MSI MS-6754 mother board won't boot and beeps when I swap processors
I've got a working PC with a MSI MS-6754 mother board with a 1.8 Celeron 478 pin processor and 1GB of RAM. I removed the processor and installed a 2.66 Pentium and the PC will not boot and the motherboard beeps. From what I've read on the internet, the beeping is a sign of bad RAM. I tried a 2.4 Pentium processors and the same thing, beeping. I put the Celeron back in and works great. The manual for the Motehrboard says any P4 processor up to 2.8GHz will work. I'm left scratching my head! What gives?
  • 1 more comment
  • yzpilot Sep 19, 2008
    Thanks Dileep! You pointed out that my motherboard was a 400MHZ FSB. I was trying to install a 533 MHZ FSB P4 processor. I finally got a 400 MHZ FSB P4 processor and now it works!
  • Ravel Lively
    Ravel Lively May 11, 2010
    Have you installed the latest bios on that motherboard, they were built in 2003 you know and often the motherboard manufacturers would leave updates necessary to run some processors for the next bios update. Also, you checked your jumpers according to your manual. Go back over them again to verify frequency, multiplier, and voltages are set for the P4 processor that you are trying to install. If that isn't done, you will get exactly what you are seeing. Be happy you have a manual, use it.
    There were two versions of that motherboard, one with Lan and one without, which one do you have?
  • Anonymous Mar 17, 2014
    msi mother board 1 long beep
Ya know. I was trying a 533 FSB processor I see now that my motherboard only supports 400! Standby. Let me get a 400 and see if it cures my ills! Ahhhhh............
Posted on Sep 09, 2008
  • 983 Answers
Your motherboard has the chipset of 845GL series
so the specification of your motherboard is as follows read it carefully there may be some error in the manual or it might not be your motherboard model just have a check with that . here are the specifications as per i saw in the net ...
CPU • Support Intel® P4 (Socket 478) processor up to 2.6 GHz. Chipset • Intel® 845GL Chipset - Support FSB 400 MHz. - Integrated 3D/2D graphic core (Core frequency= 200MHz, 350MHz integrated 24-bit RAMDAC). - Support PC266/133 Technology. • Intel® ICH4 Chipset - AC'97 Controller Integrated. - 6 ports Hi-Speed USB 2.0 controller, 480Mb/sec. - Support both ACPI and legacy APM power management. - Legacy free support.
Posted on Sep 08, 2008
  • Dileep Keshavanarayana
    Dileep Keshavanarayana Sep 08, 2008
    Main Memory
    Support four memory banks using two 168-pin unbuffered SDRAM DIMMs.
    Max. memory size is 2GB without ECC (1GB/slot).
    to the High Performance Memory design, motherboards or system
    configurations may or may not operate smoothly at the JEDEC (Joint
    Electron Device Engineering Council) standard settings (BIOS Default on
    the motherboard) such as DDR voltage, memory speeds and memory timing.
    Please confirm and adjust your memory setting in the BIOS accordingly
    for better system stability.
    Example: Kingston HyperX DDR500 PC4000 operates at 2.65V, 3-4-4-8, CL=3.
    For more information about specification of high performance memory
    modules, please check with your Memory Manufactures for more details.
    Support 100MHz FSB
    Support 400MHz Intel NetBurst micro-architecture bus.
    Three PCI 2.2 32-bit Master PCI Bus slots
    2MB Award BIOS.
    ACPI, SMBIOS 2.3, Green and Boot Block.
    Provides DMI 2.0, WFM 2.0, WOL, WOR, chassis intrusion, and SMBus for system management.
    On-Board IDE
    Dual IDE controllers integrated in ICH4.
    Support PIO, Bus Master, Ultra DMA33/66/100 operation modes
    Can connect up to four IDE devices.
    AC'97 link controller integrated in Intel ICH4 southbridge.
    2 channels S/W audio codec (Realtek ALC 101 codec):
    Compliant with AC'97 2.1 Spec and meets PC2001 audio performance requirement
    845GL Chipset Integrated with Intel Extreme Graphics 2D/3D controller
    PCI local bus single-chip Fast Ethernet Controller, RealTek RTL8101L.
    With external 10/100 Base-T Lan transformer.
    Integrated Fast Ethernet MAC and PHY in one chip.
    Supports 10Mb/s and 100Mb/s auto-negotiation operation.
    Compliant with PCI v2.2 and PC99 standard.
    Supports ACPI Power Management.
    On-Board Peripherals
    1 floppy port supports 2 FDD with 360K, 720K, 1.2M, 1.44M and 2.88 Mbytes.
