Question about Dishwashers
KitchenAid KDS-16 dishwasher, leaking from fill air gap
I have an old KitchenAid dishwasher. I remodled my kitchen, and put it back in, and noticed that it was leaking. I found that it it was leaking at the fill air gap assay. (Looking through my repair manual it is part# C-103747). If I replace the part is it going to fix my problem?
    Novelist:
  • 166 Answers
Peace,
If you want to try it okay .
but i think there are more variables and
you need hands on service tech with experiance!
Posted on Sep 07, 2008
My old KitchenAid KDS-16 dishwasher is making a loud, high-pitch, metallic sound but it still appears to be operating OK.
There is a fan blade on the top of the pump shaft. IT is loose. They are pressed onto the shaft. The only thing you can do is replace the motor or the whole machine.
Sep 08, 2017 | KitchenAid Dishwashers
Maytag dishwasher leak
If it's leaking from the door, a new gasket may fix this. If it's leaking from the pump, the seal is worn out, and the repair may be too costly or difficult. If the unit is 5 years old, consider a replacement.
Aug 29, 2015 | Maytag Dishwashers
Is a gap at top between outer door panel and inner control door on Kitchenaid dishwasher KUDE normal?
When the dishwasher starts the drying cycle, there has to be vent that the steam can escape and it just so happens to be on the left side.
Aug 06, 2014 | KitchenAid Dishwashers
Is gap between front door panel and inner panel on a KUDE Kitchenaid dishwasher normal?
Generally, dishwasher doors don't seal to the cabinet. Hot air MAY escape through the gap - this is pretty normal.
18 month old kitchen aid kudc10fxss leaks water at bottom of door
Someone may've accidentally put liquid dishsoap rather than dishwasher soap into the fill cup. The bubbling will cause lots of foam to rise up above the float-switch without actually raising the switch (shutting off the water supply). Lots of helpers on the web recommended draining, wiping out the foam, pouring in a cup of vinegar and a handful of salt and running the rinse cycle a couple of times. It worked for me!
Feb 25, 2013 | KitchenAid KUDC10FXSS - KitchenAidR...
Kitchen aide won't drain
look in your air gap first make sure there is no debrie in there this will make you dishwasher drain really slow.
Jan 16, 2009 | KitchenAid 24 in. KUDI02IR Built-in...
KitchenAid Dishwasher fill up with water after use
Is the water clean water or dirty water? This may sound like an ignorant question, but it can make a difference. If the water is clean water, it sounds like you could have a bad fill valve. If the dishwasher is filling with water when it is not running, chances are the fill valve is leaking. The valve is closed when the float switch senses the tub filling to a certain level. The valve is also closed when not energized by the control board during drain, drying and off cycles. However, if the valve diaphragm is not seating properly when closed, it will continue to leak by. That's probably why you don't notice it while is running and it has a chance to fill during the night when not in use. Here's what to look for: With the dishwasher off, take a towel and dry the tub as much as possible. Now, locate the fill port where the water comes in (usually on the left hand side of the tub). Watch this fill port closely for several minutes to see if water is running in. It could be as minute as a trickle or drip. If any water is coming in at all, the fill valve should be replaced. Now, another problem that can occur is when you notice dirty water staying in the tub or overflowing. This is usually caused by a bad check valve in the drain pump that's allowing water to leak back from the sink into the tub. Or, you do not have a high loop in the drain line. Here's what to look for: Check to make sure the drain line has a high loop as it leaves the dishwasher and before it gets to the drain pipe at the sink. That is, make sure the drain hose is looped above the trap in the sink and not laying under the sink somewhere. You can also try filling the sink with water and open the dishwasher door. Drain the sink to see if anything is getting fed back into dishwasher. If you see water starting to fill in the tub, chances are you could have a bad check valve. Some dishwashers have a check valve in the drain pump, while other models have the check valve located in the drain hose itself. Some don't have one at all. That's why the positioning of the drain hose can be important. Good luck to you and I hope this may help. If you determine a cause, post back with comments if you need advice on how to replace anything.
Sep 22, 2007 | KitchenAid 24 in. KUDS25 Built-in...
No air gap for dishwasher. Do I need it?
That is a sink overflow hole that should have nothing to do with your dishwasher or disposal. You wont have that feature any kitchen sink that has to accomodate a disposal at the bottom.
If your machine is cycling properly, it could just be that it is a kitchenaid, like mine, and they just are not as high quality as they used to be.
Jan 29, 2007 | KitchenAid 24 in. KUDI02IRBS Stainless...
Dishwashers Logo
623 people viewed this question
Top Dishwashers Experts
