Question about Technics SL-1210MK5 Turntable
Slow start When i place the needle on the platter it very slow to get to regular speed and if i touch the platter for scrating it takes about three seconds to get up to speed
  • 515 Answers
There is something wrong with your drive system. Unfortunately, you will have to have a service professional take a look at this.
More than likely one of the Integrated Circuits (IC's) have gone bad and will need to be replaced - a common issue on the newer models.
- OPTiC
The 1200s Expert
www.1200s.com
Posted on Sep 08, 2008
Once the needle touches 33 lp it speeds buy the songs
Yes the platter speeds up until the moment comes. 0'5 sec later and then the electronics take over , want you to try quartz activated and after that quartz put out and then you have a pll. try moving the pitch a bit, cause the 1210mk2 aint tables which you want for the good maintainence. if it helps or doesn't , mail as fast as you can
Mar 18, 2014 | Technics Audio Players & Recorders
Trying to repair circa 1965 HMV "Imperial" Solid State record player. The turntable is not revolving at the correct speed so I want to dismantle and see if I can fix it or find what parts I need. So my...
There should be a "C" clip on the center post that holds the record in the middle. Pop that off and gently wiggle table up. Careful not to over stretch the belt. There could be a cover over the clip.
Jun 30, 2009 | Audio Players & Recorders
Recently purchased used Panasonic SL-HM42 turntable. Works, but turning a little slow on 33rpm (30-31rpms) says DC Servo System on the front. Don't see any set screws on bottom. would like to get platter...
How to tweak the playback speed on Panasonic SL-HM42 turntables
You will need:
  1. 1x small Philips screw driver
  2. 1x small flat-head screw driver
  3. An ear for correct pitch and a little bit of DIY skill!
Step 1 - Remove the wooden base plate
After ensuring that you've removed the the rubber turntable slip mat and securely docked the turntable arm, carefully flip the turntable over onto its lid to expose the wooden base plate, as per below.
Using the small Philips-head screw driver, remove the screws holding the wooden base plate in place, then gently lift the base plate off the turntable.
Step 2 - Expose the pitch adjustment screws
Once the wooden base plate is removed, you will see the speed-controller circuit board on the right-hand side.
To expose the the two speed/pitch-control screws, firstly remove the screw holding the speed-controller circuit board in place, then gently lift the circuit board up on the free side.
Step 3 - Correct the turntable playback speed and pitch
The easiest way I found to correct the playback speed was to flip the turntable carefully back into the original position, allowing the speed-controller circuit board to hang free as shown below.
Next, play a record that you know well and are able to tell when the speed/pitch is correct (assuming you have an ear for correct pitch, that is!), then at the same time using the small flat-head screwdriver, gently turn the speed adjustment screw(s) to adjust the playback speed up or down until the correct playback speed and pitch is achieved (or at least until it no longer annoys you ;).
Turning the screws clockwise (to the right) will increase the speed/pitch, and anticlockwise (to the left) will decrease the speed/pitch.
NB - Both screws allow for fine pitch control, so if the second is already at maximum speed, you can use the first screw for additional speed.
Step 4 - Reassemble the turntable again
When you're happy with the speed of your turntable, remove the record, the mat again & locking the turntable arm, replace the screw holding the speed-controller circuit in place (as per Step 2) and then finally replace the screws holding the wooden base plate, as per Step 1.
Happy listening!
Aug 29, 2013 | Audio Players & Recorders
Platter Grinding Noise on Aiwa PX-E860
Try to determine if the noise is caused by the motor or the platter touching something. Try moving the platter by hand. Press on it whilst turning to see if it's catching. If you can get the platter off you could try some silicone grease on places you think touch one another.
Jul 16, 2013 | Audio Players & Recorders
Back firing through carb as accelerating from about 25mph to 45 mph. 2004.60 mph or better no backfire or when idlling FXD Harley only 2600 miles. Started after a fillup does not seem to want to go away...
1st id try sea foam in the tank give it time to work . could be bad gas is it carb drop bowl check slow jet & main jet for obstruction... Id pose this ? on harleytalking.com they have helped me ... good luck..
May 26, 2011 | 2004 Harley Davidson FXD - FXDI Dyna Super...
My huskystar is sewing too slow. What can I do to speed it up? I have cleaned all the lint from bobbin area. The longer I sew the slower it goes.
it sounds like you might be in need of a good oiling you should use a good sewing machine oil not wd 40 or three in one oil. place a drop or two on the needle bar and the some on the needle bar crank
Aug 27, 2010 | Husqvarna Sewing Machines
HMV Radiogram Turntable run slow at the start,
you should check under the table.
if it's a roller drive there, you can use water to clean the roller rubber and the inside edge of the platter.
If it's a belt drive, take it out and measure the length and get a replacement belt of same length
Jul 27, 2010 | Audio Players & Recorders
The turntable will not start spinning on its own, I have to spin it to get it to start, and when it does start spinning the speed is too slow. Is it just the belt?
You will need to check your belt for wear. Lift felt on platter and check belt tension. It may need replacing. To replace, simply lift platter section of the unit, taking note of the belt position. replace and your problem will be solved
Dec 19, 2009 | Aiwa PX-E860 Turntable
Numark cdx
have you checked the brake and start up settings they are the dials by the start and stop buttons it it is turned too far the platter will start up slow, you just trun to dial till you get the right start up speed you want
Jul 25, 2008 | Nu Mark Numark Cdx Table Top CD Player CD...
Technics SL-1210MK5 Turntable Logo
167 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