    1 serial ports (COM 1)
    1 VGA port
    1 parallel port supports SPP/EPP/ECP mode
    6 USB2.0 ports (Rear * 4 / Front * 2)
    1 Line-In/Line-Out/Mic-In port
    2 PS/2 connectors
    1 LAN RJ45 connector
    1 IrDA connector with Intel pin-definition.
    24.5 cm(L) x 21.4 cm(W) Micro-ATX Form Factor
    6 mounting holes
    you can just have check again in the website given below :
    so please have a check with the manual correctly once or go to other site and also check the specification for your motherboard as i think the processor what you are trying to install with is not compatible ...
    have a check
Dear sir intel 845 , MS-6714 ver:1 per processor intel pentium 4,2.40ghz/1m/533,SL86Fcosta rica support or not thanks Narendra
Your board is MSI, you can accsess their website here;
You can get downloads and have them scan your system with their "live eye". It has Intel 845GV and ICH4 chipsets and Realtek ALC650 with AC97 codec for sound, It also has Realtek LAN. It can use Intel Pentium 4 or Celeron processors, up to 400-500 MHz. This is Intel's site:
I will also give you Realtek's site:
I'm not sure what you are looking for but, I hope this helps you.
May 23, 2011 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Please, I am need manual mother board MSI G31M3-L V2. Obrigado!
then select US
see page 1 of pdf document.
Thank you for choosing the G31M3 V2 Series (MS-7529 v1.x) Micro-ATX mainboard. The
G31M3 V2 Series are based on Intel
® G31 & Intel® ICH7 chipsets for optimal system
efficiency. Designed to fit the advanced Intel
® CoreTM 2 Duo/ CoreTM 2 Quad/ Pentium
Dual-Core E2XXX and Celeron 4XXX/ Wolfdale Series LGA 775 processor, the G31M3 V2
Series deliver a high performance and professional desktop platform solution.
Apr 24, 2011 | MSI G31M3-L V2 Motherboard
Whats the processor support of this board
Pentium® 4 processors & Intel® Celeron® processors in 478-pin package.
it will support the following in the 478 pin package
P4 1.4ghz 400fsb speed to
P4 3.06ghz 533fsb speed
Celeron 1.7ghz 400fsb speed to
Celeron 2.8ghz 400fsb speed
Nov 23, 2010 | Intel 845GEBV2 Motherboard
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
B) One 4-pin ATX +12 Volt power cable,
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Nov 22, 2010 | Intel D101GGC Motherboard
I have this moterboard 845gvm-v ms-7057 ver : 1.0 i would like to know wat cpu i can upgrade to my pc speed is 2.40 ghz and i have a socket 478
Supports Socket 478 for Intel P4 Northwood/Celeron/Prescott/Prescott Celeron processor
?Supports up to 3.06GHz and P4 Prescott up to 2.8GHz.
Oct 24, 2010 | MSI 845GVM-V (MS-7057-010) Motherboard
Whats the best cpu for PM8M3-V H
you can change your Processor into Intel Pentium 3.0Ghz, for socket 478 pin type. or intel celeron D 3.0Ghz socket 478 pin type. i would like to let you know that the speed of Computer depend on the processor and memory is for cache only.
Jun 11, 2009 | MSI PM8M-V Motherboard
I format my pc driver cd lossed so i need driver
You will most likely want All-in-One Driver (older is 4-in1, also called VIA Hyperion)
Mar 14, 2009 | Drive Computers & Internet
Need wiring diagram or manuel for msi 845pe max mother board
There you go M8!
There is the manual, and all other avilible stuff for your MoBo:)
Good luck to you, and thanx for using FixYa!
If you find my answer helpfull, plz dont forget to vote!
Dec 20, 2008 | MSI Computers & Internet
PC Not Starting
When you say "...put computers back together..." what does that mean?
Check video cable pins. Check disk drive connector...make sure they are pushed in tight on mobo and drive connector.
Apr 27, 2008 | MSI 694T PRO (6309-470) Motherboard
CPU Upgrade-Which Sockel?
Here is some information may be useful to you. Intel processors Socket 1 169 pins 486 SX/DX Socket 2 238 pins 486 SX/DX/DX2 Socket 3 237 pins 486 SX/DX/DX2/DX4 Socket 6 235 pins 486 DX4 Socket 4 273 pins Pentium 60 en 66MHz Socket 5 320 pins Pentium 75 t/m 200MHz Socket 7 321 pins Pentium, AMD K6/K6-2/K6-3, Cyrix M1/M2 Socket 8 387 pins Pentium Pro 150 - 200MHz Slot 1 242 pins PII, PIII en Celeron Slot 2 330 pins PII Xeon en P III Xeon Socket 370 370 pins PIII, Celeron, Cyrix III Socket 423/478 423/478 pins Pentium4 Socket 603 603 pins Pentium4 Xeon PAC418 418 pins Intel Itanium PAC611 611 pins Intel Itanium 2 AMD processors Slot A 242 pins Athlon Socket A 453 pins Athlon, Athlon XP, Athlon MP and Duron Socket 754 754 pins AMD Athlon 64 Socket 940 940 pins AMD Opteron Conclusion: You can not upgrade beacuse Armada M700 has a pentium III processor with 370 pins. So the Socket 478 pinned pentium is not suitable. Advise: Try to exchange it with a new laptop or buy a used laptop for suitabl configuration
Oct 01, 2007 | Compaq Armada M700 Notebook
Computers & Internet Logo
2,259 people viewed this question
David Payne
David Payne
