Question about Sony VAIO Digital Studio PCV-RX860 (PCVRX860KIT1) PC Desktop
Replacing the hardrive
How do i open the tower
Hi, do you still need a solution? I just took apart my tower to clean out the dust. I can post pictures of where the levers are to open the tower but don't see the point if you no longer need help.
Posted on Dec 04, 2008
    Sergeant:
  • 305 Answers
I do not have the same model as you but generally all covers come off in a similar way. first have a look round the tower and you should see screws mainly at the back, have a good look at the screws because some hold components to the cover inside. you need to look for screws that are right on the edge of one side, generally larger than any other, undo them,then check the bottom of the tower on the same side as these ecrews, remove them, then the side that had the screws should slide towards the back, it may seem a little stiff, but should slide backwards a few centimetres and then fall,off loosely. hope this helps
Posted on Sep 06, 2008
Hardrive removal
Simple as pie... you will see the harddrive mounted horizontally in a small shelf after you tae the cover off. You have to unscrew the philips screws that hold it in the shelf and unplug the connectors. make sure you label the wires so you know which ones came from that harddrive... they is usually room for 2 harddrives and two complete sets of connectors, don't mix them up. (One is the master and the other called a slave.) There is an adapter for the harddrive that you should always keep should you need to replace the harddrive, (comes in two pieces on either side) the new ones don't come with the adapters to fit them in the case; they are bare bones. If you don't want to go through the gymnastics of taking the other tower apart and installing the 2nd harddrive in it to read it... an internal HDD adapter can be purchased from Tiger Direct for a nominal cost. I allows you plug you internal HDD into a USB socket in any PC (desktop or laptop) and read it as you would a Flashdrive.
Jun 02, 2014 | Gateway E-4300 E4300 Matxhrn Lux Pc - XP...
My emachine tower won't turn on . I try un plugging it and plugging back and it doesn't work. Could it be that there something wrong with the motherboard or the hardrive?
> won't turn on
Remove the side-panel, and then press the ON button.
Do any fans start to turn? Feel any air coming out of the back of the power-supply?
Does pressing the button open/close the CD/DVD tray?
If not, then your power-supply has "blown", and must be replaced.
If the fans do turn, and the tray opens, but nothing happens on the screen,
e.g., no "splash" screen, nor any brief white-text "hardware-summary" appears,
then it's either the CPU or the motherboard which is the problem.
If you see the "splash" screen, or that "summary" screen, but Windows does not start to load, then the disk-drive either is not getting any power, or its "data" cable is not connected, or the disk-drive itself has "died".
It's time to take it to a qualified technician, for professional trouble-shooting.
Feb 01, 2011 | Computers & Internet
Tower power button flashes amber but will not start
Flashing Amber power LED indicates a bad power supply.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817822008&cm_re=atx_power_supply-_-17-822-008-_-Product
May 13, 2010 | Dell Dimension™ E510 PC Desktop
HELP MY HARD DRIVE HAS GONE!
Ok to understand this , you dropped a 1 TB hard-drive external hard drive on the floor? Well considering that it is a external, the cases in most externals are meant to take a beating as well as the hard-drive it self. There is two possiblities I can think of, what could of happened. When the Hard-Drive hit the floor, it could of is disconnected the connection on the hard-drive itself inside the casing, which you will have to pop it open and reseat it. Or the hardrive, arm inside the hard-drive it self snapped or is misplaced, which is unrepairable. Open up the casing and looking for the hardrive it self. Towards the back of the hard-drive is where the connection of th drive is, it is eather sata or orginal set up with his pins based. Take the connection off and put it back on and see if that works, if it didnt, best advise would be is take in in and have the drive tested, see if its still operable.
DrakeTech
Feb 25, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Tower is making clicking noise and a reeving sound but everything is loading and running ok
Please take this time to back up all your data. This could be a sign your Harddrive is failing if it is not your harddrive it could be a fan. You need a tech to look at your system right away to prevent failure. Fans are cheap to replace but if they fail you can lose your entire computer. If its your harddrive your looking at 2-3 hours labor and hardrive replacement. Generally it is worth doing.
http://mylive-tech.com
Techs are waiting to help you.
Jan 01, 2010 | Acer Computers & Internet
Need to remove a hardrive
You open the case and remove it.
Replace it with a new one.
I think this is what you are asking.
Replace it with the same kind--if it's an IDE drive, you'll need a new IDE drive. SATA drives need to be replaced with like kind.
Size doesn't usually matter except in an older system.
Once you place a new drive in the system, you'll need to run the recovery disk that came with the computer or get a copy of the same version of Windows and use the code that should be on the case.
Jul 23, 2009 | Compaq Computers & Internet
I"m trying to hook up this Emachine and im having proble4ms connecting cdrom floppy hardrive
An external drive would have a cable you connect to the back of your tower. An internal would not have this but would connect directly to your motherboard on the inside of your PC Tower.
Based on your follow up question it appears you want to connect to an inside pin out connection point. Is this right? And if so, what type of cable do you have that need to connect? Is it thin and round or flat and wide?
Thank you for your patience. One of use will be able to help you further once you post this information. Sorry, but we actually need to konw this in order to solve your problem.
Regards,
Worldvet
Please use th comment box below to reply.
Aug 18, 2008 | Computers & Internet
Hardrive
you need to go to Gateway.com support and download the driver for yout network card and install it. the mouse should work if it is a basic mouse that came with the computer, or if you have a wireless mouse you will need to get the drivers and install them from the makers website.
Feb 22, 2008 | Gateway 510H Pentium 2.4 GHz, 256MB RAM,...
Gateway Hard drive replacement
Any PATA hardrive. Parallel also known as IDE. I would go for SEAGATE barracuda, simple, effective, and a 5 year warranty.
So, you will be looking for a 3.5 parallel hard drive. Check if your computer has a partition limit, ie, pre firewire 800 machintosh G4 towers cannot take single drives larger than 120 GB.
ATX is your motherboard form factor.
Keep me posted.
Oct 25, 2007 | Maxtor DiamondMax Plus 6800 (91366U4) 13.6...
Sony VAIO Digital Studio PCV-RX860 (PCVRX860KIT1) PC Desktop Logo
104 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
