray immediately opens again and displays "Take CD out". Cycles through trays and gets stuck.
    Novelist:
    Champion:
  • 277 Answers
If you sure that the system supports the disc's format.. And it won't play other discs... try to clean the CD lens. If it wont help and you're NOT still under warranty you should at least open the system and look for Problems with the door opening/closing: Steps: 1. Make sure the drawer-loading belt is still tight and elastic. If not, it can be replaced with a belt obtained from an electronic-parts supplier. The replacement should be of equal or slightly greater thickness and should fit snugly but not so tightly that it strains the motor. 2. Check for broken or loose gears and have them replaced. 3. Check for obvious sources of contamination such as pet hair or foreign objects that are preventing smooth operation of moving parts. Small children have a habit of inserting items into CD players. 4. Use electronics-grade contact cleaner to clean the door-position contacts.
Posted on Jan 15, 2006
5 cd changer problem
what brand/model number?
Jan 03, 2013 | Audio Players & Recorders
Durabrand W600-S cd tray wont open
Hello, this kind of repair requires certain skils and knowledge about the cd changer mechanism. Please claim for an in warranty repair or replacement of the system. If you need more info please advice. Arpi
Jul 16, 2007 | Durabrand W600 Shelf System
Th cd are getting stuck in my gpx kccd6316dt, I
Is it still under warrenty?
Either it is worn out or it has a manufacturing defect.
Mar 24, 2010 | GPX KCCD6316DT Shelf System
Denon DCM-280. Tray won't open, there are CDs in
If you don't wanna send it for service, open the chassis of the player and free the CDs from the tray. Its highly likely that the CDs came off the trays and got stuck inside.
Jul 31, 2009 | Denon DCM-280 5-Disc CD Changer
Cd changer loading problem (panasonic sa-pm53)
Have a Panasonic SA-PM53 pulled a CD trays out to get stuck CDs out. So how do I get the 5 CD trays back into the carriage and in sync?
May 24, 2009 | Panasonic SC-AK78 CD Shelf System
Cd tray won't open; won't play cd or turn off
No solution - plastic thread driving opening/closing had snapped after 16 years!
May 17, 2009 | JVC XL-M509TN 7-Disc CD Changer
CD tay won't open
If you had any cds inside, you can open the case and see whether there's any cd jammed, with the power switch off! If you didn't have any cds inside, open the case anyway and check if the tray opens or not!!!
Hope it goes well!!
Apr 04, 2008 | RCA RS2653 Shelf System
Cd tray stuck closed
open the cabinet and remove the magnetic lock placed on the top of the mechanism then u can remove the cd
Jan 02, 2008 | Yamaha GX-505 CD Shelf System
How to rip musc to my harddrive
Play Recordable CDs Containing MP3/WMA Audio Files
To play recordable CDs containing MP3 and/or WMA audio files:
Press the eject button on the Xbox 360 console (or select Open Tray from any area of the Xbox Dashboard) to open the disc tray.
Place a data CD-R or CD-RW containing MP3 and/or WMA media on the disc tray with the label facing up (to the right if the console is vertical).
Press the eject button (or select Close Tray from any area of the Xbox Dashboard) to close the disc tray.
Go to the Media area of the Xbox Dashboard. Select Music, Current Disc.
To play all tracks on the CD, select either Play All or Add to Current Playlist.
If you have an existing playlist open, Add to Current Playlist will append all tracks on your current CD to that playlist. Selecting Play All will clear a current playlist and create a new one consisting of all the files on the current CD. (Be sure to save your playlist, if desired, prior to selecting the Play All option.) Files are added to a playlist in alphabetical order by file name. Playlists start again from the beginning once the final track has played.
riz.
Nov 18, 2007 | X-Gaming X-Arcade PC Joystick (XGMPC)
Panasonic SC-AK600 CD Shelf System Logo
182 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
blanqui2000
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
