What is your engine model number?
It should be on a plate on the side of the engine.
Your problem is a clogged jet inside the carburetor. Once I have the engine model number, I will be able to give you a carburetor diagram that will show you how to clean it.
Richard
Look above the muffler for a black plate with a bunch of numbers on it. That is the engine model number.
You will need to rebuild the carburetor to get your mower running correctly. It is a really simple process.
Herwe are the parts you need.
The carburetor kit number is 498260
The main jet number is 498978Here is a copy of the parts list for your engine.
Below is a few videos to walk you thru the rebuild process.
Cannot find a plate on the engine. Is it under the plastic shroud? Ryobi product # is 9611600022 00
Thank you. The numbers are 123K02-0513 E1 05030859
I don't know until I can try the fix, but it makes sense.
